75W-90 Royal purple in 2011 front & read differentials
Discussion in '2nd Gen. Tacomas (2005-2015)' started by iliketurtles, Apr 23, 2013.
  1. Apr 23, 2013 at 3:34 PM
    iliketurtles
    iliketurtles [OP] Well-Known Member
    I bought some crush washers at the dealership and the parts guy told me I don't need to change the fluid since I've only got 37k miles on it and that I shouldn't put 75W 90 in it because it calls for 75w 85.
    How many have done what I'm about to do and put a lot of miles on it without problems? He said it's $50/quart and I told him that I think it's a gimmick by Toyota to get more of my money since I can seem to find the shit anywhere but the dealership.
    REAR diff..input read in the subject
  2. Apr 23, 2013 at 3:51 PM
    wyotaco06
    wyotaco06 Well-Known Member
    Offroad 4x4 06
    $50 a quart is a complete ripoff. Mobil 1 or Amsoil severe gear 75w 90 is $10-20 a quart, and a lot of people use these fluids in there T case and diffs.
    15K is the recommended mileage for the rear diff. I always change mine at 15K. I used to change the T case and front diff at 15K as well, but since the fluid came out very fresh looking every time I did them, I save the front diff and T case for 25-30K. If your at 37K, you should do all three at once. Its very simple to do them, and it will save you some money to DIY.
    I used Royal P in the rear once, and it was $20 a quart. I swear that it made my rear diff howl just a tad, and after research on Royal P's lubrication properties, I have been using either Mobil 1 or Amsoil.
  3. Apr 23, 2013 at 3:55 PM
    iliketurtles
    Thanks man. The guy told me the service interval for the front diff was 100,000 miles. I have royal purple in the rear diff and haven't noticed any noise so far. I've only put about 30 miles on it, though.
  4. Apr 23, 2013 at 3:59 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I used plain old 75-90w Valvoline oil for my rear differential and bought a couple ounces of LSD fluid since my truck is a Sport model. I used Redline full synthetic for the front diff and transfer case.
  5. Apr 23, 2013 at 5:46 PM
    iliketurtles
    Looks like I'm not changing the front diff oil today. One of the bolts on the skid plate is stuck on there pretty well. I tried PB blaster, and when that didn't work I decided yanking on the socket wrench might do it and I stripped the bolt. Fml.
  6. Apr 23, 2013 at 6:35 PM
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
  7. Apr 23, 2013 at 6:58 PM
    93civEJ1
    93civEJ1 Well-Known Member
    09 DC TRD OR
    Procomp 6" Stage 1, Bilstein 5100's in front, flowmaster 40 series
    Breaker bars or something on the wrench works wonders. You will be fine with 75 90. I just changed all three on mine. All looked good except mainly the front oil looked dark. I replaced all 3 of mine with 75w-90 castrol syntrax gear oil.
  8. Apr 23, 2013 at 7:42 PM
    DirtEater
    DirtEater Well-Known Member
    Surprise, AZ
    Royal Purple has crazy pricing on their gear oil. Their motor oil is slightly higher than most, but their gear oil is outrageous. Didn't used to be. Last time I bought RP 75W90 was about 4 years ago and it was $10.99. I still have one quart left from that purchase. I'd never buy it now that they want $23 a quart, when you can get Amsoil Severe Gear Oil for $11, or Mobil 1 for the same price. A pretty purple bottle with a yellow top doesn't warrant double the price.
  9. Apr 23, 2013 at 9:11 PM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    You'll be fine with 75w90 though I think royal purple is a bit of a gimmick myself.
  10. Apr 23, 2013 at 9:17 PM
    iliketurtles
  11. Apr 24, 2013 at 5:15 AM
    93civEJ1
    09 DC TRD OR
  12. Apr 24, 2013 at 7:04 AM
    rickc5
    rickc5 Well-Known Member
    Rick
    Whitewater, CO
    2021 Tacoma TRD Pro
    none
    Be sure to coat the threads on the skid plate bolts with anti-sieze compound before re-installing them. It will keep the bolts from rusting in place and make them easier to remove next time.
  13. Apr 24, 2013 at 9:32 AM
    rhavin42
    rhavin42 Well-Known Member
    Vladimir
    Phoenix, AZ
    09 DC LB SPORT 4x4
    x2 Cept I used the Valvoline all around. did it 30k miles ago no issues, coming due on the 60k change and I'll do the same thing again.
