60k Service interval
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MAXTacoma, Feb 8, 2010.
  1. Feb 8, 2010 at 8:04 AM
    MAXTacoma
    MAXTacoma [OP] Well-Known Member
    Lexus GS 350
    Ok my truck has 62k on it and the only thing that I have ever done was change the oil, have the rear brakes adjusted, change the air filter, and put new tires on it. I'm getting a really nice tax return back and was planning on having the transmission fluid changed and maybe the front and rear diff oil, and the spark plugs. Would you agree with having this stuff done. I do alot of towing. I'm going to have this truck for atleast 10-15 years. Suggestions???
  2. Feb 8, 2010 at 8:19 AM
    Packguy2
    Packguy2 Well-Known Member
    Holly Springs, NC
    06 Prerunner DC LB Sport
    I'm in the same boat, except I changed the rear diff fluid already.
  3. Feb 8, 2010 at 8:20 AM
    saf023
    saf023 Well-Known Member
    East Coast
    2nd Gen TRD Sport DCSB 4X4
    I would think hard about having your brake fluid and cooling system changed as well.
  4. Feb 8, 2010 at 8:20 AM
    MAXTacoma
    Lexus GS 350
    Yeah I think I'm going to get the trans. fluid changed but not really to sure about the spark plugs and just wondering if there is something that I'm missing...
  5. Feb 8, 2010 at 8:21 AM
    MAXTacoma
    Lexus GS 350
    Really??? At 60k???
  6. Feb 8, 2010 at 10:50 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    If you have the V6 your plugs should have been changed AGES ago.
    Look in your owners manual or toyota.com for the service information pertaining to your truck. Start around the 30K mileage interval and work your way up to see what has been missed.
    There is a bunch of stuff that should have/needs to be done with your truck. Reference the Toyota service intervals to ensure you don't miss anything.
  7. Feb 8, 2010 at 6:08 PM
    MAXTacoma
    Lexus GS 350
    I know what my manual says but how much and what really needs to be done. I mean there is alot of stuff in there that I think they include to just make more money.
  8. Feb 8, 2010 at 6:20 PM
    Fortech
    CANADA
    You could do it all yourself for around $100 or a little more. If $100 is going to break the bank you should have bought a Yaris...
  9. Feb 8, 2010 at 6:26 PM
    MAXTacoma
    Lexus GS 350
    Well I know how to change oil, air filter, but thats about it. I'm a perfectionist and if i mess something up it usually ends up costing me more than if i just paid someone to do it. therefore I just plan on taking it to the dealership and lett them do it but dont want to pay them to do a bunch of stuff that really doesn't need to be done.
  10. Feb 8, 2010 at 6:31 PM
    stinky_truck
    stinky_truck Well-Known Member
    ryan
    i=13 miles currently @ 75,500 miles
    Plane Jane:4x4,6 speed, shortest bed,URD3SC
    front baja bbq hoop bumper and rear allpro bumper, URD SCIII,urd short throw & stg IIIclutch combo kit w/throwout, DDM Hid 4000k, icon frt (coil overs)& rear shocks (piggy back rez)& add a leaf.
    i have an 08 DC manual 4x4. currently at 73k
    i work construction on the road. (alot of highway mileage).
    here's what i do.
    oil n oil filter change every 3k and oil additive (Restore 6cylinder)
    air filter every 5k, unless have cold air then clean it usually every 7k
    tire rotation every 5k
    transmission 75W-90 gotz to be every 10k!!!! especially if ur hauling tonz of shit!
    same with the rear diff (if have LSD:make sure you add Diff additive).
    transfer case and frt diff ur good to go about 30k depending on weather conditions and ur off road adventures.
    Lucas fuel injection cleaner every 40k
    change out coolant red, brake fluid, power steering fluid annually.
  11. Feb 8, 2010 at 6:33 PM
    MAXTacoma
    Lexus GS 350
    Spark plugs??
  12. Feb 8, 2010 at 6:37 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    13 TRD OR DC MGM
    Stock for now
  13. Feb 8, 2010 at 6:41 PM
    MAXTacoma
    Lexus GS 350
    could you tell an improvement in performance/mpg when you changed your plugs?
  14. Feb 8, 2010 at 6:41 PM
    stinky_truck
    ryan
    my mechanic buddies tell me 70k on spark plugs should be good. i'm at 73k still running strong with spark plugs. that was next on my list to do for maintenance(spark plugs), but my truck has been in an accident. go with some irridium sparks. i know maintenance is expensive but worth it in the long run if tryna go 15 years!
    if you havent done it already get ur emergency rear brakes tighten a few clicks and the rear drum air compressed out.
    i do all my own maintenace, except coolant flushes, brake, power steering fluid changes.
  15. Feb 8, 2010 at 6:43 PM
    stinky_truck
    ryan
    make good friends with mechanics to use their shop. u could learn alot! bribe dem with beer. Ko' Bier!
  16. Feb 8, 2010 at 6:45 PM
    MAXTacoma
    Lexus GS 350
    Ok so I'm thinking that is going to be trans fluid, rear diff fluid, and spark plugs. I dont use 4x4 that much so the transfer case and front diff fluid will just have to wait till another time.
  17. Feb 8, 2010 at 6:52 PM
    stinky_truck
    ryan
    one more thing. sorry to be annoying. by urself a grease gun. and plug it into the grease fittings in the CV joints connected to the frt and rear shafts. pump until you see fresh grease. do this with every oil change.
    i use mobil 1 75W-90 fluid for transmission, frt rear diff and tranfer. mobil 1 oil for engine. the transmission fluid change will be the most difficult but can be done with out paying shops. if ur rich buy some of dat royal purple. it takes about 8 quarts to take care of the transmission , transfer case and the frt and rear diffs.
  18. Feb 8, 2010 at 7:02 PM
    MAXTacoma
    Lexus GS 350
    Ok thanks for your help... I'm going to try and do some of these things myself but the transmission thing Ill probably pay them to do that considering its a "sealed" transmission. So i'll do the rear fluid, spark plugs, and grease fittings. Its there anything else??
  19. Feb 8, 2010 at 7:07 PM
    stinky_truck
    ryan
    AC cabin air filter depends on how much u use ur AC. located behind the glove box.
  20. Feb 8, 2010 at 7:13 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    13 TRD OR DC MGM
    Stock for now
    Honestly I did not, I felt the truck ran the same along with same mpg. I agree with the cabin filter change behind the glove box!
