$60 Ebay Shock hoop
Discussion in 'Long Travel Suspension' started by 87xjmike, Dec 16, 2011.
  1. Dec 16, 2011 at 11:09 AM
    87xjmike
    87xjmike [OP] Well-Known Member
    Folsom
    98 5lug 2rz
    downey mid travel 2wd set up
    In an effort to not spend 250 on a hoop i think i'm going to go with one of these for the rear outer frame rail/ inn fender well and gusset it where necessary so i don't have to cut up the bed to use my 12" billy's. Has anybody tried any of these? If so how'd it fit? I'm trying to utilize all my bed space to carry 2 dirt bikes and gear.
    http://compare.ebay.com/like/260177794710?var=lv&ltyp=AllFixedPriceItemTypes&var=sbar
    or maybe trail gears would be better...they look the same though
    http://www.trail-gear.com/shock-hoops
    i like that this one comes with hardware...
    http://www.datinfab.com/shockhoops-1.aspx
  2. Dec 16, 2011 at 1:48 PM
    jtlachac08
    jtlachac08 Well-Known Member
    Jeremy
    Phoenix, Az
    There's nothing wrong with running shock hoops, provided they are stong enough and gusseted well.
    I'm interested to see how these would turng out. Pretty inexpensive, give it a shot
    Post your progress
  3. Dec 16, 2011 at 1:56 PM
    87xjmike
    Folsom
    98 5lug 2rz
    Yeah i was just hoping someone here had tried one and could attest for fitment issues on a first gen. I have a god damn pile o shit 3" body lift on mine so i'll have less fitment issues than others.
  4. Dec 16, 2011 at 2:01 PM
    jtlachac08
    Jeremy
    Phoenix, Az
    It all depends on your set up and what your looking to achive....
    Good luck and have fun
  5. Dec 16, 2011 at 4:42 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Have you taken a good look at your rear wheel wells?
    I'm not saying it's not possible, but there's not a lot room in there.
    I have shiney spots on the inside of my fender wells where my tires rub at full flex (or full compresssion before I put wheel spacers).
    Lack of room:
    I think you'd be better off doing something similar to what JLee did to his. He added a new crossmember and triangulated his shocks. I still don't think you'll get anywhere near using the 12" shock (mostly due to lack of uptravel). Jerry's got 10's with an allpro +4.5" rear lift and I'm not sure he's using all of his shock.
  6. Dec 16, 2011 at 4:52 PM
    MadTaco461
    MadTaco461 BRO runner
    CA
    99 turbo 5 lug long travel
    Kinda stock
    you can do a full on bedcage and make it bolt on. Unbolt it and slam the stock shocks in and throw the dirtbikes in the back. My buddy did this to his 2nd gen and works great. It's a weekend project.
    edit: put a rubber mat over the bed to cover up the shock holes.
  7. Dec 19, 2011 at 10:24 AM
    87xjmike
    Folsom
    98 5lug 2rz
    Yeah i have very few scrub marks. I'm staying with a 31" tire so with a wheel spacer i should be good.
  8. Dec 19, 2011 at 10:46 AM
    xtyharvey
    xtyharvey Active Member
    Boulder City, NV
    03 PreRunner SR5 DC
    Camburg LT Kit w/Fox 2.5 Coil-overs, Glassworks Unlimited Front Fenders, 33' BFG All Terrains, Flowmaster Exhaust System, AFE Intake, Deaver F55 Leaf-springs w/ Fox 2.0 Remote Reservoirs
    I made my own and they've held up through many many offroad miles.
    12TRDTacoma likes this.
  9. Dec 19, 2011 at 11:15 AM
    87xjmike
    Folsom
    98 5lug 2rz
    nice, that looks really good. Did you do a bolt in crossbrace? Are those 12" shocks? It looks like you added a sleeve to the axle to get the shock bracket in the proper location down there.
  10. Dec 19, 2011 at 11:32 AM
    ColesDirtyYota
    ColesDirtyYota Well-Known Member
    Cole
    San Diego
    Dezert Built
    Camburg LT Icon 2.5" x 9" coilovers Radflo 2.0" Bumpstops Radflo 2.5" x 16" tripple- Bypasses Deaver F67 Race Pack Richer Racing 12" shackles Full bedcage Full 2" cab cage Tube bumper Solid motor mounts Total Chaos spindle Gussets RR gusseted UCA mounts Total Chaos poly urethane Steering kit T100 axle 4:88's/ Locker AFE dry air intake BA Muffler Trimmed the Throttle Body Fiberwerx 05+ clip Fiberwerx 8" bedsides Full JL speakers/ deck/ sub Rigid Industry 30" LED bar ORW LED amber lights/ brake lights Kenwood Race Radio HF jack with custom skid plat
    ur wheels have a low backspacing? if so u might not need a spacer and that would be ideal, but if not def run a spacer or ull prob rub and end up fucking your tires up and ect. but shock hoops are alot stronger then a bucket and ect, so as long as it's put in correctly your good to go
  11. Jan 18, 2012 at 7:47 AM
    TacoMX
    TacoMX TW's Official anti body-lift pundit
    Jonathan
    Deltona, Florida
    I would get the datin fab ones; the biggest reason that they are made in the USA. Trail gear outsources almost all their fabrication.
    Fuck TG
    Support a company that manufactures in the USA!
    Ready for: :crapstorm:
