6 speed manual, What gear do you use at what speed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shaneh39, Oct 6, 2010.
  1. May 10, 2011 at 1:21 PM
    #41
    Drunknsloth
    Drunknsloth Indffrnce will be the fall of manknd but who cares
    Retribution
    South West
    08 SR5 Access V6 6-Speed
    Blacked-Out Badges; Retribution Decals (Sockmonkey); Tailgate Mod; Red LED Rear Blinkers; Yellow Foglights; Yellow Front Blinkers; Superwhite Xenon Corner Bulb; Leer Bedcap; Bedrug Bedmat; Black Cupholders; Black Plastic Piece Around Window Controls; Plasti-Dip Front Bumper Valence; Plasti-Dip Grill Surround; Blackout Chrome Back Bumper; Metal Miller Skid-Plate; Aero Turbine 2525 Muffler; TSB Rear Leaf Springs and Shocks; Satoshi Grill Pending; Off-Roading Torn off Mirror (Replaced); Blue-Sea Fuse Box; Tinted Tail Lights; URD Short Shifter; Interior Mood Lighting; Hood Lights; BedLights Pending
    Cool, any other tips besides RPM range to keep the engine at peak performance?
  2. May 10, 2011 at 1:26 PM
    #42
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    Found this article linked from a MPG forum:
    http://www.autospeed.com/cms/A_110216/article.html
    According to tests, the red zone gives you best MPG
    The diagrams are based on a sample of 1995 model year, naturally aspirated, EFI 2-valve engines.
    Quoted from conclusion of article:
    So I guess low rpm, high engine loads gives you more MPG?
  3. May 10, 2011 at 1:28 PM
    #43
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    wow, never seen a chart on it before
  4. May 10, 2011 at 1:29 PM
    #44
    blackhawke88
    SGV, CA
    07 TRD Offroad
    yea, i mean, who even does these tests? oh, and those black dots represent the engine load range EPA tests for MPGs at :laugh:
  5. May 10, 2011 at 1:31 PM
    #45
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Engine Load = Speed??
  6. May 10, 2011 at 1:33 PM
    #46
    blackhawke88
    SGV, CA
    07 TRD Offroad
    no, engine load = The definition of BMEP is: the average (mean) pressure which, if imposed on the pistons uniformly from the top to the bottom of each power stroke, would produce the measured (brake) power output.
  7. May 10, 2011 at 1:35 PM
    #47
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Yo just pushed me in the Opposite direction of understanding...
    Whats this have anything to do with brakes?
  8. May 10, 2011 at 1:37 PM
    #48
    blackhawke88
    SGV, CA
    07 TRD Offroad
    lol, it has nothing to do with brakes, brake, in this case, means brake horsepower, and the mileage is being calculated as BSFC:
    Brake Specific Fuel Consumption
    So what’s Brake Specific Fuel Consumption? As with bhp (brake horsepower), this refers to the specific fuel consumption when the power is measured by an external brake – in other words, a dyno. Most times, 'brake specific fuel consumption' and 'specific fuel consumption' are the same thing.
  9. May 10, 2011 at 1:38 PM
    #49
    thinkingman
    thinkingman Well-Known Member
    redmond WA
    2006 dbl cab 4wd 6sp
    Foglights are for fog, not oncoming traffic!
    I was referring to Macgyver...Wide throttle openings and lower revs are always going to provide better economy....A car mag did a mileage test on a BMW 325e (anyone here old enough to remember the 'eta' engines?) conclusion was short shifting and big throttle was much better for economy.
    These are torque engines.
    Rumbly, low-rev power is what they do.
    Sure wish 6th gear was about 15% longer.
  10. May 10, 2011 at 1:40 PM
    #50
    blackhawke88
    SGV, CA
    07 TRD Offroad
    so the absolute best mpgs are obtained with throttle wide open in the highest gear? basically if im going 5 mph in the parking lot, i should be pedal to the metal in 3rd gear?
  11. May 10, 2011 at 1:42 PM
    #51
    Drunknsloth
    Retribution
    South West
    Could be true, but my truck would be shuddering so much that I would think that it would implode.... :confused:
  12. May 10, 2011 at 1:43 PM
    #52
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    makes sense i guess
  13. May 10, 2011 at 1:53 PM
    #53
    blackhawke88
    SGV, CA
    07 TRD Offroad
    oops, already found a counter-argument for BSFC:
    http://www.cargather.com/engineering/technical-01435.html
  14. May 10, 2011 at 1:55 PM
    #54
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Ofcourse not. Best mpg under a load is achived in a taller gear, with more throttle. Obviously, the BEST mpg is going to be given with the least amount of work the engine has to perform to move the vehicle. For example, I can get 35+ mpg at 43 mph, but thats not practical on the freeway, and you cant maintain that speed on city streets.
  15. May 10, 2011 at 1:56 PM
    #55
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Well... Technically... You could....
  16. May 10, 2011 at 1:57 PM
    #56
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Depending on red lights, and impacts resulting from running them, then sure....
  17. May 10, 2011 at 1:58 PM
    #57
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Get Lost in a Traffic Circle?? :D
  18. May 10, 2011 at 1:59 PM
    #58
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    We dont have those here.
  19. May 10, 2011 at 1:59 PM
    #59
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    They make life so easy, rarely ever have back ups
  20. May 10, 2011 at 1:59 PM
    #60
    blackhawke88
    SGV, CA
    07 TRD Offroad
    so wide open throttle at the tallest gear, while maintaining the same speed, = best mpgs?
