6x9 door speakers
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Mason502, Sep 12, 2021.
  1. Sep 12, 2021 at 10:26 AM
    Mason502
    Mason502 [OP] Well-Known Member
    Mason
    Mount Sterling, Kentucky
    2015 Tacoma 4x4 Access Cab 2.7 Automatic
    Bilstein 5100 shocks, cali raised LED.
    I’m looking to replace my factory door speakers, so any suggestions on what I should look for?
  2. Sep 12, 2021 at 10:39 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    I replaced mine with these. What a difference. They also have a tweeter so you don’t need to mess with that one in the door.
    You will also need the adapters to fit the Tacoma. I bought everything on Amazon and it was a simple job after looking at utube videos on how to remove the door panel. If I did it all over again I would buy the same ones. All sounds are much clearer now and the stock head unit works good with these.
    https://www.amazon.com/Rockford-Fosgate-R169X3-Full-Range-Coaxial/dp/B00BF6HVG4
    https://www.tacomaworld.com/threads/rockford-fosgate-sounds-good-in-access-cab.730191/
  3. Sep 12, 2021 at 10:55 AM
    spitdog
  4. Sep 12, 2021 at 10:59 AM
    AJKlug1
    AJKlug1 Well-Known Member
    AJ
    SE Wisconsin
    2010 ACLB 4x4
    Full sound system, 3rd gen OR suspension, pro headlights & more
  5. Sep 12, 2021 at 11:01 AM
    Corny Taco
    Corny Taco The Sauce
    Blake
    Columbus/Atlanta Georgia
    06 SR5 DCSB Prerunner
    -33 inch Nitto Ridge Grapplers -18 inch fuel kranks -Bilstein 5100s -OME normal duty dakars -Toytec/Eibach coils -Magnaflow off-road pro exhaust -Prinsu roof rack -nfab rock guards -EBay Faux Trd Pro Grille -Custom basshead audio build in progress
    I’m personally running the Skar TX 6x9s. Clear and loud if powered properly with an amp (which all door speakers should be). I love them and they have done me well, but I’m swapping them out for some pro audio speakers to blow my ears off.
    https://www.skaraudio.com/collections/tx-speaker-series/products/tx69-6-9-inch-coaxial-car-speakers
    I have also heard great things about these bully performance audio 6x9’s. They seem really beefy and good quality.
    https://www.bullyperformanceaudio.c...ormance-audio-bp-6-9hd-500watt-6x9″-speakers/
    no offense to the poster above, but Rockford isn’t all that’s cracked up to be. They’re at an okay price for what they are, but you’re just buying the brand name.
  6. Sep 12, 2021 at 11:12 AM
    spitdog
    I looked at the Skar TX6x9s but a lot of people recommended spend a little more for quality. They looked pretty cheap and the reviews said they tend to crackle after about a yr. I think the reason so many people bought the fosgates is the fact they must be a better speaker. Your better of spending a little more on quality. You can buy those Tx6x9 for 40 bucks, that was a warning flag to me.
  7. Sep 12, 2021 at 1:52 PM
    Corny Taco
    Blake
    I’ve read about that crackling and I think that can be attributed to running them on head unit power, improper grounding, or improper tuning. I haven’t had an issue. They’re def a budget brand, but most of the speakers out there on the market are made in the same factory in China with different specs. that’s why I’m upgrading to some deaf bonce sylvesters.
    I’m not coming at Rockford, they’ve been around for a long time and the quality is good, but could be better hence all the speakers are made in China since you really can’t find any from anywhere else sadly. I’m just going off of what I’ve handled and experienced.
  8. Sep 12, 2021 at 8:27 PM
    sentientprogram
    sentientprogram Well-Known Member
    I used Kenwood KFC-690 (6x9)
  9. Sep 12, 2021 at 8:54 PM
    Waasheem
    Waasheem
    2007 xrunner
    I went with pioneerTsa692c speakers. A huge improvement over stock. Really anything you stick in there will be an improvement over the half dollar sized magnets the stock has.
    doityerself likes this.
  10. Sep 12, 2021 at 10:17 PM
    Ralphtaco805
    Ralphtaco805 Well-Known Member
    15 Tacoma
    Bilsteins 5100 Hellwig Rear swaybar 17 trd sportswheels
    I replaced my cheap speakers to jl audio speakers because it’s bassy and crispy sound and I don’t have to buy the amp and subwoofer
  11. Sep 12, 2021 at 10:23 PM
    RealLeisure
    RealLeisure Well-Known Member
    Ray
    01 DCSB 4WD V6
    I'm not sure if you'll have an identical problem as I did (I have a 1st gen taco), however I'd be certain the depth of the speakers are good to go before purchasing. I ran into the issue of buying speakers that matched the XY dimensions but were far too deep and I ended up having to Dremel out a lot of plastic to get them to fit. Good luck though!
  12. Sep 13, 2021 at 3:32 PM
    Mason502
    Mason
    Thanks guys for the help I’ll look into all of them and see
  13. Sep 13, 2021 at 3:36 PM
    Capt. Obvious
    Capt. Obvious Fearless Keyboard Warrior
    Darrick
    Gig Harbor
    '12 DCLB TRD
    6" body lift, LEDs errwhere, Jesus mural on the hood
    Even a cheap-o speaker will sound better than the factory speakers. Spend some extra money on sound deadening for the doors while you have the panels off too.
  14. Sep 13, 2021 at 7:22 PM
    doityerself
    doityerself Well-Known Member
    The Deep South
    2006 SR5 DCLB 4x4
    Not Enough and it continues...
    X2. Big improvement for me. Crutchfield.com has good choices.
    Thatbassguy likes this.
  15. Sep 13, 2021 at 7:31 PM
    Thatbassguy
    Thatbassguy Sweet or sour?
    James
    '19 T4R, TRDORP, KDSS
    RSG sliders, SOS skids, SOS bumper, wheels, tires, etc
    +1 for Crutchfield.com
    They will sometimes throw in any adaptors you need for free.
    I pu JL CI-690's in my 4Runner and it's a huge improvement over stock.
  16. Mar 31, 2022 at 6:46 AM
    ROUSHETTE
    ROUSHETTE New Member
    KARI
    NAPLES, FL
    TACOMA TRD
    RACKS, STEREO, OFF ROAD COMPONENTS
    Hi guys, I recently purchased 6X9's for my 2011 Sport Tacoma. The brackets I received (Metra 82-8146 6" x 9") https://www.amazon.com/gp/product/B00IIC6CPE?ie=UTF8&th=1 didn't fit the screw pattern. I returned them & tried https://www.amazon.com/gp/product/B00IIC6CPE?ie=UTF8&th=1
    Neither fit. I see you have used the https://www.amazon.com/dp/B00IIC65NS (
    Metra 82-8149 6" x 9"). Do you think this is going to work this time or is there a different bracket I should be aware of that I haven't Googled yet? Any help would be greatly appreciated. Not the JLB speaker option.
  17. Mar 31, 2022 at 7:14 AM
    Arrow05
    Arrow05 Well-Known Member
    Cruthfield is your friend. They have everything that you will need. Also if you're looking to upgrade the tweeters, i heard replacing them with Subaru tweeters is a good upgrade.
  18. Mar 31, 2022 at 7:16 AM
    ROUSHETTE
    KARI
    NAPLES, FL
    TACOMA TRD
    Yeah, I looked there. Thank you. I have already replaced the speakers to Sony, but the 2 different types of brackets do not fit.
  19. Mar 31, 2022 at 8:31 AM
    clenkeit
    clenkeit Well-Known Member
    Colin
    Lakewood, CA
    2010 White DCLB TRD Sport
    According to Crutchfield, the correct 6x9 adapter is Metra 82-8146
    https://www.amazon.com/Metra-82-8146-Speaker-Adapter-Vehicles/dp/B00IIC6CPE
    Which "screw pattern" didn't work? Were you unable to screw it to the door or were you unable to screw the speaker to the adapter? In most cases you should be able to just add new holes where needed although that shouldn't be necessary. Do you have any pics of the fitment issue?
  20. Mar 31, 2022 at 8:35 AM
    ROUSHETTE
    KARI
    NAPLES, FL
    TACOMA TRD
    The holes on the bracket did not line up with the door holes. Both Tacoma's we were able to get them all to line up except the 2011 front 6X9's. Guess I will have to get those pics. Thanks.
