60,000 mile maintenance
Discussion in 'New Members' started by Tacv605, Apr 25, 2013.
  1. Apr 25, 2013 at 6:17 AM
    Tacv605
    Tacv605 [OP] New Member
    Seattle
    2005 Tac PreRunner V6 4x2
    Could I get the recommended 60,000 mile maintenance work done somewhere else than the dealer, for a 2005 Tacoma V6? they're asking $500. :cool:
  2. Apr 25, 2013 at 6:22 AM
    Manwithoutaplan
    ID
    Yea, try another shop for sure it is all basic maintenance. Or you could do yourself it will be like 200 bucks for all the parts.
  3. Apr 25, 2013 at 6:24 AM
    Large
    Large Red
    DIY..
    Mobil 1 syn Oil & OEM filter
    Front, rear Diff & T-case Mobil 1 75W90
    New spark plugs, there is a heavy debate but NGK are fine with a .038 - .043 gap (someone correct me if I am wrong)
    New in cabin filter, check engine filter.. replace if necessary.
    Trans flush - optional?
    Coolant flush (I would personally do it at 60k intervals)
    rotate tires, check psi in all 4
    lube everything with a zerk, drive shaft, UCAs (aftermarket), LCAs (also aftermarket)
    maybe forgetting something, but I also do it in an excel spreadsheet so I don't forget .. lol
  4. Apr 25, 2013 at 6:26 AM
    Manwithoutaplan
    ID
    Sounds about right.
  5. Apr 25, 2013 at 6:33 AM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    Flush trans every 30k
    Coolant flush is at 100k
    Check spare tire pressure
    Check front end for play
  6. Apr 25, 2013 at 6:38 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    $500 and you have a Prerunner?!?! Damn, those stealerships have no soul!
    For a 4x4, you'll spend $100 just in oils to do the front, rear and transfer case fluid changes but with a pre-runner, you only have to do the rear end ($30 for high quality gear oil). The only other things you'd need to do is spark plugs (about $40 for parts), engine oil and filter ($30-40 depending on which oil you like), tire rotation (DIY free), air filter ($20) and cabin air filter ($10). So about $150 in parts if you do it all yourself.
  7. Apr 26, 2013 at 5:01 AM
    Tacv605
    Seattle
    Thank you all for the feedback
