(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Mar 4, 2013 at 8:46 PM
    PerfectTekniq
    PerfectTekniq I'm undefeated in the UFC.
    Pepe Silvia
    Claremont, CA
    2009 Super White 4x4 DC SB Sport
    AllPro Front, AllPro Rear w/ wraps, AllPro IFS Skid, 5100 w/ 885's upfront, Duratracs, Front Superbumps, BuiltRight UCAs, Dakar Leaf Pack, Extended 5100's, AllPro Flip Kit, Rear Superbumps, Extended SS brake lines WeatherTech Floormats, TRD Intake, ScanGaugeII, TRD SoCal, Grillcraft, Wet Okoles, Cobra 75 w/ 4' whip
    No way. You can't have murderin' gloves have the fingers cut off.
    Those are Ash Ketchum gloves.
  2. Mar 4, 2013 at 9:16 PM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    Nice pictures Corey.
  3. Mar 4, 2013 at 9:16 PM
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
    Whats next for your truck? Ditch the DB lift?
  4. Mar 4, 2013 at 9:17 PM
    mjbtaco
    mjbtaco low and slow
    Michael
    Montclair , so cal
    Turbo'd 95.5 extra cab and 2013 Silver DCSB TRD Sport
    PERFORMANCE Custom Turbo Setup FRONT SUSPENSION Drop Spindles by Aaron Carswell 01-04 Swaybar Endlinks Energy Suspension Endlink Bushings Cando Upper Control arms QA1 coilovers with 8" spring Custom 4 pot Brembo BBK Modified lower control arms with mjbfab qa1 mounting plates and Poly bushing sleeves REAR SUSPENSION Chasis Tech drop leafs QA1 adjustable shocks weld in drop notch Gas tank cross member bridge 3" angled blocks 2013 Double Cab Short Bed TRD Sport Eibach Pro Truck Shocks front and rear Lifted to the 3rd setting on the front shocks
    i finally got my truck running so some of you guys might see it around in the 909 and 626 haha.
  5. Mar 4, 2013 at 9:41 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
  6. Mar 4, 2013 at 9:55 PM
    Manwithoutaplan
    ID
    Yes looking on what I need to do to covert back to a 3 inch lift.
  7. Mar 4, 2013 at 10:04 PM
    MonkeyProof
    SoCal- SGV
    You can order a factory OEM cross brace from Toyota or you can Fab up your own. Would be a fairly easy thing for any of the local fab shops. Sick Nick, the one dude in Lancaster, LSK, YotaMasters come to mind just on the of my head, maybe even Defined Engineering in West Covina...
  8. Mar 4, 2013 at 10:18 PM
    Manwithoutaplan
    ID
    thinking of having my buddy make a cross member for me. I just got to figure out what size shocks i need.
  9. Mar 4, 2013 at 10:20 PM
    MonkeyProof
    SoCal- SGV
    What do you mean what size shocks.. you have a modified coil bucket for the DB lift as well?
  10. Mar 4, 2013 at 10:22 PM
    Manwithoutaplan
    ID
    like do i look for a extend coil over or just 6 inch coil.
    you think lsk will have their spindle out in couple months?
  11. Mar 4, 2013 at 10:28 PM
    MonkeyProof
    SoCal- SGV
  12. Mar 4, 2013 at 10:31 PM
    Manwithoutaplan
    ID
    are you running a 8 inch shock ^???
  13. Mar 4, 2013 at 10:34 PM
    MonkeyProof
    SoCal- SGV
    Yes..
    Here you go..put those sliders and lockers into good use. No excuses now :popcorn:
  14. Mar 4, 2013 at 10:35 PM
    LSK
    LSK Well-Known Member
    Burbank, CA
    Aiming to bring top of the line suspension, at a very affordable cost. As well as helping the off-road community
    we will. the hub blocks are whats holding it up but I sent the drawings to a bunch of places to get quoted today. Should have hiatts and jens hub blocks in the next two weeks.
  15. Mar 4, 2013 at 10:38 PM
    MonkeyProof
    SoCal- SGV
    Nice!!
  16. Mar 5, 2013 at 5:36 AM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    Just look for a used or new tacoma ext travel shock don't worry about how many inches. Or even an oem replacement if your going to keep that bj uca the extended travel is only 1/2 inch more travel
  17. Mar 5, 2013 at 8:13 AM
    Manwithoutaplan
    ID
  18. Mar 5, 2013 at 9:30 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    hey reeeeeannnn, when can i get that headlight?
  19. Mar 5, 2013 at 9:34 AM
    Jerez
    Rod
    Ontario Ranch
    Estock
  20. Mar 5, 2013 at 9:37 AM
    PerfectTekniq
    Pepe Silvia
    Claremont, CA
    Matt got a boner.
