6x9 speaker suggestions
Discussion in 'Audio & Video' started by D44boy, Aug 14, 2012.
  1. Aug 15, 2012 at 10:03 PM
    B1SLYFOX
    B1SLYFOX Active Member
    Brandon
    Virginia Beach
    2012 Prerunner TRD Offroad
    Just getting started.
    Tough to say, so many variables... sometimes mounting locations can cause rattling in panels and so on, what sounds good to one person may sound different to another you will more than likely be happy with any nice middle of the road speaker from a reputable manufacturer. Almost anything is an upgrade from stock.
  2. Aug 15, 2012 at 10:09 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    Yeah I have the alpine 6x9's now but don't have a amp powering them and one went out from lack of power. Just wondering if I should buy the same when I get my amp or get components.
  3. Aug 16, 2012 at 8:19 AM
    Aw9d
    Aw9d That one guy
    For the front, the component's are much better.. ONLY if you are using an amp to run them.
  4. Aug 16, 2012 at 2:27 PM
    Aw9d
    Aw9d That one guy
  5. Aug 16, 2012 at 9:51 PM
    JCVorndran
    JCVorndran Macaroni Connoisseur
    Jonathan
    Phoenix
    6000K headlights and foglights, limo tint, Pioneer AVH8400, Rockford T1652 components, PBR300.1 and PBR300.4
    http://lmgtfy.com/?q=underpowering+speaker
    thats all I have to say about the matter
  6. Aug 17, 2012 at 9:25 AM
    Hillingdoner
    Hillingdoner Well-Known Member
    Rio Rancho, NM
    95 LX xtracab 3.4L 4x4 5spd
    140 amp Cadillac alternator, Audio system in progress, 4Runner map light mirror conversion, foot well lamp addition, buckets and console from 99 Tacoma regular cab, big three, tint
    I would go and listen to both and see what sounds good to you. I like components myself. They can present installation challenges over just bolting in a single speaker as you now have two each side and typically a crossover module each side, but imo worth it. That being said, just got some Crutchfield deal with a unscientific head to head and they were split on which they liked, component or coax. Moral of the story is what sounds good to you is what you should get.
    I would just say to stick with a good brand, look at quality of construction and materials used, efficiency, rms power they are designed for, frequency range, mounting fit etc. and listen to them all.
    When I shop for speakers I take a disc I'm familar with listening to with me and a note pad. I make sure the test hu is set flat, talk to the sales person to find out how their board is built (are the speakers in separate chambers and how big or are they just in an open cabinet etc.), are they being run off an amp, how much power are they getting and then listen subjectively to the speakers. Compare brands, models, sizes. Make notes on my impressions.
    Then I take a break, walk around, go to a quieter part of the store or outside for a bit to give my ears a break. Then go back in and listen again and see if I still get the same impressions or notice something different. I add to my notes and if needed go to the next place in town that has another brand I'm interested in and do the same thing.
    Once done I then review the notes, compare how the speakers will fit within my planned system and go from there.
    Most importantly I'd advise getting your gain structure set correctly in your vehicle. Start with your signal source and then follow through the system to any amps you are adding. Plenty of how-to posts on the audio forums. Alternatively if you did not feel comfortable with doing the gains then you could take it to a decent audio shop and have them do it for you. Would be time/money well spent.
  7. Aug 23, 2012 at 4:37 PM
    Aw9d
    Aw9d That one guy
  8. Aug 23, 2012 at 10:33 PM
    D44boy
    D44boy [OP] Well-Known Member
    Kaneohe, hawaii
    2011 prerunner double cab
    that's a good method.
