6 speed manual swap
Discussion in '2nd Gen. Tacomas (2005-2015)' started by anthony250f, May 17, 2014.
  1. May 18, 2014 at 11:49 AM
    805tacoma
    805tacoma Member
    Bummer, well good luck on the swap anyway. Truck looks awesome!
  2. May 18, 2014 at 11:55 AM
    BAMFTACO
    BAMFTACO Another day another beer
    Juan
    Woodlandland hills , CA
    2007 Tacoma AC Prerunner
    Kings bruh
    Anthony if your gunna do manual swap just do t56 in that bitch. that would be a solid tranny
  3. May 18, 2014 at 12:00 PM
    BAMFTACO
    Juan
    Kings bruh
  4. Jul 30, 2018 at 7:54 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    I know this is old but anything ever come of this?
  5. Jul 31, 2018 at 2:01 PM
    rheath08
    rheath08 Well-Known Member
    Russell
    Bakersfield, CA
    Frankenstein's Monster
    converted AWD, RC62f swap, Supercharged
    I did the swap with my 4x4 conversion. I did all the labor myself with some help from a friend. You will need the drive shaft modified. The carrier bearing is in a different location.
    The rear cross member will need to me modified or a custom one made. The trans mount is in a different location. If your changing to or from 4wd.
    Just now noticed this is old thread lmao!
    Oreo Cat likes this.
  6. Jul 31, 2018 at 5:25 PM
    Oreo Cat
    How bout electronics? I'm 4x4 and staying that way so imagine it might be easier?
  7. Jul 31, 2018 at 6:36 PM
    rheath08
    Russell
    Bakersfield, CA
    @Oreo Cat yes that will help. for the engine i got a manual 4.0 ecu. the dealer installed and programmed my vin into it. they had to program the immobilizer control unit as well. still use my original key. now the transfer case, you will need a manual transmission transfer case. the input splines are different. auto is 26 splines and the manual is 23 splines. the count might be wrong but they "ARE" different. the electronics should all be the same on both transfer cases.
    hold on a second. what gen is your truck? i see "stock 5 lug" are you a 4cyl?
  8. Jul 31, 2018 at 7:25 PM
    Oreo Cat
    Haha the 5 lug thing is a joke
    Might have even seen it if youre in Bakersfield
    rheath08[QUOTED] likes this.
  9. Jul 31, 2018 at 7:29 PM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    I’ve driven a Tacoma with a T56 swap. It’s amazing.
    rheath08 likes this.
  10. Jul 31, 2018 at 8:43 PM
    rheath08
    Russell
    Bakersfield, CA
    too bad its only a 2wd option
