(626 & 909) TW Members
Discussion in 'Southern California' started by Manwithoutaplan, Mar 4, 2011.
  1. Jun 26, 2014 at 10:19 AM
    Manwithoutaplan
    Manwithoutaplan [OP] the full Monty
    ID
    That is what i am thinking. DId you guys have trq wrench?
  2. Jun 26, 2014 at 10:51 AM
    ProForce
    ProForce IG @proforce.expeditions OB#5411
    Anthony
    Alaska
    09 MGM TRD Sport DCSB 4.0 Auto 2wd
    Too many to list. See build page. Link in signature
    Just found out its the same size nut at the ubolts. So I have all my OEM ubolt nuts with the flare on them and I also have a few nylocks of the same size that ill just add washers too.
    Yah nylocks should not be necessary but I guess it cant hurt
    We did keep running into problems and the install took 12 hours to complete front and rear. That inlcudes time driving around looking for a new bleeder valve too lol (which is now fixed) but by the end of the night we were all exhausted. Im positive we cranked everything down but the only thing we actually took a torque wrench to was the wheels and ubolts. Everything else was by hand so thats probably my issue. Ill swing by friday though.
  3. Jun 26, 2014 at 11:41 AM
    Manwithoutaplan
    ID
  4. Jun 26, 2014 at 11:46 AM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Awwww...thanks :D.
    Thing about "just cranking it down" instead of using the proper torque is this. The UCA should rotate on the bolt, if you just crank it down it may be so tight that the bolt rotates with the UCA thus loosening the nut. Aaaaand..the reason why they call out torque.
  5. Jun 26, 2014 at 12:01 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Torque wrenches are important for sure.. I carry one while on the trail and and also several others I wheel with including blackhawke88. Checking/inspecting important components while on the trail is crucial. This also comes down to prepping properly before each trail run. I spend a good 1-2 hours inspecting and making sure everything is tight, not broken or worn. That includes inspecting my recovery gear. It's a habit that needs to be learned and kept.
    I think if proforce had been properly prepping his truck , the loose UCA hardware would have been noticed a lot sooner. Don't mean to call him in a negative way, just using his situation as an example.
  6. Jun 26, 2014 at 12:26 PM
    ProForce
    Anthony
    Alaska
    I agree. I had the clunk/pop since the install 3 weeks ago and have been trying to find it but must have overlooked that area. Noob mistake i guess. Lessons learned
  7. Jun 26, 2014 at 12:57 PM
    the Oobagooba
    the Oobagooba Member
    Jon
    Southern California
    10 PreRunner
    Bilstein 5100's all around, Eibach coils, N-fab AAL, custom fab bumper with nerf bar, light bar
    Didn't even realize there was a audio page. Haven't lurked as hard as I thought. Going to take a gander through that first before making hard decisions. Deadening seems to be where im headed though. Thanks for the help!!
    EDIT: After scrounging through the audio threads I think what im looking for is better quality of sound as well as slightly louder. Wanting to only spend around $2-300 for the upgrade. Deadening seems to be a for sure as well as speaker upgrades. With all the DIYs threads, ill probably head that way as well to keep costs low. Thanks again!
  8. Jun 26, 2014 at 1:50 PM
    Manwithoutaplan
    ID
  9. Jun 26, 2014 at 2:38 PM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    hippy did it lol :eek:
  10. Jun 26, 2014 at 2:55 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    No...you want a Pelfreybilt expo rack! HERE
  11. Jun 26, 2014 at 3:40 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    Ask him if he'll do it out of aluminum. :confused:
  12. Jun 26, 2014 at 4:04 PM
    Jerez
    Rod
    Ontario Ranch
    Estock
    ^^^nice
    See how much nick can make you one for...then get some lobsters with a Mexican hat cut into some plates and welded on the corners :laughing:
  13. Jun 26, 2014 at 4:36 PM
    magikbean562
    magikbean562 once flirted with danger, danger got clingy
    greg
    socal
    pinto
    33" mudders
    needs to be more penisee
  14. Jun 26, 2014 at 4:38 PM
    precoma
    precoma Well-Known Member
    Corey
    Lake Arrowhead, CA
    2009 4x4 trd sport
    Total Chaos 3.5 Long travel, Defined SUA
    Is that made out of all spoons ?!?! That's awesome
  15. Jun 26, 2014 at 4:52 PM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    So there's rock, metal, blue lobsters...what about disco lobster??
  16. Jun 26, 2014 at 5:17 PM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    Ahhh yea, get down and boogie!!
  17. Jun 26, 2014 at 6:04 PM
    magikbean562
    greg
    socal
    pinto
    33" mudders
    disco herpes fool
  18. Jun 26, 2014 at 6:08 PM
    Manwithoutaplan
    ID
  19. Jun 26, 2014 at 6:09 PM
    magikbean562
    greg
    socal
    pinto
    33" mudders
    fixed the bearing issue ryry? i just did my rear diff. smell isnt that bad lol. ive smelled worse. coolant from cnc machines beats it x20
  20. Jun 26, 2014 at 6:12 PM
    Manwithoutaplan
    ID
    Tomorrow my friend.ahh the smell of rear end ... I mean sulfer. FYI if you get really bored helping a guy do his lift on friday evening.
