6 speed manual, What gear do you use at what speed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shaneh39, Oct 6, 2010.
  1. May 10, 2011 at 9:36 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Although Ive never really tested this, I have always been told that low rpm's burn less fuel regardless of load. Im going to test this in a couple hours...
  2. May 10, 2011 at 9:40 AM
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I'm with Chris....your injectors don't just dump fuel into the cylinders based on the pedal position.
    I don't think you 'experts' have this figured out like you think you do.
  3. May 10, 2011 at 9:40 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    it is all relative to throttle because lets say you are at 4000 RPM, but foot completely off the throttle, you are not burning any fuel. What really confirmed this for me is my scangauge because I always display engine load and throttle position sensor. With engine load as low as possible (I try to keep it below 60) and TPS as low as possible, I get the absolute best MPGs, and that includes being in low gear at given situations, such as going up a hill on the freeway: I down shift 4th, keep that engine load and TPS down, and I still maintain 16+ MPG
  4. May 10, 2011 at 9:42 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    tell me where I said I was an expert. I have been using a scangauge for 2+ years, and I have found what works for me :notsure: maybe try doing some tests for yourself?
  5. May 10, 2011 at 9:43 AM
    808matt
    808matt Well-Known Member
    hawaii
    15 crew cab
    alot of the time i'm in 6th gear by 30 mph but thats when i'm on flat/downhill sloping roads and in no need of gasing it at all
  6. May 10, 2011 at 9:44 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    how were you gauging how much gas you were burning?
  7. May 10, 2011 at 9:47 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    then your scangauge and mine are birds of a different feather. I reset current trip every time i go grapevine and I get 18 MPG, with LT, doing my style of shifting. And that is confirmed at the chevron pump by in-n-out after grapevine going north.
  8. May 10, 2011 at 9:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The last mpg test I did going up to the mountains (6% grade) showed 13.4 mpg in 5th, ans 10.8 in 4th, at 70 mph. I did this a couple times, and the results were the same all the time. Lower gear gave less mpg. Im going to try it on some flat ground here in a bit.
  9. May 10, 2011 at 9:51 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    FWIW, Even though you may be useing more skinny peddle in a taller gear, the throttle being open more increases the efficency of the engine, as pumping forces are reduced, as opposed to a lower gear, with the throttle partially open. The single biggest restriction in an engine is the throttle butterfly.
  10. May 10, 2011 at 9:51 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    You were probably at a good engine load at the hill. next time at that hill, look at engine load. If you are below 95, then you are still good, if you are about 95, inching towards 100, then down shift so you are around 80, which will improve mpg.
    At the hills around Socal, I'd be in 6th, maintaining 70mph, and hit a hill, and watch engine load creep up to 98 load, giving me 8 mpg. downshifting to 4th, getting me back at around 85 engine load, puts me back at 15+ mpg
  11. May 10, 2011 at 9:54 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The automatic downshifts when Im at 85% engine load. Even holding at 84% in 5th gear (with my boat hitched up), I see better mpg than when dropping down to 4th.
  12. May 10, 2011 at 9:59 AM
    blackhawke88
    SGV, CA
    07 TRD Offroad
    that is pretty interesting. there maybe other factors in my case, since I have a URD MAF and headers, I guess a different A/F map could make my case different. Next time I go back home for an extended period of time, i'll do some tests with my WRX, although and F/I vehicle is also a completely different creature
  13. May 10, 2011 at 10:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    The MAF calibrator screws with the AF signal, so that could be the reason there is a difference. Comparing an FI to non FI engine is 2 different animals. If under boost, more fuel will be burned.
  14. May 10, 2011 at 10:01 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Off to go do some tests now. Back to post findings in a while.
  15. May 10, 2011 at 10:12 AM
    #35
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Highest possible manifold vacuum in any gear = highest mileage. Does not apply to a diesel.
  16. May 10, 2011 at 10:49 AM
    #36
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Regardless of the MPG wouldn't you want to downshift to keep the engine load lower as to not wear out your engine prematurely?
  17. May 10, 2011 at 12:41 PM
    #37
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    As long as the engine is operating within perameters, and oil pressure is good, increased wear isnt an issue.
    Anyway, Im back and found that in every gear, at speeds from 30 mph, up to 70 mph, the taller gear yields the better mpg. And example....Second gear at 30 mph was about 21 mpg. and the MAF was getting 21 to 23 gps air flow. At the same spped in 4th, mpg went to 31, and the MAF was flowing 17 gps. the biggest difference was at 43 mph, where in 5th, I was getting between 35 and 38 mpg, and in 4th it dropped to 22. At 70 mph, 5th gear was getting 22, and 4th was at 19. Not a big difference, but I was also being hit with a 30 to 35 mph headwind.
  18. May 10, 2011 at 1:06 PM
    #38
    Drunknsloth
    Retribution
    South West
    So is there a minimum RPM or other factor that you should always stay above to keep within the parameters?
  19. May 10, 2011 at 1:07 PM
    #39
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    I use my 6-th Gear at 215km/h :cool:
  20. May 10, 2011 at 1:12 PM
    #40
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I would say above idle....
