6 Spd Tranny Noise w/ Clutch Pedal Out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by moondeath, Feb 1, 2013.
  1. Feb 1, 2013 at 8:45 AM
    moondeath
    moondeath [OP] Tyrannical leaders use 'Alternative Facts'
    Pa, Carlisle
    2013 TRD Sport DCLB 4x4
    5100 @ 1.75", 1.5" Icon Progressive 3 leaf, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    ]Im curious if other people here with the 6 speed have the whirring noise from the tranny while the clutch pedal is up and goes away while pushed down. It is not the same sound that other people have experienced with the squeaky/chirp noise. This noise has been going on since I bought the truck new. May be completely normal, just want to see if others have the same noise or not.
  2. Feb 1, 2013 at 9:22 AM
    2004TacomaSR5
    2004TacomaSR5 Sentinel Prime
    Jon
    Montana
    2004 Tacoma DCSB & '79 Toyota Pickup 4WD
    Really don't think that is normal, not sure what would cause that. Have you taken it to the dealership and asked them?
  3. Feb 1, 2013 at 10:54 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech Vendor
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Interestingly enough, the throw-out bearing can make noise either pushed in, or when released. However I know that there has been an issue with the TOB and input shaft housing, and I am sure someone here has the link to the thread that discusses it, as well as the fix.
  4. Feb 1, 2013 at 11:16 AM
    moondeath
    Pa, Carlisle
    I've read quite a few of the topics on here about that issue that your speaking of. It seems that those problems had different noises, more like squeak and chirp sounds. Mine has been doing this whirring whining noise since the day I bought it off the lot. Just thought it was normal. Has about 40k miles now. I'm not saying it isn't a problem with the TOB, it may or may not be. I'm curious if this is a common operating noise with other trucks or if its isolated to mine.
    And no I haven't had it to the dealer for this yet. I wanted to feel around and see if others do this or not. I'm starting to feel like a dealership troll for having it in there to get all the TSBs done.
  5. Feb 1, 2013 at 11:28 AM
    RadTaco914
    RadTaco914 MALLIN'CRAWLIN'
    NEIL
    NORTH CAROLINA
    2017 DCSB TRD O/R "TURD GEN"
    Well mine is an 08' and it had 92k when I bought it from a dealer and mine does the exact same thing as yours. I noticed mine in the drive through one morning. There is defiantly a TOB issue. However, with mine being way over mileage I am just babying mine till I can upgrade it...I would take yours to the dealer just to see what they say..maybe you can squeeze a new clutch outta them :D
  6. Feb 1, 2013 at 11:39 AM
    tinker_troy
    tinker_troy VAN ENTHUSIAST
    WA
    Blue Subaru Thingamagigy
    Mine only does it when it's really cold out. Been like that since I got it.
    I think you should take it in and let them have a listen.
    And don't feel like a troll! You are an informed consumer, nothing wrong with that. If the dealership doesn't like it tell them to complain to toyota, it's not your problem.
  7. Feb 1, 2013 at 11:45 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    sr5 trd 4wd
    my 2009 v6 6-speed was making more of a chirping sound.Throw out bearing was replaced under warranty.The Luk bearings are the problem.
  8. Feb 1, 2013 at 12:06 PM
    moondeath
    Pa, Carlisle
    Mine definitely sounds louder when its cold, but does it all the time. I guess Ill have to take it in again.
  9. Feb 1, 2013 at 10:08 PM
    BamaToy1997
    Bill
    Navarre, FL
    Does it sound like a growling noise, similar to a wheel bearing? If so, you still COULD be looking at a TOB. Remember when your clutch is pressed in, ALL of the force of the pressure plate is being pressed against the bearing.
  10. Feb 1, 2013 at 10:18 PM
    Lipson
    Lipson Well-Known Member
    Adam
    San Diego
    '97 T4R Limited
    Mine's made this noise since I bought my truck. I thought it was a problem so I got the dealership to replace the TOB under warranty. A month after replacement the whirring noise came back, more so when it's cold in the morning. I don't think it's an issue, many people with the manual transmission have this.
  11. Feb 2, 2013 at 8:40 AM
    rustbus
    rustbus Well-Known Member
    western Canada
    2012 TrailTeam Pro - white
    i just took my 2012 in with the same issue, they claim normal operation. pronounced when colder, goes away warmed, but always there.
    for me, best i can recall, i first noticed it after 5000km and the first use of 4wd. thats what made it stand out. now at 17k kms and about the same really.
  12. Feb 2, 2013 at 1:44 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    They all do it it's normal neutral gear rattle there is a lot of stuff turning in neutral. As soon as you push the clutch in every thing stops turning.
  13. Feb 2, 2013 at 3:59 PM
    moondeath
    Pa, Carlisle
    Definitely not a growling noise, literally just a whirring noise.
    Sounds like this is a pretty common sound, which makes me feel better.
  14. Feb 2, 2013 at 4:09 PM
    BamaToy1997
    Bill
    Navarre, FL
    In neutral the input shaft is the only thing turning when the clutch is released.
  15. Feb 2, 2013 at 4:30 PM
    Aerial Tacoma
    Aerial Tacoma Well-Known Member
    Andre
    Kodiak Ak
    2010 TRD Off Road Access Cab
    TRD Cold Air Intake, TRD Catback, Original HomerTaco Raptor Grill, TRD Trail Teams "Black", Duratrac 265/75/16, ALL PRO apex rear bumper, Retrofits W/ BHLM halos and deamon eyes
    X2 but just when it's cold
  16. Feb 2, 2013 at 4:50 PM
    djo991
    djo991 Active Member
    07 Double cab SR5
    Nothing on it .... FOR THE MOMENT
    same thing here , on october 2012 my TOB were replaced , with new transmission fork , the cylinder .. 1200$ job ... after the job the truck as no more sound .. 2 month later .. it started again .. they offer 1 year job warranty .. this summer i go to the dealership and ask them to do the job again but with this bearing , http://www.urdusa.com/p1260519023/T...IT,-2005+-Tacoma-V6-6-Speed/product_info.html
    should fix the problem
  17. Feb 2, 2013 at 5:16 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    i/ve never driven anything that didnt make noise in neutral with clutch out. harder to notice while driving. if these trucks had a neutral option for t-case, you could row through the gears and really hear a racket. i chalk it up to unloaded chatter.
    check your fluid level to be sure, and drive the hell out of it
  18. Feb 2, 2013 at 10:17 PM
    joes06tacoma
    Joe
    Central Coast, CA
    Bought mine with 40K on it and the noise that you describe. In the 25K since, the throwout bearing was replaced due to chirping. The whirring noise in neutral has remained the same. The regional rep who approved the clutch work told me it is normal for the six speed to make audible noise in neutral.
  19. Feb 2, 2013 at 10:46 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    + the countershaft's gears for 1st and 2nd.
    My truck has a little gear noise from the box when spinning in neutral as well. Push the clutch, it goes away. I have the TSB fork and TOB fwiw.
    I've yet to find a manual gearbox that doesn't make that low grrrrrrsh sound in neutral. Even my Fit with its highly-praised incredibly reliable 5 speed did it when I picked it up from the dealer with 7 miles on its odometer. Actually, that one was louder than the Tacoma's. I bet it was built like my old noisy d-series tranny with the 3/4 shift hub on the countershaft and spun those freewheeling gears good and fast. Didn't help that Honda's idea of gear lube was friction-modified 5w20 either.
  20. Feb 3, 2013 at 4:23 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Nope you got 2 counter shafts turning also. Diesel cars/trucks use a dual mass flywheel because the gear rattle is very noticeable with out it due to the high compression. I replaced the DMF in my TDI with a single mass when it when south and if you think the Tacoma is noisy in neutral the VW sounded like a concrete mixer.
