8 Gang Switch Panel - Auxbeam/Amazon
Discussion in 'Lighting' started by dpele, Dec 4, 2019.
  1. Feb 21, 2023 at 4:21 PM
    #381
    Hayden334
    Hayden334 Well-Known Member
    Hayden
    Cullman, Alabama
    2010 Tacoma DCSB TRD OR
    2" spacer lift, 285/70 R17's and a Softopper.
  2. Feb 21, 2023 at 4:47 PM
    #382
    jackn7
    jackn7 Old Man Tan Taco
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    I bought the six simply because I don’t plan on installing as many lights as other people. Replaceable relays was a nice bonus.
    Tacodude79[QUOTED] likes this.
  3. Feb 21, 2023 at 6:14 PM
    #383
    JKO1998
    JKO1998 Well-Known Member
    Utah
  4. Feb 22, 2023 at 7:08 AM
    #384
    dpele
    dpele [OP] Pele Prints Vendor
    Dan
    Edmonton, Alberta
    2010 Tacoma DCSB
    Elka 2.0 w/ OME Dakars, 285/70/R17 Duratracs, & more!
    I had an 8 gang generic Amazon one and I accidentally blew one of the relays. I replaced it with an 8 gang Auxbeam with the app. I use the app way more than I thought... and I like that I can match the panel backlight colour to orange like everything else in my cab.
    Both of them perform(ed) great!
  5. Feb 22, 2023 at 11:34 AM
    #385
    Tacodude79
    Tacodude79 Member
    2022 Tacoma AC 6MT TRD OR
    Also, for anyone that has one of the Auxbeam or other Amazon panels, have you noticed any parasitic draw from the panel while the truck has been turned off?
  6. Feb 23, 2023 at 5:29 AM
    #386
    Brownie_Man
    Brownie_Man Well-Known Member
    Maine
    2019 Off Road
    I have not.
  7. Feb 23, 2023 at 6:36 AM
    #387
    jackn7
    Art
    So Cal
    2008 DCLB 4x4
    Just some stuff...
    Nope. But if there was I would assume it would be so little that I wouldn’t notice.
  8. Feb 27, 2023 at 3:26 PM
    #388
    BigCountry762x39
    BigCountry762x39 Well-Known Member
    TL
    PNW, Oregon!
    2009 Tacoma, with the cool white paint peel
    Arb Deluxe bull bar Front Bumper Ironman4x4 12k winch synth line AFE Intake OME 2.75in Dakar Leaf springs (R) Fox 2.0 bypass shocks (R) Bilstein 6112 (F) 33's on KMC wheels off road lighting comfort mods Redrock HD roof rack Retevis rt95 Radio Slotted Rotors and HD pads
    so I've held and looked over the Auxbeam and the slightly cheaper Nilight versions and i cant tell a difference. the 6 button one same deal I've the 6 buttons in my Tacoma
  9. Feb 28, 2023 at 7:33 AM
    #389
    Fonzy77
    Fonzy77 Well-Known Member
    California
    2007 White Tacoma
    Hey man just got the same one you have! Almost done with the install, I’ll finish when I’m off work. I have a question with the load harness, maybe you could help. Each switch has two corresponding red wires, do both get connected to the positive wire of the light or accessory? And did you just ground the light/accessory ground wire somewhere to the frame?
  10. Feb 28, 2023 at 7:45 AM
    #390
    Technique
    Technique Well-Known Member
    Alex
    Utah
    2017 Silver Offroad DCSB
    -285/70/17 Toyo AT3 -Tuned
    Awesome! That's correct. I took both red wires and wired them to an accessory. I then took the ground from each accessory and used the stock grounding point right near the battery. Ideally, I would like to get a bus bar for all my ground cables but that's a project that has not come to fruition yet lol.
  11. Mar 1, 2023 at 12:00 PM
    #391
    Fonzy77
    California
    2007 White Tacoma
    Appreciate the help! Took your idea and went out and got a bus bar for all my grounds to keep the wiring nice and clean. I ended up blowing a couple fuses while I was testing my lights, (completely my fault for not double checking amps) but this got me thinking if it would be possible to upgrade the fuse and relay for a switch from a 5amp to 20amp. Gonna do some more research on this, what do you think?
  12. Mar 29, 2023 at 5:59 AM
    #392
    PlataTaco
    PlataTaco Well-Known Member
    Cole
    SoCal - Coachella Valley
    Silver 2015 DCSB Limited
    Planning to install an 8-gang in my 2015 and potentially mount it in one of the sunglass holders. I know it's a relatively common spot but I'm curious about a couple things if anyone can give some advice. Mostly trying to find out if there's enough clearance that I could still close it up to keep the switch panel out of sight when not in use. Also wondering if anyone has tried the Auxbeam RA80 XL model, it's an 8-gang RGB panel but has larger buttons and doesn't connect to an app. Seems like it should fit in the sunglass holder based on the dimensions and my rough measurements but it's hard to tell for sure.
  13. Apr 12, 2023 at 12:55 PM
    #393
    Irishblessing
    Irishblessing So Cal Is Where My Mind States
    2023 Tacoma OR
    Has anybody who has added a fuse under the hood fuse box found a good place to route it without cutting the box, so I can actually close the box completely?
  14. Apr 12, 2023 at 5:58 PM
    #394
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    Around minute 13 he shows how to run the wire next to the main loom coming out of the box.
    https://youtu.be/yPhmb4ad5vk
    TomTwo and Irishblessing[QUOTED] like this.
  15. Apr 13, 2023 at 7:30 AM
    #395
    Irishblessing
    2023 Tacoma OR
    Thank you, thats exactly what i wanted.
    ssd2k2[QUOTED] likes this.
  16. Apr 13, 2023 at 12:17 PM
    #396
    ssd2k2
    Keith
    Minnesota
    No problem, I just got done doing my Auxbeam and was going to wire it into the hood fuse box so the video was still in my youtube history.
    Though I couldn't find a fuse that was ignition controlled so I just ran the wire to the box under the steering wheel.
    Irishblessing[QUOTED] likes this.
  17. Apr 13, 2023 at 12:23 PM
    #397
    Irishblessing
    2023 Tacoma OR
    I have been using the INJ-either 10 or 15 Amp fuse- under the hood to power my Raptor lights, I was going to use that for the 8 gauge when I get it.
    I had done something similar to the video but instead just lifted the plug and routed it underneath, the plug doesn't go down all the way-It's temporary- so this is a much better permanent fix.
  18. Apr 22, 2023 at 7:15 AM
    #398
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I mounted my 8 gang controller in the eyeglass holder. When cutting the slot for the wire, make it long enough for the full range of opening and closing the holder. I use velcro to hold the controller in place. Velcro holds it real good. Took a wheelin trip to Moab and the controller never moved.
    Hope this helps. I just found our post.
    PlataTaco[QUOTED] likes this.
  19. Apr 22, 2023 at 7:53 AM
    #399
    JKO1998
    Utah
    Anyone ever hook up a locker to one of these?
  20. Apr 23, 2023 at 6:58 AM
    #400
    PlataTaco
    Cole
    Thanks! Looked like it would work fine but I was hoping someone around here had tried it just to confirm. Do you notice the holder swinging around much if you leave it open when you're out wheeling or does it stay fairly still?
