8.4" vs 8" E-Locker R&P
Discussion in '2nd Gen. Tacomas (2005-2015)' started by RevoTaco, Aug 11, 2014.
  1. Aug 11, 2014 at 12:41 PM
    RevoTaco
    RevoTaco [OP] Well-Known Member
    SoCal
    Sold - 08 6SP 4x4 AC TRD Off-Road
    I'm still trying to understand this...I've done hours of searching and reading and still can't fully understand what I am looking at.
    Here is what I understand so far:
    E-Locker trucks have 8" R&P (Basically TRD ORs)
    All other trucks have 8.4" R&P - Actual size measures 8" but it's stronger so it's listed as 8.4
    Questions:
    Since the 8.4" is really 8" in diameter, does this mean the tooth count is the same? In that case, doesn't this mean the gearing is IDENTICAL between the two?
    If it's the same gearing between the two does this mean the front end of E-Locker trucks can have a 8.4" R&P swapped in (assuming same gearing) and work just fine? Is it confirmed the front end of a E-Locker truck has an actual 8" diff and not just an 8.4"?
    Thanks!
  2. Aug 11, 2014 at 12:54 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
  3. Aug 11, 2014 at 6:58 PM
    RevoTaco
    SoCal
    I read that whole thread and it didn't answer either of my two questions.
  4. Aug 11, 2014 at 7:09 PM
    RevoTaco
    SoCal
    Through some more searching found some more information. It seems that all trucks TRD or not have the same front end if they are 4x4 - so the basic answer is, we have no choice but ARB for the front diff, huh?
  5. Aug 11, 2014 at 7:12 PM
    RevoTaco
    SoCal
    I'm aware of that but I don't want to bother with an air supply.
  6. Aug 11, 2014 at 7:16 PM
    Large
    Large Red
    Front diffs are the same, the only difference is the 4 cyl's have 4.10 gears (41 teeth) and the 6 cyl's have 3.73 gears (37 teeth).
    The ring and pinions are the same size (I think) but the base SR5 / Sport axles housing is a little larger (8.4" vs 8"), probably due to the e-locker in the O/R. You have more options than an ARB air locker in the front and rear. Look up lunchbox or lockrite.
  7. Aug 12, 2014 at 12:09 AM
    RevoTaco
    SoCal
    Basically, yes. I want an Aussie locker type of locker for the front of my Taco.
  8. Aug 30, 2014 at 7:05 AM
    Ghost848
    Ghost848 Well-Known Member
    Tony
    Alberta,Canada
    09 V6 TRD OR Silver M6
    OME + Dakers, 285/75R16 Nitto Trail Grapplers, ARB Bumper, Columbia overland Dual battery, Super winch,CC stage 4 clutch, bestop supertop, URD TO bearing, BHLM headlights, Cruisin offroad rear bumper, Harrop front E-locker.
