6MT in 3rd Gen. MTF Choices
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DTaco18, Oct 20, 2018.
  1. Oct 20, 2018 at 6:05 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Absolutely, especially when accelerating from a stop and backing up. As you know, we can go like 100 mph in reverse lol. I think I had closer to 6K than 5K on the truck, taking into account two full size guys and load in the bed.
    If I were going to pull this type of load often there would be a full size and an automatic in my future.
    But, in "slipping clutch" condition, yes, the current OEM clutch setup is ideal.
    m603holden likes this.
  2. Oct 20, 2018 at 9:19 PM
    ATC Taco
    ATC Taco Active Member
    Justin
    18 Off Road DC MT Blue
    That’s what I’ve been learning. Fast but light shifts for the first 3 gears. I also don’t quite push the clutch in all the way.
  3. Oct 21, 2018 at 2:15 AM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    If you can drive this truck to the point where you're almost in range of floating the gears, it shifts great.
    I basically lightly 2 finger slap forward or back and it goes right into gear. I love this truck.
    My second gen had gear identity crisis on a few occasions
    doublethebass likes this.
  4. Oct 21, 2018 at 4:45 AM
    Ck1010
    Ck1010 Well-Known Member
    Ohio
    ‘21 Tundra TRD Off-Road
    I’ve put 3k miles on and it’s definitely getting smoother. 2 to 1 is easily the roughest shift I have.
  5. Oct 21, 2018 at 7:27 AM
    specter208
    specter208 Well-Known Member
    California
    2017 TRD SPORT ACLB w/ 6MT TRUCK WHITE
    TOYOTA OEM: Cast Aluminum Running Boards Mud Guards Bed Mat All-Weather Floor Liner NIssan Frontier Sliding Bed Extender
    I'll only do a downshift to 1st when the digital tach reads 3-4mph. You can try it, from 2nd second go into neutral and brake until you are about to reach 3mph and then clutch in and shift to 1st. It will slide right Into 1st gear very often at this speed or it will atleast not rumble in your hands like it does sometimes. Any faster or slower and the shifter shakes or the synchros take forever to match the speeds.
  6. Oct 21, 2018 at 7:31 AM
    specter208
    California
    Make sure you are pushing that clutch at least 3/4 to be safe. The clutch system has an accumulator that can change the clutch engagement and disengagement action and be the difference between a smooth shift or a rough/notchy shift.
  7. Oct 21, 2018 at 7:42 AM
    specter208
    California
    Not true. Friction modifier is important to have the proper amount of slipperiness. MT oil can't be to slippery or else the Synchros will keep slipping, make a slot of noise and have a harder time matching the speeds of the input and output shafts. A good friction modifier will allow the synchros to grab the gears quickly and easily.
  8. Oct 21, 2018 at 8:52 AM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    @DTaco18 I've got a nice heavy shift knob for sale that will take away that notchiness...;)
    Honestly though, I've got three knobs now. Stock, one that's 800g and one thats 130g (about 70g less than stock). The lighter one feels more notchy than stock and the heavy one just feels smooooooth and easy, almost effortless at times.
  9. Oct 21, 2018 at 10:06 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Sandpaper is a "friction modifier." Graphite is a friction modifier. Anything that changes the coefficient of friction is a friction modifier lol.
  10. Oct 21, 2018 at 10:08 AM
    m603holden
    Marteeen
    New England
    ...self moderating here. Set everyone up for a layup joke here. Hahaha.
    hiPSI[QUOTED] likes this.
  11. Oct 21, 2018 at 10:11 AM
    specter208
    California
    Yeah I know. He's not fooling me.
    hiPSI likes this.
  12. Oct 21, 2018 at 10:23 AM
    specter208
    California
    Ok, what's your point.
  13. Oct 21, 2018 at 10:30 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    That words like "friction modifier" are just marketing. Just by creating a lubricant you created a friction modifier. If you change or modified that formulary, then you created a different lubricant.
  14. Oct 21, 2018 at 10:31 AM
    m603holden
    Marteeen
    New England
    It's all about the lube and CH's....
  15. Oct 21, 2018 at 10:35 AM
    #35
    m603holden
    Marteeen
    New England
    Because 1 ch one way or another, boom, friction is all out of wack.
    hiPSI likes this.
  16. Oct 21, 2018 at 10:37 AM
    #36
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The only time I have ever used Friction Modifier is in my car, the Service Manual calls for a small bottle of it in the rear diff.
    specter208 likes this.
  17. Oct 21, 2018 at 11:05 AM
    #37
    ATC Taco
    Justin
    Yea thanks I do push it in about 3/4. Haven’t felt a rough shift yet while doing it. I learned about the accumulator recently and knowing what it does has helped me learn better. Now I just need to get used to the clutch feel when it’s really cold. Feels like molasses!
    specter208[QUOTED] likes this.
  18. Oct 21, 2018 at 11:11 AM
    #38
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    I think we need to add a candle...
    m603holden[QUOTED] likes this.
  19. Oct 21, 2018 at 11:15 AM
    #39
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Seriously, some of these guys should be working with Sommerfeld's Number before posting about this topic lol.
  20. Oct 21, 2018 at 11:47 AM
    #40
    specter208
    California
    Except you actually have a base stock oil and then you have the additives like detergents/dispersants, anti-wear additives like ZDDP, rust inhibitors, and of course viscosity index improvers which modify the friction created by your base oil.
