7/8
Discussion in '2nd Gen. Tacomas' started by COL. Daniel A. Ness, Jul 18, 2007.
  1. Jul 18, 2007 at 6:12 PM
    COL. Daniel A. Ness
    COL. Daniel A. Ness [OP] Active Member
    Is the Taco about a 7/8 1/2 ton?
    800 lb. bed?
  2. Jul 18, 2007 at 6:39 PM
    flyman767
    flyman767 Well-Known Member
    Tacoma's maximum payload is just over a half ton at 1370 lb...that leaves(assuming an even load) with approx 1000 lbs left for the bed.
  3. Jul 18, 2007 at 8:21 PM
    COL. Daniel A. Ness
    Well then it is a 1/2 ton.
    I did read a 800 lb. load for the bed and a weak tailgate; no specs..
    I know that it is not a Power Wagon. I still have the 1974. But I have abused the heck out of it. I twisted the drive shafts like pasta. Spicer fixed that.
    An IH Combine transfer case replaced stock which spun the front bearing.
    I put three scoops of sand in it. And had the fun of changing out a u joint on the side of the road with poor tools.
    I know the Taco is not up to that.
    But then neither am I.
