7300 miles and leaking AGAIN
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dirthawker1313, Dec 15, 2007.
  1. Dec 15, 2007 at 2:20 PM
    dirthawker1313
    dirthawker1313 [OP] Well-Known Member
    some of you may remember my original post from about 3 weeks ago. my 07 DC had developed a leak at the input shaft on the transmission. well i took it to the dealer and they replaced the seal. they told me the seal was warped and it was no big deal. well 3 weeks later the seal is leaking accompanied with a nice thunk noise and feeling. it will be going back to the dealer on Tuesday for this and for my TSB SU006-007. of course the dealer never called me to let me know the parts were in for that. i hope this thing dosent leak a third time. isnt there a federal law about having the same problem 3 times?
  2. Dec 15, 2007 at 2:24 PM
    concrete jedi
    concrete jedi Well-Known Member
    Rochester N.Y
    06 Tacoma 4 door indigo blue
    Broken and scratched tailgate, cracked rear tail light lens, coffee stain in driver seat.
    Your report is grim, I am thinking that if it leaks again it's more than a seal, I would have them look at it to determine what is making the seal fail. :(
  3. Dec 15, 2007 at 4:20 PM
    humanoid
    humanoid bite me
    Sunny SoCal
    I had a '99 Xtra Cab PreRunner SR5 V6
  4. Dec 15, 2007 at 4:35 PM
    dirthawker1313
    thanks for the link. and trust me i will...:mad:
  5. Dec 16, 2007 at 6:31 AM
    TACOMA915
    TACOMA915 Active Member
    +1 They may just replace the entire transmision this time. It could be a line bore problem.
  6. Dec 16, 2007 at 2:35 PM
    ellsworth
    ellsworth Well-Known Member
    Buffalo
    08' off rd 6 speed
    6 inch Fabtech, st stabilizers, 18x9 DC -1s 305/65/18 bfg at's
    OUTPUTSHAFT SEALS ARE PRONE TO LEAKS FROM ALL SORTS OF REASONS..IT MAY BE BEING INSTALLED INCORECTLY..OR THE NEW SEAL GOT KNICKED REINSERTING THE SHAFT..ASK TO SEE THE SPECIAL TOOL THEY USE TO INSTALL IT..IF THE TECH HAS NO AWNSER OR CANT PRODUCE THE TOOL FIND A NEW DEALER..IVE SEEN ALOT OF TECHS BANG SEALS IN WITH A HAMMER AND DRIFT OR A BIG SOCKET THAT FITS THE OUTSIDE CIRCUMFRENCE..GET IN TOUCH WITH THAT DEALERS TOYOTA SERVICE REPRESENTETIVE WHO CALLS ON THAT DEALER NOT A DEALER EMPLOYEE OR DEALER MANAGER..THEN THE REP WILL CONTACT THE SERVICE MANAGER AND WAIT TO SEE HOW FAST YOUR TRUCK GETS PREFERENTIAL TREATMENT...TRUST ME I KNOW...
  7. Dec 16, 2007 at 2:52 PM
    dirthawker1313
    yea the tool is called a seal driver i own a set. but its not just the seal. seals dont make a large KLUNK that you can hear as well as feel. there is a reason it failed the first time wich i believe is the reason it failed the second time. i heard and felt the same sound both times it failed.
  8. Dec 16, 2007 at 3:08 PM
    Nitro_rc
    Nitro_rc Active Member
    07 DoubleCab TRD Sport 4X4
    Weird that with a new in seal installed that it's still leak. I would question the dealer to see if they really change the seal. If they did, then there is something wrong with the output shaft bearing/bushing. If this bearing/bushing is bad, no matter how many new seals you change out, with in a couple weeks of driving, the new seal will be ruin. Try moving the drive shaft side-to-side and up-down motion, if moves alot then the bearing is bad.
  9. Dec 18, 2007 at 11:42 AM
    dirthawker1313
    well its at the dealer. ill let you know how it turns out. there also doing the suspension TSB at the same time.
  10. Dec 19, 2007 at 7:16 AM
    cuzv
    cuzv Member
    Right - If they cant fix the same problem after 3 tries, you have the legal right to demand a replacement (which wouldnt be so bad, considering the bad luck you've already encountered). Good luck
  11. Dec 19, 2007 at 12:43 PM
    dirthawker1313
    they are replacing the tail shaft assembly on the transmission. it should be ready today. ill will keep you all informed.
