6 speed manual, What gear do you use at what speed?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by shaneh39, Oct 6, 2010.
  1. May 10, 2011 at 2:01 PM
    #61
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If under a load, yes. If just criusing on the freeway, unloaded, then things change.
  2. May 10, 2011 at 2:38 PM
    #62
    BrokenTusk
    BrokenTusk I support a velociraptor free workplace.
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Check Build Thread!!
    Wind force on the vehicle increased exponentially as you increase in speed
  3. May 10, 2011 at 3:13 PM
    #63
    Evil Monkey
    Evil Monkey There's an evil monkey in my truck
    Robert
    Escondido, CA
    07 4x4 DC SR5 TRD Off-road
    Weathertech front & rear mats, rear suspension TSB, Toytec AAL for TSB, Hi-Lift Jack, Bilstein 5100 & Toytec Adjustable coilovers, Built Right UCAs, KMC XD 795 Hoss Wheels, Definity Dakota MTs 285/75R16, Leer XR, Thule Tracker II & Thule MOAB basket
    I think instantaneously, you would be using less fuel. But because your engine isn't working very efficiently, you'll use more over the long run if you're trying to accelerate.
    So say you're rolling along at 20 mph. If you were in 3rd and punched it, you'd quickly get up to speed to shift into the more efficient gearing (e.g. 6th). In 3rd, you'd be closer to the torque peak which is the most efficient fuel/power ratio. The instantaneous mpg would be lower than if you were in 6th at 20mph, but it's going to take much longer to get up to a more efficient speed since the engine is bogged down.
  4. May 10, 2011 at 3:15 PM
    #64
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    You! Evil Monkey! I Require some of your merchant wares
  5. May 10, 2011 at 3:44 PM
    #65
    Evil Monkey
    Robert
    Escondido, CA
    :confused: Que?
  6. May 10, 2011 at 4:03 PM
    #66
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Zombie Stickers
  7. May 10, 2011 at 4:08 PM
    #67
    Evil Monkey
    Robert
    Escondido, CA
    :confused: Que? I think you have wrong monkey. Sockmonkey is probably who you're looking for.
  8. May 10, 2011 at 4:10 PM
    #68
    BrokenTusk
    Marcelasaurus
    AB, Canada
    The Scarlett Whore
    Sigh... I always grab the wrong monkey
  9. May 13, 2011 at 8:43 AM
    #69
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Interesting....You learn something new every day.
  10. Sep 9, 2011 at 4:21 PM
    #70
    Wally
    Wally Well-Known Member
    Ontario (the metric version)
    07 Access Cab TRD 4x4 6MT 1GR-FE
    The recommended shift points are listed in your manual ... I started using them as an experiment and they were a little different than what I was picking naturally by "feel".
    The recommended shift points are around 2200/2200/2100/2000/1900 RPM I think but I'm guessing a little, I don't feel like going outside and looking them up. So in general shift low in the RPM range and let the low end torque accelerate you instead of revs and each shift happens a little lower than the previous one. It also seems to match up with the chart that was previously listed for fuel consumption.
    Bottom line is to ignore trying to keep up with automatics off of the line, everyone that drives one seems to bury the throttle while the natural pace of these trucks is to build speed a little more slowly.
  11. Sep 10, 2011 at 2:01 AM
    #71
    Wallygater
    Wallygater Well-Known Member
    USA
    '11 SR5 DBL Cab 4x4 6 speed
    Softopper, All-pro bolt-on sliders, Tom Wood's drive shaft, Goodyear 235/85/16 Dura-trac's, SG, USA-Spec I-pod adaptor, Amsoil in everything
    I don't even look at the tach while I'm driving unless I'm hammering it. I shift in normal driving according to feel. I shift when I want to. The true beauty of a manual trans. Control.:cool:
  12. Sep 10, 2011 at 2:25 AM
    #72
    Manwithoutaplan
    ID
    exactly.
  13. Sep 10, 2011 at 6:57 AM
    #73
    skiracer0112
    skiracer0112 Well-Known Member
    Bryan
    Breckenridge, CO
    '11 Silver Double Cab 6-speed TRD OR
    They do work really well when people who know how to use them are driving. But when they are installed in a tourist area where most people visiting have never seen one they cause huge backups.
  14. Aug 7, 2013 at 12:07 PM
    #74
    Smardt Turbocor
    Smardt Turbocor Older Guy
    Galen
    Lexington South Carolina
    Tacoma 1/2 cab 4.6 Liter V-6 5 speed manual
    I don't buy that last statement. It's all about engine and load and gear relationship. The issue is: What is the least rpm we can have doing the work that needs to be done without overloading the engine ? First gear at 4K IS consuming A LOT of fuel. Not exactly my permanent parking lot gear,
  15. Aug 7, 2013 at 12:25 PM
    #75
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    lol did you read the whole discussion? a lot has been covered since that statement was made
  16. Aug 7, 2013 at 12:29 PM
    #76
    savedone
    savedone Well-Known Member
    Gerald
    Texas
    TRD off-road 6speed manual
    3 inch lift by dealer at purchase
    6 gear for 35mph and above as long as it is not being lugged.
  17. Aug 7, 2013 at 12:40 PM
    #77
    Chipskip
    Chipskip N7MCS
    Chip
    Green Ridge, MO
    07 Tundra
  18. Aug 7, 2013 at 1:28 PM
    #78
    yotaman90
    yotaman90 bröther may I have some lööps
    Taos, NM
    2012 TRD Offroad
    I usually shift my truck......
    1st to 2nd at 10
    2nd to 3rd at 20
    3rd to 4th at 30
    4th to 5th at 35
    and 5th to 6th at 40
