60k mile Timing belt replacement?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Styx586, May 11, 2012.
  1. May 15, 2012 at 11:55 AM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Interesting.
  2. May 15, 2012 at 11:58 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Being that your truck is 11 years old it might be a good idea to change the timing belt, water pump, thermostat and idler pulley. $600 is the average price for having it done at the dealer, check other local shops for cheaper prices. Usually do this at 90,000 miles but you have to consider the age of the belt. It is always cheaper to do the work yourself.
  3. May 15, 2012 at 11:59 AM
    boshak
    boshak Well-Known Member
    AG
    CA
    2003 Manual 4x4 5VZ-FE
    Very
  4. May 15, 2012 at 3:22 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    All the maintenance guides are on the Toyota web site. For example 2002: http://www.toyota.com/t3Portal/document/omms/MSTOY02_MS0003/xhtml/MSTOY02_MS0003f.html?locale=en
    At 60k there is indeed a requirement to inspect valve clearance, but it's aural-only. "Inspect for excessive lifter noise and engine vibration and adjust if necessary." Unless the valves "sound loud", there's no need to open up the cam cover and insert feeler gauges.
  5. May 15, 2012 at 3:35 PM
    boshak
    AG
    CA
    Nice find and clarification. I saw inspect and went straight to FSM for inspection notes.
  6. May 16, 2012 at 8:18 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    Recently had the valves checked on mine. 243k and probably never been done. Heard some slight valve ticking so took it in as I did not want to muck with it. Replaced two shims on one side and that was it. Fairly costly to have done. Think I ended up around $450-500 after everything, but did a job I did not want to do myself. Also got me new valve cover gaskets that it needed as I had a slight leak on the ones on the truck so saved me that job and also got me new intake gaskets.
  7. May 16, 2012 at 3:40 PM
    KenLyns
    Belly of the Beast
    ^Wonder what functional harm would result if you simply left it unadjusted. 2nd gen's 1GR-FE doesn't have shims, so some engines have ticking since new.
  8. May 16, 2012 at 3:42 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
    Interfernce wise yes, however the broken belt slapping around inside can cause damage
  9. May 16, 2012 at 4:28 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    For me i have always changed my timing belt at 60k period. AS for valves unless they are loud dont touch them.
  10. May 16, 2012 at 6:08 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Doubt it would ever be a problem on a Tacoma engine, but on motorcycles, what happens is the clearances tighten up over time.
    This results in the valve train getting very quiet.
    They tighten because of the valve seat and the valve wearing, allowing the valve to recede into the head.
    Eventually, all gap will be eliminated, or the gap will fall below the cam bearing clearance specs, which ultimately results in the valve not fully seating.
    Two problems:
    1 - Compression loss from the poorly seated valve
    2 - Contact area loss with the head prevents adequate heat-sinking, and the (typically exhaust) valves burn.
