$75 eBay "tailgate reinforcement"
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTuesday1, Aug 23, 2020.
  1. Aug 23, 2020 at 11:18 PM
    TacoTuesday1
    TacoTuesday1 [OP] Well-Known Member
    FL
  2. Aug 23, 2020 at 11:23 PM
    BKinzey
    BKinzey Well-Known Member
    Beauford
    Hollywierd, CA
    2015 White Tacoma Access Cab TRD Off Road 4x4 V6
    RCI aluminum front skid, SnugTop, Sliders, bedside supports, LED interior, CaliRaised fogs & brackets, rear diff breather mod, DIY bed platform
    Looks like it would work, also looks like crap. Check the thickness, this one is 1/16".
  3. Aug 24, 2020 at 4:35 AM
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    Looks like crap and makes my knees hurt thinking about crawling into the bed to grab something. I've got a couple of bags of paver sand in the back of my truck right now, I can imagine dragging them out over that with those bolt heads would probably elicit some words that the neighbor's kids don't need to hear.
    Naveronski likes this.
  4. Aug 24, 2020 at 5:34 AM
    Pigpen
    Dan
    Northwest Montana
    Plywood would be more practical.
  5. Aug 24, 2020 at 5:39 AM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    I think it looks like crap, on par with Autozone glue-on chrome.
  6. Aug 24, 2020 at 5:42 AM
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    Not sure why youd want to put a molle panel there. Sure you could attach stuff when the tailgate is closed, but when its open, that stuff is just in the way. And like someone else said.. thickness
  7. Aug 24, 2020 at 6:13 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Where's the strength in that? It's a flat sheet? If it was bent to fit over the top it would be a hell of a lot stronger
  8. Aug 24, 2020 at 6:14 AM
    Taco Wake
    Taco Wake Well-Known Member
    South Carolina
    Looks like the bottom portion would get filled with dirt/debris and the only way to clean would be to remove the reinforcement panel. I'll pass.
  9. Aug 24, 2020 at 9:59 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    wont do a damn thing for reinforcement.... flat sheet n all.
  10. Aug 25, 2020 at 6:50 PM
    CraigF
    CraigF Well-Known Member
    Craig
    Oak Grove, OR
    06 AC PR OR 4.0L
    none yet
  11. Aug 25, 2020 at 8:14 PM
    Notoneiota
    Notoneiota Well-Known Member
    Oakdale, MN
    14 Tacoma DCLB TRD Sport
    Mostly stock with a few minor mods.
    Looks horrible. I'd put it under the existing cover. Not over it.
    Alexely999 likes this.
  12. Aug 25, 2020 at 8:17 PM
    rascott95
    rascott95 Well-Known Member
    Dallas, TX
    2019 DCSB TRD Off Road
    That looks like a class A knee destroyer.
    Grossomotto likes this.
  13. Aug 25, 2020 at 10:47 PM
    SANTOS562
    SANTOS562 Well-Known Member
    Los Angeles, CA
    2008 Tacoma PreRunner Long Bed Double Cab
    3” Toytec front lift, 2” rear blocks, iridium plugs, fender turn signals, HID reverse lights, BFG T/A KO2 285/70/17, chrome oval solid nerf bars
    :rofl::rofl::rofl::rofl:
  14. Aug 25, 2020 at 10:51 PM
    SANTOS562
    Los Angeles, CA
    I don’t understand the need for it. Tacos have a great liner already. What would be the point of that: a spider nest, gravel catcher, butt scratcher...I just couldn’t pick a more useless need for it.
  15. Aug 26, 2020 at 7:04 AM
    rkd
    rkd Active Member
    Andrew
    Orlando, FL
    06 AC Tacoma TRD Sport 4x4
    Doesn't look like that would do much
  16. Aug 26, 2020 at 10:11 AM
    Gen2 Man
    Gen2 Man Well-Known Member
    Midwest
    07 Sport DCLB
    3rd Gen Sport wheels
    Sounds pretty negative in here. The city boys with mall crawlers can’t even imagine what this might be for. If I designed one it would be about twice as thick and use countersunk fasteners. Also use a beveled edge so as not to catch when unloading bags of sand. Finally bring it up over the top of tailgate because that right angle would add more strength.
    I used to haul round bales of hay and dry they weigh hundreds of pounds but wet it’s even worse. Rolled one off the back and that wimpy tailgate does flex in the middle, I know this from experience LOL so don’t find out the hard way like I did.
  17. Aug 26, 2020 at 11:04 AM
    zaitsev77
    zaitsev77 Member
    Frack
    Ohio
    2006 PreRunner
    I've been thinking I didn't have enough crevices to catch dirt. :crazy:
  18. Aug 26, 2020 at 11:10 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    MD/GA
    2nd gen
    More import garbage from Hooke
    lmao my favorite part about this piece of junk is the screws for the sides don’t even appear to have spacers or anything, so you’ll have probably a centimeter of just exposed screw threads.
  19. Aug 26, 2020 at 11:15 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
