6MT throwout bearing and clutch system shenanigans
Discussion in 'Technical Chat' started by BillDaCat8, Dec 12, 2020.
  1. Feb 8, 2021 at 4:19 PM
    #141
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    Good idea heat shielding the fluid line!
  2. Feb 8, 2021 at 4:25 PM
    #142
    BillDaCat8
    BillDaCat8 [OP] Well-Known Member
    Jake
    PHX
    07 4x4 Access Cab M/T
    My shit is all stock.
    The previous hydro setup (when it wasn’t leaking) seemed to do weird things when it got hot as well. Hopefully this will help prevent that.
    The OE line on the 3rd gen is also wrapped with some very similar heat rejection stuff. So, Toyota obviously knows that this line needs some protection. Even with the OE components.
  3. Feb 8, 2021 at 6:15 PM
    #143
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    2019 Cement Sport 4X4 MT AC
    OVT, 4.88, ADM, F&R ARB lock, KO2's, RWD L MOD
    Idiot alert: Why does the Tilton hydraulic release bearing have two lines?
  4. Feb 8, 2021 at 6:21 PM
    #144
    TodayWasTHeDaY
    Russ
    Calgary
    One end is where the bleed screw is and exits the transmission housing so it's accessible.
    BillDaCat8[OP] likes this.
  5. Feb 8, 2021 at 6:32 PM
    #145
    Pablo8
    Pablo8 Here!
    Paul
    Everson WA
    Makes total sense. Thanks!
  6. Feb 12, 2021 at 1:22 PM
    #146
    Bluebaron7
    Bluebaron7 Well-Known Member
    Augusta, GA
    2009 Tacoma Double Cab TRD Off-Road(Sold)/2024 4Runner ORP
    3 Inch Lift, Leaf spring pack, SPC UCA's, Bilsteins 5100's, AFE CAI, ECGS Needle Bearing, CVJ Axles, Under seat Infinity Sub & 4 channel amp, softtopper, decked system, prinsu roof rack, Kenwood deck & Infinity speakers all around with door matting, taco sauce only sticker, steering wheel leather wrap and dash cam.
    How’s the awesome build going?
  7. Feb 12, 2021 at 2:48 PM
    #147
    BillDaCat8
    Jake
    PHX
    Going quite well. Transfer case went in last night. Propeller shafts, exhaust, etc go in tomorrow. I hadn’t posted much about that here since it’s not really related to the clutch stuff.
    As for the clutch stuff, I have been working behind the scenes. I’d forgotten to order a couple of bushings for the pedal, so, those are due in tomorrow. That’ll hopefully be all of the parts that I need for under the dash. The wife has the day off tomorrow as well, so, she will be recruited to help bleed the system. Once that’s done, fingers crossed, it’ll be time for a test drive.
  8. Feb 12, 2021 at 3:37 PM
    #148
    TodayWasTHeDaY
    Russ
    Calgary
    Good idea hard mounting the bleed fitting!
  9. Feb 12, 2021 at 5:32 PM
    #149
    BillDaCat8
    Jake
    PHX
    Thanks.
    That worked out really well actually. The bleed line from the bearing came out to the perfect length. The pressure line did too, now that I think about it.
  10. Feb 13, 2021 at 5:44 PM
    #150
    BillDaCat8
    Jake
    PHX
    Hey! I said; No more plastic shit!
    The old and the new.
    My idea for an adjustable pedal stop.
    Clevis pictured with one of the newer plasticy ones. Was just figuring how much longer the new one needed to be. Turns out, an inch. Seems like everything is just an inch off with this whole thing.
    Found an 8x1.25 coupler at the local hardware store. It’s a hair short at 22mm. But, it’ll do the trick. I ran a long bolt up through the both of them before welding to make sure it all lined up nicely.
    Ready to weld.
    The chrome-esque coating on the clevis was very un-fond of welding temperatures. I had to knock it all off with an abrasive disc. I would’ve liked to have it coated again, But, I need this truck back on the road. So, a dousing of fluid film will have to do.
    Here’s the new no-B.S. clevis installed on the new pedal. Then, pedal installed. FJ pedal fits with zero drama. New bushings everywhere obviously. I have my pedal adjusted to be even with the brake pedal. To achieve that, I backed the cruise cancel switch up at the top of the pedal all the way out. Then I removed the locknut. Then I threaded the switch back in and used the locknut on the underside. I then made pedal height adjustment to where I want it. Don’t forget to reconnect the wire when done.
    Pedal stop.
    mav, Key-Rei, rheath08 and 2 others like this.
  11. Feb 13, 2021 at 6:16 PM
    #151
    BillDaCat8
    Jake
    PHX
    rheath08, megillet and TodayWasTHeDaY like this.
  12. Feb 13, 2021 at 6:16 PM
    #152
    BillDaCat8
    Jake
    PHX
    mav, Key-Rei, rheath08 and 5 others like this.
  13. Feb 13, 2021 at 7:03 PM
    #153
    garciav
    garciav Well-Known Member
    Houston, TX
    2013 Tacoma TRD Off-Road 6MT
    TRD SC,HPTuners
    Did you end up changing master cylinder size ? What is that pedal out of ?
  14. Feb 13, 2021 at 7:14 PM
    #154
    BillDaCat8
    Jake
    PHX
    Stock master. Pedal is from FjCruiser. I’ll fill in the blanks later. Wifey made margaritas. Pollo asado tacos tonight.
    Key-Rei, VirusCage, rheath08 and 5 others like this.
  15. Feb 13, 2021 at 7:24 PM
    #155
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    Oof
  16. Feb 14, 2021 at 7:58 AM
    #156
    BillDaCat8
    Jake
    PHX
    This is Tilton’s video for setting up their HRB. Watch and understand. This is a very important step!
    https://www.youtube.com/watch?v=0X2JAoHhy0A
    If you’ve been following this thread, you’ll recognize when I did the measuring and such. Pay close attention to the back end of the video where they discuss setting the pedal stop. I did that part yesterday and was quite pleasantly surprised at how little stroke the clutch actually needs to disengage. So, do not skip this setting. For that reason, I’m going to say that the FJ pedal should be mandatory for any sort of HRB setup. It’ll work for second as well as third gen trucks.
    Another note. The clutch switch at the bottom of the pedal’s stroke is now not being contacted by the pedal because of the stop bolt. So, that will need an adjustment. I’ve just been using the bypass switch on the dash until then.
    Edit:
    I’ve learned this morning that the maximum allowable adjustment at this switch is insufficient. I’m going to need to extend the switch bumper on the back of the pedal.
  17. Feb 14, 2021 at 8:28 AM
    #157
    garciav
    Houston, TX
    TRD SC,HPTuners
    Did you add that pedal stop bracket to the FJ pedal or does it come that way ?
  18. Feb 14, 2021 at 9:31 AM
    #158
    BillDaCat8
    Jake
    PHX
    It comes with a hole there. There’s a plastic bumper that is supposed to go there. But, not this time. I could tack weld one of the nuts in place to make adjustment a little easier. But, it’s really not necessary.
    6 gearT444E likes this.
  19. Feb 14, 2021 at 11:27 AM
    #159
    6 gearT444E
    Deep South
    Herculiner Hootus
    What’s the main reason for the pedal swap, because of the tilton bearing, or did you want to also rid yourself of the dreaded pedal squeak of the taco (and this the swap also alleviate that noise?)
  20. Feb 14, 2021 at 2:23 PM
    #160
    BillDaCat8
    Jake
    PHX
    I want it to feel like a solid pedal. I don’t need all the plastic stuff in there muddying the feel. Even with the updated TSB parts I had the pedal squeak too. It did it mostly when it was cold outside. And, yes. I needed an easy way to incorporate a pedal stop.
    It feels great now. No weird noises. We’ll see for how long. I just installed it yesterday.
