6 speed manual, What gear do you use at what speed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shaneh39, Oct 6, 2010.
  1. Oct 6, 2010 at 10:41 PM
    shaneh39
    shaneh39 [OP] Member
    Washington
    07 4x4 sr5 black
    Just purchased. Stock with ARE canopy
    I recently upgraded from an 2001 5 speed v6 to a 2007 v6 6 speed. I have never had a 6 speed and was wondering how you drive your manual? Not really sure what gear I should be cruising in for the best MPG. I have noticed I rarely use the 5th gear unless accelerating. Heres what I have been doing in general.
    25-30mph 3rd
    35-45mph 4th
    50-70+ mph 6th gear
    assuming no hills
    This about normal? Just so used to cruising in fifth it feels so odd not to use it much at all.
  2. Oct 7, 2010 at 4:11 AM
    Brunes
    Brunes abides.
    Rotorhead
    What the number of the gear is doesn't really matter-As long as the engine isn't screaming or luggin out you are probabyl pretty close to good. I cruise about 2200-2500 RPM most places. A little higher on the freeway.
  3. Oct 7, 2010 at 4:21 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    this is rocket science
  4. Oct 7, 2010 at 4:22 AM
    Priddle
    Priddle And now for something completely different....
    St. John's, NL Canada
    2014 Tacoma 4x4 TRD Sport DCSB
    Current: Pelfreybilt front and rear bumpers, winch, icon front coils/shocks, Icon rear shocks, Dakar leafs, Camberg UCAs, Pumpkin Android stereo, custom sub box w/ 2x10" RF subs and Kicker amp, short shifter kit, Fuel Beast 18" wheels w/ 1mm offset, BFG AT2 285/65/18
    I try to keep it under 2000rpm, ideally at 1500rpm when just keeping a steady speed and its not straining the engine.
  5. Oct 7, 2010 at 4:29 AM
    jester156
    jester156 Well-Known Member
    Cumberland, RI
    08 V6 4x4 DC TRD, 6spd
    TRD Supercharger, TRD CAI, Sirius, Rear TSB, Front 5100 with Eibach coils, 1.5" AAL, URD short throw, fog light mod, weather tech liners,
    pretty much same here.
    although i rarely use 3rd. 1, 2, 4. I do a lot of rural driving so speed is always low, HW is always 6th.
  6. Oct 7, 2010 at 4:53 AM
    Simms65
    Simms65 Well-Known Member
    David
    WV
    '16 Quicksand O/R M/T
    I'm not 100% sure about the mph right now, but I try to keep the RPMs as low as possible, shifting under 2k unless I need to accelerate quickly. If I'm cruising at ~35mph or higher and don't have to climb hills I'm always in 6th.
  7. Oct 7, 2010 at 4:58 AM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I'm hard core....everywhere I go I use 6th
  8. May 8, 2011 at 11:49 PM
    Nucks4TheCup
    Nucks4TheCup Member
    I've only started driving manual last year. Why do you skip 3rd gear? WHen I test drove the 6 speed 1st gear seemed pretty useless as well.
    Do you save gas driving in 6th when possible?
  9. May 9, 2011 at 9:33 AM
    Simms65
    David
    WV
    Lower RPMs = lower fuel usage provided you are light on the skinny pedal.
  10. May 9, 2011 at 9:34 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    mpg is a function of engine load and throttle, not necessarily RPMs
  11. May 9, 2011 at 1:17 PM
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I shift mostly by feel. If the engine feels like it's lugging or reving too high, I'll switch. The user's manual gives recommended shift points for the best fuel efficiency.
  12. May 9, 2011 at 1:23 PM
    Evil Monkey
    Robert
    Escondido, CA
    I usually skip gears as well (mostly 4th to 6th). I skip because the speed I'm at is usually sufficient to warrant it. I tend to rev higher to get up to speed quicker, taking advantage of the engine's higher torque at higher rpms (torque peak is about 4200 rpms). It doesn't hurt anything.
    1st gear is pretty tall. It's useful when towing or slow offroading. Larger tires makes it a little more useful for day to day.
  13. May 9, 2011 at 1:45 PM
    ne0tas
    ne0tas Well-Known Member
    Erick Iglesias
    Duarte, California
    None. :[
    This.
  14. May 9, 2011 at 1:47 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    EXACTLY!! I wish more people would understand this!
    You could be going 25mph in 6th gear with your foot to the floor using WAY more gas than if you were rolling through a parking lot in 1st gear at 4k rpm
    Toy916 likes this.
  15. May 9, 2011 at 5:20 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Toyota says 127 MPH in 5th haven't tried it yet.
  16. May 10, 2011 at 5:32 AM
    kb1jop
    kb1jop Well-Known Member
    Rick
    Springfield, MA
    2010 Barcelona Red 4WD DCSB 6-Speed SR5
    Factory Towing Package Factory Roof Rack OEM Bed Mat Trifecta Tri-Fold Tonneau SeatSaver Custom-Fit Seatcovers WeatherTech Custom-Fit Floor Mats Block Heater: http://www.metrotpn.com/ProductDetails.aspx?CollectionID=13&ProductID=191&SortIndex=9
    Start in 1st [obviously,] then @ 20 mph for 2nd, 30 for 3rd, etc. Every 10 mph matches the gear# @ 2000 rpm. Just remember:
    2 for 20
    3 for 30
    4 for 40
    5 for 50
    6 for 60
    this is also an easy way to tell what gear you're in just by looking at the tach and speed, in case you forget. :confused:
  17. May 10, 2011 at 5:58 AM
    TacoCat
    TacoCat These pretzels are making me thirsty
    Johnny-5
    Chantilly, VA
    18 wrx limited 6MT
    x2 on this. 5th and 6th are so close it doesn't make sense most times for me to use 5th.
  18. May 10, 2011 at 7:37 AM
    novanut21
    novanut21 Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, GrillCraft Grill, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley.
    I've heard 100 is possible in 3rd:cool:
  19. May 10, 2011 at 9:16 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I disagree...can you back this up?
  20. May 10, 2011 at 9:33 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    Although your RPMs are higher in first gear, you arent actually using more fuel than if you are applying more throttle in 6th gear to maintain the same speed. Lets say you are going 20 mph in first gear, high RPMs, but only using 30% throttle, you will be using less gas than if you were in 6th gear, at 1000 RPM, using 98% throttle. Think of it as using MORE fuel to go the SAME speed, thus, LESS MPGs
    EDIT: I used to follow the low RPM = saves gas movement, however, what I have found to work best is choose the gear which allows you to use as LITTLE of the skinny pedal as you can. That means being in second gear to go up a hill rather than being in 4th, just so that skinny pedal doesnt have to hit the floor.
