6MT in 3rd Gen. MTF Choices
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DTaco18, Oct 20, 2018.
  1. Oct 20, 2018 at 11:55 AM
    DTaco18
    DTaco18 [OP] Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    When I bought my 18 Tacoma, it didn't take long to figure out that it's pretty notchy from 1-2 and 2-3 (No grind, just crunchy). Switched to Redline MT-90 at 3k miles, with a bit of improvement. Read a couple of threads talking about Motorcraft XT-M5-QS (Syn 75w90 GL4) in the taco trans. Ordered some from RockAuto and put it in today. Initially, it does seem quite a bit smoother than the redline mt-90.
    Anyone else try this oil? Surprised to see so little talk of it on here...
    nevadabugle likes this.
  2. Oct 20, 2018 at 11:57 AM
    Mack7n
    Mack7n Well-Known Member
    Josey
    Old Town, ME
    2018 Tacoma TRD Sport DCSB 6M BBP/2018 T4R TRD Pro Calvary Blue
    Awaiting arrival of my 6MT, and obviously need to do a little more reading on this stuff. I test drove a different 6MT and didn't notice anything odd, and purchased the new one sight unseen from a dealer 3 states away. Should I be looking into this oil change?
  3. Oct 20, 2018 at 12:04 PM
    DTaco18
    Worth reading on this, but don't be discouraged about the 6mt... I'd still take it over automatic any day!
    It seems many people have the same issue. Fine on downshift, notchy on upshift between 2-3k rpm. No grind, more of a "feel" issue, like you're afraid to be hard on it. Below 2k rpm and above 3.5k are smooth.
    I would stick with the oem oil if you don't notice anything, and if you find the same issue, I'd try the sythetic motorcraft oil before amsoil or redline. It's only about $50 bucks for the change out, and it's definitely smoother than oem oil.
  4. Oct 20, 2018 at 12:05 PM
    Mack7n
    Josey
    Old Town, ME
    Thank you. I'll definitely look into this if I have any issues. Just swapped my Auto for a Manual. Couldn't handle the issues anymore.
    doublethebass and su.b.rat like this.
  5. Oct 20, 2018 at 12:10 PM
    phsycle
    phsycle Well-Known Member
    CA
    No issues with mine. I like a bit of notchiness as it clicks into gear.
    But I’ve used Redline in the past with good results.
    tonered and shakerhood like this.
  6. Oct 20, 2018 at 12:22 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Welcome to TW. Most people here realize that components (engines, transmission, diffs) don't fail because of brand of fluid as long as it's a quality brand meeting OEM specs.
  7. Oct 20, 2018 at 12:47 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If you have owned a Manual Tacoma prior to a 3rd Gen then you will appreciate how smooth it is and how easily it shifts.
    JoeRacer302, Wulf, tonered and 4 others like this.
  8. Oct 20, 2018 at 1:16 PM
    DTaco18
    Funny, I've read that a lot, so most manual Tacomas probably do shift smooth through all gears. For me, my first gen 5-spd shifted smoother than my new 3rd gen 6-spd. I never gave any thought to what oil was in my first gen tacoma; there was never any crunch or question going into any gear. (Or maybe I just got used to it?)
    Maybe these are just one-off's that have the crunchiness into 2nd and 3rd (There's been other prior posts regarding it). Either way, I want it to feel as smooth as possible, so experimenting with oil is a cheap and easy thing to do. Just looking for input from others who have tried oils other than oem and redline.
  9. Oct 20, 2018 at 1:35 PM
    RocTaco
    RocTaco Free stun!
    Pete
    Green Mtns
    21' SR5 Trail AG
    Mine is a 5-speed, but I've always had a bit of a notchy shift from 1st to 2nd. Mostly the first 10 minutes or so of driving, then only occasionally.
    I did all 4 fluid changes at 30k, and honestly the trans and t-case looked like they had been poured out of the bottle. I put amsoil 75w-90 MT fluid in the transmission, and it shifts pretty much the same as it did before.
    DTaco18[OP] likes this.
  10. Oct 20, 2018 at 1:36 PM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I highly recommend any 6MT users with notchy shifts to adjust their shifting technique. I recommend quick shifting with finesse. Move the shifter into the next slot before the engine RPMs drop more than 200-300 RPMs. The synchros will have to spin less and will make less noise. I also run redline MT90 and highly recommend it for this transmission.
  11. Oct 20, 2018 at 1:41 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    Haha very true.
    I've got no issue with mine. 30k and it finds it's gears just fine on the upshift and down.
    shakerhood[QUOTED] and BlakeM like this.
  12. Oct 20, 2018 at 1:44 PM
    BlakeM
    BlakeM Well-Known Member
    Blake
    Gonzales, LA
    2023 T4R.SR5.4WD.OMG.LOL.WTF
    How many miles do you have on it?
    I’ve got 21k on mine and the shifting is WAY smoother than it used to be.
  13. Oct 20, 2018 at 1:48 PM
    '16goingon'17
    '16goingon'17 Well-Known Member
    Trailslayer
    NoVA by way of NWA
    2017 TRDOR 4x4 DCSB MT
    JBA STD UCAs. 6112/5160 @6/5. Wheelers 1.5" 3AAL with Superbumps. BROG molle headrest covers. GMRS & Ham radios with roof-mounted NMO Laird Phantom antenna. Thinkware front/rear dashcams, FreshMexicanTaco's DMM, Meso's dome/map LEDs & Flipfob, Swingcase on driver side. Accumulator Delete Mod (ADM). Two-wheel drive Low Range Mod (2LM). Overland Tailor Tune (OTT) 7.0. Extra juicy oil spill on the bed mat.
    All I know is that the issue has to do with the clutch accumulator and the friction modifier or lack thereof in the MT fluid.
    tonered likes this.
  14. Oct 20, 2018 at 1:50 PM
    DTaco18
    Good to hear. I'm only at 4k, so maybe some more time to wear in...
    BlakeM[QUOTED] likes this.
  15. Oct 20, 2018 at 2:06 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Um no. Put 5K on the ass and you appreciate the accumulator lol. I pulled a scissor lift on a tilt trailer a few times last week.
    Friction modifier lol. Marketing buzzword.
    MOC221_ likes this.
  16. Oct 20, 2018 at 2:10 PM
    su.b.rat
    su.b.rat broken truck
    mine as well. once you learn its quirks and get your aim correct and habitual, then there isn't drama with this gearbox unless yours is faulty or something. I changed from stock to Royal Purple at around 15k and it's been just perfect since. now at 37k.
    shakerhood likes this.
  17. Oct 20, 2018 at 2:30 PM
    thefreshtaco
    thefreshtaco Well-Known Member
    Indianapolis Indiana
    2016 White TRDOR DCSB M/T Tech
    Lucas made mine feel better.
  18. Oct 20, 2018 at 2:36 PM
    MOC221_
    MOC221_ 3 pedal metal
    Frank
    2019 DCSB Sport M/T Barcelona Red
    vF Tuned; ADM; Core SS
    I'm curious... why do you say that about the accumulator?
    Are you saying it makes manipulating the clutch while towing easier in some way?
    tonered and hiPSI[QUOTED] like this.
  19. Oct 20, 2018 at 2:47 PM
    MOC221_
    Frank
    With regards to the "chunkiness/notchiness" of this gearbox, well it just gets better the more miles you put on.
    Getting into reverse was a bastard at first, and 2-3 resulted in a chunk most of the time. I just took it easy, didn't force anything. Later I added a weighted shift knob.
    No gear oil change. :notsure:
    hiPSI and TeecoTaco like this.
  20. Oct 20, 2018 at 3:53 PM
    TeecoTaco
    TeecoTaco Liberty Biberty
    SW Ontario
    16 Taco DCSB TRD Sport 6MT
    Modified the level of gas in the tank
    Ya, I'm due for all fluids. Trolling the shyte outta these threads to figure the best goo to go with
