6MT throwout bearing and clutch system shenanigans
Discussion in 'Technical Chat' started by BillDaCat8, Dec 12, 2020.
  1. Sep 24, 2022 at 1:30 AM
    #381
    offroadtoyboy
    offroadtoyboy Well-Known Member
    Middle of nowhere Cali
    2006 Pre-Runner / converted to full manual 4WD / RC62 swap / Manual 4R trasfer case mod
    kasbien,
    But the parts I have will still work for him right?
    what did you change?
  2. Sep 25, 2022 at 11:11 AM
    #382
    Kasbien
    Kasbien Well-Known Member
    Kellen
    BC, Canada
    07 DCSB 6MT 4X4
    Pop rivets and JB Weld.
    Yes they will work. They were my prototypes so I built upon them since then.
  3. Sep 26, 2022 at 7:12 AM
    #383
    Rezkid
    Rezkid Not a Well Known Member
    TJ
    WTX
    '08 DCSB TRD RT
    Little bit of this and that
    Thank you! PM inbound!
    Still waiting on the piston from Jegs. That's the last part holding up the whole deal. I'll be shooting them an email today inquiring about canceling and placing an order for the replacement 62-6122 piston.
  4. Sep 28, 2022 at 10:17 AM
    #384
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    Rezkid, DesertRatliff and MeJBRO like this.
  5. Sep 29, 2022 at 7:30 AM
    #385
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    It's not on their website yet, but I just got a call back from Summit and placed my order for 62-6122 over the phone, if you are still not having luck with Jegs.
    MeJBRO and Rezkid[QUOTED] like this.
  6. Sep 29, 2022 at 12:06 PM
    #386
    Rezkid
    TJ
    WTX
    '08 DCSB TRD RT
    Good to know, I got my original order with Jegs cancelled and talked to their technical team about sourcing the new PN# from Tilton. If that falls through I'll give Summit a call and order through them.
    Littles[QUOTED] likes this.
  7. Oct 5, 2022 at 9:54 AM
    #387
    super g
    super g Well-Known Member
    garrett
    north carolina
    09 trd off road with high hopes
    Afe stage 2 cai pro dry s, magna flow exhaust
    Not sure if you actually went through with this, but if you did have more spacers made for the Bearing/HRB I'd buy one off of you. Need to replace the clutch/flywheel on a truck/Trans with 178k on it and I'd love an extra overdrive so contemplating the RC62F and HRB set up vs the 250.00 for the urd sleeve fix, this way i get a better clutch AND double overdrive..
    XPOTRPR[QUOTED] likes this.
  8. Oct 5, 2022 at 12:14 PM
    #388
    super g
    garrett
    north carolina
    @BillDaCat8 @Rezkid I currently have an 09 tacoma with the original plastic MC... based on this and a few other threads am I understanding that I can purchase the newer LC/ Prado MC with a metal adjuster ( p/n 31420-60032) and just use this whole unit in place of the original? Based on what I've read it's a cross reference for the updated 2nd and 3rd gen MC units sans the all metal adjuster. Thanks.
  9. Oct 5, 2022 at 2:47 PM
    #389
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    I did not. I left it alone as this is @BillDaCat8's Baby. I know he's got a lathe and the abilities though..
    super g[QUOTED] likes this.
  10. Oct 5, 2022 at 5:02 PM
    #390
    Rezkid
    TJ
    WTX
    '08 DCSB TRD RT
    You can skip that and go straight for the FJ Cruiser parts that @BillDaCat8 has listed in post #1 of this thread. The idea is that you want to replace the plastic clutch pedal assembly with the metal one from the FJC and should use the FJ master along with it.
  11. Oct 6, 2022 at 4:14 PM
    #391
    BillDaCat8
    Jake
    PHX
    Agreed.
    @super g If you are going to a HRB then I suggest switching to the FJ pedal. If you need a new master, it makes a lot of sense to just use the FJ master as well. The clevis on that master is plastic. But, it will work just fine.
  12. Oct 6, 2022 at 4:24 PM
    #392
    BillDaCat8
    Jake
    PHX
    @Kasbien has your spacers and more. He’s in the middle of developing a kit to make it super easy to adapt the Tilton HRB. If I were you, I would wait for him to get those finished up. It’s going to take you a while to find your RC62F anyway. Not to mention acquire all of the parts from Tilton that you will need.
    That being said; if you are going to switch to an RC62F, you don’t necessarily have to run the Tilton set up. If you run a third gen Tacoma pressure plate (which bolts right up) you can use the third gen release hardware that will likely come with your transmission. Assuming you buy one used.
  13. Oct 23, 2022 at 9:05 AM
    #393
    MeJBRO
    MeJBRO Member
    2005 SWB X-RUNNER
    Update: got the base plate for the URD release bearing bored to fit the threaded sleeve for the Tilton HRB...problem is the machinist oversized the i.d. of the base plate by .002". Gonna put some green loctite on, let it cure for 48 hours, and try to reassemble the truck...
  14. Oct 23, 2022 at 11:21 AM
    #394
    offroadtoyboy
    If you have a big enough ball bearing or something similar, you put the round metal object in the hole and smack it with a hammer. It will cause the hole to swell and shrink a few thousands.
    XPOTRPR and MeJBRO[QUOTED] like this.
  15. Nov 2, 2022 at 1:34 PM
    #395
    BillDaCat8
    Jake
    PHX
    So, I’m here at SEMA.
    I found the Tilton booth and spoke to Kirk. He actually remembers me. I was surprised.
    Anyway,
    Still no plans for a kit for our trucks. He realizes that there’s good potential there. But, he says that they just don’t have the resources to do it right now.
    We did discuss their kit possibly including a master cylinder as well.
    Just keeping the idea fresh in their heads.
    tonered, GilbertOz, Kasbien and 8 others like this.
  16. Nov 2, 2022 at 2:16 PM
    #396
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    oof..
    I'm here if you guys ever need me...
    This.. Ping it.. might help some, but that plate was decently thick IIRC.. hopefully it gives it enough engagement.
    MeJBRO[QUOTED] and garciav like this.
  17. Nov 2, 2022 at 7:02 PM
    #397
    offroadtoyboy
    We used to do this kind of thing on all sorts of materials and kinds of thicknesses with no problem. Obviously with the aluminum you don’t need to hit as hard.
  18. Nov 2, 2022 at 7:05 PM
    #398
    offroadtoyboy
    Funny that you mention this, when I was getting all my parts (including the right part number that Summit said was discontinue by Tilton) Kirk mention I should speak with you lol.
  19. Nov 30, 2022 at 8:03 PM
    #399
    MeJBRO
    MeJBRO Member
    2005 SWB X-RUNNER
    I drove the X-runner tonight for the first time - in a long time. The HRB is working perfectly and I have the pedal dialed in with a long bucket elevator bolt. I'm still running the plastic pedal, but I didn't have to relocate the switch. This is temporary, as I still have a small drip on the bleed line. The Russell speed bleeder assembly has been delayed twice since my original order in October. It has been delayed till January 9th. I needed to get the truck outta the garage, though. She's limpin' along, but I'm the happiest I've been in 3 years - thank you to everyone that did all the heavy lifting on this thread! I really appreciate it and I hope one day I can help someone like y'all helped me.
  20. Dec 2, 2022 at 9:18 PM
    #400
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    What up Jake- I thought this Tilton HRB was designed to work off a larger 7/8" master cyl (a size up from the 3/4" OE) ? You're saying ideally we should size it smaller, maybe 5/8" bore to get more stroke throughout the bite point of the clutch? Wouldn't sizing down require more force to depress the clutch pedal?
    I have the same issue you are describing and with the URD stg 3 pressure plate the clutch pedal is hella firm, it takes an effort to feather the clutch smoothly in stop-n-go traffic.
    I ask because I recently acquired a pedal assembly from another member on here and wanted to see how one of those tilton master cyl's would fit without having to pull the pedal assembly from my truck.
