7-Pin Trailer Harness/Plug Replacement Tip
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Lute, Jul 25, 2013.
  1. Jul 25, 2013 at 1:53 PM
    Lute
    Lute [OP] Member
    Lute
    Oakland, CA
    05 4x4 V6 TRD DBL Silver 6SP
    Hi All,
    If you break your factory Tacoma 7-Pin trailer plug / harness, you will be sorry to find out it costs about $200 from Toyota for a replacement. Apparently Toyota only sells it as a kit, you cannot get the plug and harness separately.
    I can't take full credit for the following tip; the original post by 'Jake The Wolf' (thanks Jake!) on this website tipped me to the core of the solution, but I thought I'd add my experience to offer a better overview.
    Honda has the identical plug available as a plug w/harness by itself, sold for the Ridgeline. The Honda part # is 32113-SJC-A00 and lists for $49.62. HOWEVER, the connector that plugs into the OEM harness on your truck is different.
    Rather than cut and splice wires, what I did was I disassembled the plug, then swapped the individual pins. To do this, insert a small screwdriver into each of the four slots on the side of the plug body and push the clips out of the slots. Next, use a pair of needle-nose pliers to grab a male blade terminal in the socket, and pull the center plug socket out of the plug body. You will then see a white plastic retainer plate which covers the female blade terminals. Remove the plate by pulling it up with a small hook. At this point, you will see that each female blade terminal is retained into the plug body with a small clip; using a very small flathead screwdriver, gently pull the clip away from the blade terminal while pulling the corresponding wire out the back end of the plug body. One by one, swap each wire w/ terminal from the old plug to the new, and voila- you have an OEM plug with your OEM harness, no need to hack the wiring up!
    GilbertOz, Williston, Nv90 and 16 others like this.
  2. Sep 23, 2013 at 7:54 PM
    colbyrainey
    colbyrainey Well-Known Member
    Colby
    KC
    '11 Dbl TRD Sport
    TSB Leafs, Bilstein 5100's @ 1.75", K&N Filter, Kenwood DNX 6180, BFG Rugged Terrain T/A's, ImMrYo Rearview Mirror Bracket, Extra D-Rings, Gloss Black Stock Wheels, Grillcraft Grille
    Do you have the part number for this kit? Mine is missing both the plug and harness and I'm looking for the best way to find one.
    Scooter WCT likes this.
  3. Sep 24, 2013 at 2:52 PM
    Lute
    Lute [OP] Member
    Lute
    Oakland, CA
    I referenced the part number for the Honda part which can only be used in the manner I described- as a repair for the existing Toyota 7-Pin trailer harness. If your harness is 'missing', I would wonder if it ever had the trailer kit installed in the first place. Toyota sells two different kits which come with the wiring harness, the wiring converter, the bracket and the harness plug- one is the 4-pin style, one the 7-pin style. If you don't already have the hardware in place, I believe you will need to get one of the kits from Toyota, rather than just the plug I referenced above.
  4. Sep 25, 2013 at 4:30 PM
    colbyrainey
    Colby
    KC
    '11 Dbl TRD Sport
    Thanks for the info - I'll look to Toyota for this.
  5. Sep 25, 2013 at 6:19 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    I bought a plug for like $15 at Wally World cut the wires and put some flat spade connectors. I drew a wiring diagram before cutting. I wish Toyota would mount these things in the bumper. I guess that would be too difficult because they would have 2 bumpers. I found that if I leave my hitch in it offers some protection.
    Nv90 and koditten like this.
  6. Jul 23, 2015 at 10:41 AM
    WhiteWalkerTaco
    WhiteWalkerTaco Well-Known Member
    Justin
    Denver, CO
    2015 White Tacoma TRD Off-road
    This is by far the best way to repair the broken trailer connector I have found on TW! Thank you Lute for the directions on swapping the connector! Was a little confused at first but once I realized you were swapping the actual trailer connector and not the connector that connects to the truck's wiring harness (pictures would have helped) it was easy! Still waiting for the Honda harness to come in, but when it does I will already be halfway there! Much better route than splicing in an aftermarket connector!
  7. Jul 24, 2015 at 9:19 AM
    ranger098
    ranger098 Well-Known Member
    Brian
    Minnesota
    http://www.napaonline.com/Catalog/C...Adapter-Tow-Vehicle/_/R-NDP7552145_0373950438
    This is literally the exact same part that comes on the truck from the factory, right at Napa. (the second image on napa's site isnt the same as what i got, might be a slightly different product in store). Heres a step by step:
    take the harness out of the mount on the truck (8mm bolts i think), and disconnect the harness up behind the bumper so you can go to your workbench with it.
    use a flathead screwdriver to remove the one screw holding the outside housing on the harness, and push on the wires to pop the housing loose from the plug.
    Cut the exposed wires as short as possible, leaving a little of the colored jacket to reference the wire locations
    strip the ends of the wire and put them into the new harness, following using the old harness to see where to connect each wire (you could use a spade connector or something if you like)
    install back into the trucks mount, and use elecrical tape to seal up the hole where the wires enter the housing so water doesnt get in there.
    I was shocked and sooo happy to see this harness at my local napa store. My old harness had salt and water getting in there and corroded the wiring so bad that certain wires were totally disconnected. This is a direct replacement and costs like 10 bucks!
    Williston and taco_yoda like this.
  8. Feb 3, 2016 at 10:54 PM
    iJDub
    iJDub Well-Known Member
    Anyone have the wiring diagram for this? I had taken the wiring out before tagging it and I don't think the colors align with the standard colors cause one of them was switched around when I was using a 4 pin setup.
  9. Apr 28, 2016 at 7:37 PM
    Whiplash777
    Whiplash777 Well-Known Member
    Upstate NY
    '09 Blue Double Cab Off Road
    Side steps, DRLs, DynoLock
    I just completed this swap out today using Lute's instructions in the first post.
    Here is the new Honda harness:
    There is a nice L-cover over the rear of the plug (the one on my truck was missing):
    Pop the clips and you get this:
    The four clips to hold the core of the plug:
    Removing the core of the plug:
    Here is the removed plug and the O-ring that seals it:
    Here is the socket with the plug core removed:
    I carefully used a pair of needlenose pliers to remove the white internal cap (the tolerances are tight and it is a little tough to get out):
    Internal base with white cap removed:
    I got tired of holding the door open and trying to work in the plug so I carefully put a pair of locking pliers on it:
    The back of the plug:
    Using a small screwdriver to release the clips on the base connectors:
    Some of the wires removed:
    All wires removed:
    Completely disassembled:
    Reassembled on the truck:
    And here is why I needed to replace it (what's left of the old one):
    The old retaining bolts sheared off, but the new plug is such a tight fit (I actually needed to use a rubber mallet to get it fully back in place) that I knew it wasn't going anywhere.
    I hope the photos help.
  10. Apr 28, 2016 at 7:43 PM
    TACOVRD
    TACOVRD I Identify As A Prius
    TW Addict
    AZ/WA
    2019 T4R ORP - Formerly 2013 DCSB OR Spruce Mica
    Workin' on it....
    Tagged for future reference if needed... :thumbsup:
  11. Apr 28, 2016 at 11:19 PM
    IronPeak
    IronPeak PermaLurker
    AuggieX
    Back to Back
    2007 sr5 4x4 DCLB/2015 TRD sport 4x4 DCLB sold
    Bigger Taller Slower
    I like the OP solution, nice and cheap and keeps it factory..most important for most folks no wire cutting stripping....
    this is the route i went
    Destroyed mine on a rock, found this replacement for 22$, it upgrades the factory 7 round to 7 round and 4 flat, that overs 95%of towing ,then moved it. Where toyota hung these off the rear bumper is a known flaw, and as the OP noted, they want 200$ to replace it, nonsense. This mod does require cutting the wires at the old plug, the replacement plug below has screws to seat the wires, or use round ends, or round ends and solder, which is what I did .... kookoo I know.
    http://www.amazon.com/Hopkins-48470...psc=1&redirect=true&ref_=od_aui_detailpages02
    Also requires hole saw or dremel if you want to do this step --Then I cut a hole in my bumper between my plate and plate light, mounted it there out of harms way.
  12. Sep 13, 2016 at 10:36 PM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Thanks for this, super helpful, just a question, do the wires only fit into one slot? So when you reinstall the Tacoma wires you can't mess it up?
    Kolter45 likes this.
  13. Sep 13, 2016 at 10:48 PM
    WhiteWalkerTaco
    Justin
    Denver, CO
    No, they can fit in different slots, but the wire colors are virtually the same and they are pinned the same so just match the pin assignment from the Toyota one to the Honda one and use wire colors as a guide. You should be golden!
  14. Sep 14, 2016 at 7:33 PM
    Kerrigan911
    Kerrigan911 Well-Known Member
    Dan
    05 TRD OR, AC, 4x4, V6
    I went on Amazon and bought tow ready 20119 for $25. Cut the one plug and cut my busted toyota plug off. Then i used a multimeter to verify what wire goes to each pin. Finally solder wires and good to go. I also now have a 4 pin as well as the 7 pin
  15. Jan 14, 2017 at 7:39 PM
    NiteTaco
    NiteTaco Well-Known Member
    North Alabama
    09 TRD DCSB
    Finally got around to doing this swap using the Honda part number today...great write-up! I would add that the only real challenge I had was getting the white insert out without chewing it up too badly. I found that if you take a thin metal coat hanger and bend a very small hook into the end of it with some pliers, you can use the hanger like a puller. You can fit it into little triangle holes and hook it from behind...hopefully this helps some else too.
    BTW, I'm also working on relocating it into the DS license plate light hole...hopefully tomorrow.
    TOMB, Taco*Sauce06 and motormike like this.
  16. Mar 30, 2017 at 3:43 PM
    Bunio26
    Bunio26 Member
    Anthony
    2015 silver tacoma trd off road
    Light bar (more on the way)
    I am doing this replacement now, but having trouble getting mine disconnected so that I can do the switch! Please help! Thank you
  17. Mar 30, 2017 at 3:50 PM
    Sand Shark
    Sand Shark I dont pub crawl.when I do,I use pub crawl control
    Erich
    Phoenix, AZ
    2017 Blazing Blue DCSB Off-Road (yes I get dirty)
    REI VIP Parking Pass,Pavement Avoidance System
    Badass write up...
  18. Mar 30, 2017 at 4:12 PM
    03f5sp
    03f5sp Well-Known Member
    Bill
    Wisconsin
    2011 TRD Off Road dcsb
    Front 5100s @ 2.5, 1.5 AAL, 265/75-16 all terrains
    I bought a replacement plastic housing at Napa for $5 and mounted it in place of the license plate light. It looks factory and eliminates the possibility of smashing it again.
    TRDSport10 likes this.
  19. Apr 1, 2017 at 8:57 AM
    rjaneway34
    rjaneway34 Member
    South Florida, USA
    15 Blue Ribbon TRD Sport DCSB
    SCS Stealth 6 Wheels 265/70 R17 Duratracs Bilstein 5100's @1.75 Fold-A-Cover G4 Elite WeatherTech Floor Mats Rough Country Step Bars WeatherTech Window Deflectors
    Thank you, OP. I completed this fix this morning and couldn't be happier!
  20. Jun 2, 2017 at 1:39 PM
    cbannister83
    cbannister83 I'm a d**che
    43S GT 59500 92000 ish
    DCSB
    Loading...
    Quick question for anyone that might know off hand. What color wire gives power to the reverse lights on the trailer? I have a 2014 if that makes a difference..
    Thanks
