6MT throwout bearing and clutch system shenanigans
Discussion in 'Technical Chat' started by BillDaCat8, Dec 12, 2020.
  1. Sep 30, 2021 at 7:12 AM
    #261
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    I ordered through Kirk.
    Honestly, I do not remember exactly what size I did those holes. I just measured the hose and selected a bit that was slightly larger. You can still work on making the moons fit in the hole and such. Just wait for your HRB to drill for the lines.
  2. Sep 30, 2021 at 8:00 AM
    #262
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    did you already buy the half moon plugs? I have a pair I didn’t use and a set of new flywheel bolts if you’re interested.
  3. Sep 30, 2021 at 12:23 PM
    #263
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    Thanks for the offer. I'm actually experimenting with some tapered silicon plugs used for lab test vials. Perfect dimensions, I'll just have to freeze them in order to make the holes or just punch a solder iron through them.
  4. Sep 30, 2021 at 9:12 PM
    #264
    BillDaCat8
    Jake
    PHX
    Cool idea. What about a hollow punch tool to make those holes? Harbor Freight has cheapies that should do the trick.
  5. Oct 1, 2021 at 2:37 AM
    #265
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Not likely, seeing how thick these are. I will report my findings if they end up working out.
    Tomorrow I'll email Kirk and source the bearing. Any perks of going with the Toyota branded bearing? I can likely source a Koyo, Timken, FAG, etc. easier through work.
  6. Oct 1, 2021 at 7:03 PM
    #266
    BillDaCat8
    Jake
    PHX
    Ah. Yes. Much thicker than I’d imagined (that’s what she said)
    As for the bearing, If you can source them stateside, please do share where.
    The OE number I ordered off of eBay was easy enough and arrived quite quickly considering where it shipped from.
    @garciav got his fast too. His is in and running btw. Hope he’s not mad that I leaked that tidbit.
    Kasbien[QUOTED] likes this.
  7. Oct 1, 2021 at 8:41 PM
    #267
    garciav
    Houston, TX
    TRD SC,HPTuners
    +1 for Tilton over CM !
    rheath08, Kasbien and TodayWasTHeDaY like this.
  8. Oct 1, 2021 at 11:59 PM
    #268
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Awesome! Are you enjoying it? Did your quill snap as well?
  9. Oct 2, 2021 at 8:38 AM
    #269
    garciav
    Houston, TX
    TRD SC,HPTuners
    Honestly too soon to tell, only have a couple hundred miles on it but just based on build quality of the unit and the name tilton carries I feel a lot better about having it in my truck.
    My quill didn’t snap. I cut that sucker off (regretfully so) to run the now obsolete URD fix-u hydrobearing a few years back. Obviously knowing what I know now I would’ve steered clear from that setup but back then I was naive enough to think that URD was the answer to everything Tacoma. Definitely learned the hard way that’s not the case.
    GilbertOz and TodayWasTHeDaY like this.
  10. Oct 3, 2021 at 3:23 PM
    #270
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Okay, that's fair. Did your OG URD hydro setup fail like the Clutch Masters unit? Or just impossible to get parts to service it now?
  11. Oct 4, 2021 at 10:51 AM
    #271
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Got the bearing ordered. I searched far and wide locally through auto part suppliers and bearing suppliers alike, but didn't have any luck. I ended up ordering it from https://partsouq.com/ in Dubai as it was cheaper and way faster than shipping to Canada from eBay. I placed the order last night and was notified this morning that it had been shipped. We'll see if this website delivers.
    If you're looking for more bearing manufacturer part number interchanges, here's a compiled list: https://www.yoyopart.com/oem/217493/toyota-9036345013.html
    @BillDaCat8 I just noticed from your photos that it looks like only half of the bearings inner race actually get's seated on the bushing/piston. I know that the force applied to the bearing is axial in this case (parallel with the piston), but ain't that still bad? Am I missing something?
  12. Oct 5, 2021 at 8:53 PM
    #272
    BillDaCat8
    Jake
    PHX
    Same vendor on eBay that I used. You’ll be fine.
    There’s plenty of meat there to hold things together. Certainly the Tilton piston wasn’t designed for this exact bearing. But, it works fine with the collar to adapt it.
  13. Oct 8, 2021 at 2:35 PM
    #273
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Gotcha. I might tweak my bushing design. We'll see when I get the parts in hand.
    EDIT 1: The bearing arrived. 5 days to get it from Dubai... Wow! That's awesome. Mine is a Nachi bearing in a Toyota box, so you may as well order the Nachi bearing off of the PartSouq website and save yourself a cool $5. :D
    EDIT 2: Kirk cleared up my part number confusion on the Tilton pieces and recommended I order through Summit. FYI, for the Canadians reading this, Summit Racing has free shipping over $99 right now and duties were around $30 to land it all in British Columbia.
  14. Oct 28, 2021 at 10:42 PM
    #274
    BillDaCat8
    Jake
    PHX
    Where are we at with your project up there Kel?
  15. Oct 31, 2021 at 2:00 PM
    #275
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Ordered the FJ pedal shopping list a few weeks back through a friend of a friend who's a parts guy at a Lexus dealership to avoid the rediculous Canadian markup/closed border crossings. It was supposed to take up to a month to come in.
    So between the Tilton and Toyota orders I'm just sitting here patiently waiting for the parts to pour in by mooseback. :canada:
  16. Nov 27, 2021 at 10:26 AM
    #276
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Progress Update #1
    All parts have now arrived. Took my measurements for my bushing design and drew it up on the computer. Pretty much 1/3 of the bearing race is unsupported when seated on the piston, so I'm going to add a bit more support to my version just to be safe. I'll be going with 6061 aluminum now that I've got it hand because I realize that the piston itself is actually aluminum so we don't have to worry about future corrosion issues in this case.
    Next step is getting my drawing to my amigo with the CNC lathe to whip it up the bushing for me and I'll begin working on all the other bits.
    BillDaCat8[OP] likes this.
  17. Nov 27, 2021 at 12:45 PM
    #277
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    @BillDaCat8 do you still have that RA60F bell housing kicking around? Would you be able to grab these measurements for me? If not I'll try hunting down a local taco guy with one kicking around.
  18. Nov 30, 2021 at 3:32 PM
    #278
    BillDaCat8
    Jake
    PHX
    Not super accurate. But here’s what I got.
    tinker_troy and Kasbien[QUOTED] like this.
  19. Dec 1, 2021 at 2:52 AM
    #279
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Thanks a bunch. I can now make the bracket for the anti-rotation pin so that it's ready to go for the shop.
    Onward!
  20. Dec 5, 2021 at 11:50 PM
    #280
    Kasbien
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    @BillDaCat8need a few more confirmations from ya... :rolleyes:
    1) Can you confirm that the 34mm hole for the slave cylinder is the diameter same on the RA60F bell housing? And approximately how thick those aluminum half-moons plugs are? Now that I've got all the Tilton parts in front of me, I've realized that idea of modifying the silicon taper plug is not going to work in the slightest. I'm going to 3D print some half-moons myself since we have extreme shipping delays due to flooding where I live right now.
    2) Could you also confirm what length bolt you have in this picture and how much you have sticking out roughly? I'm browsing catalogues at my auto parts store for rubber/polyurethane bump stops on a stud but I think they're all going to be way too tall/wide to be useful.
    :bowdown:
