(805) TW Members Thread
Discussion in 'Southern California' started by jblaze805, Feb 25, 2011.
  1. May 20, 2013 at 9:52 AM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    Or just turn wrenches when your not in the shop lol
    I'm thinking Devin is a little confused it'll prob work for re-filling tires when you leave the trail.
  2. May 20, 2013 at 10:03 AM
    05tundra13
    05tundra13 Well-Known Member
    Devin
    Simi Valley
    05 tundra doublecab
    "This compact vehicle mounted compressor has been designed to do everything! Activate your ARB Air Locking Differentials, air up a 35" tire in less than a minute and run air tools. This 100% duty cycle, 6.16 CFM compressor is built to support all of your compressed air needs. The CKMTA12 and CKMTA24 twin on-board compressor kits were designed to fill the off road markets need for a compact sized yet high-volume compressed air source to suit the high volume airflow needs of most air powered tools, and also to suit the actuation and control needs of the ARB Air Locker, and the harsh and demanding environment of the ARB Air Locker user." am i wrong on it being able to use air tools still? I may need the extra air tank then if so.
    thats what i am going to be using it for mainly...just thought id be able to get my tires off a little faster too. guess ill just have to wait and see.
  3. May 20, 2013 at 11:20 AM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Depends on which air tool.
    My impact and air ratchet consume WAY beyond 3 CFM which is all the ARB air compressor is good for (at only 90psi none-the-less). It is 100% duty cycle tho...as long as you're not in the desert :cookiemonster:
    But yes...refilling tires will be a walk in the park. Just don't expect too much from the "air tool" department unless you're running an air brush or a 1/4" ratchet.
  4. May 20, 2013 at 1:03 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    Anyone rolling to the Mackenzie's 500 this weekend?
  5. May 20, 2013 at 3:12 PM
    Cr250jumper
    Cr250jumper Señor member
    The moon
    50 shades of tan©
    Tacoma with some stuff melted to it
  6. May 20, 2013 at 3:15 PM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
  7. May 20, 2013 at 3:26 PM
    Cr250jumper
    The moon
    50 shades of tan©
    I see them using them in the pits at NHRA so they must have plenty of torque. You can get the Dewalt one for about $225 with battery and charger or $150 if you already have batteries
  8. May 20, 2013 at 3:29 PM
    santabarbarataco
    jordan
    santa barbara
    they can torque to over 400ftlbs a bit excessive but they are nice.
  9. May 20, 2013 at 3:40 PM
    rnance85
    rnance85 Member
    Ventura
    09 PreRunner TRD
    Maxtrac Spindle Kit Billstein 5100's AAL DVD System Navigation
    Hi guys! Newbie here to the forums and I need some help from the 805 crew. I recently bought a 09 PreRunner but cannot stand the look of the stock height. Thus, I'm am in the market for a lift kit. I'm trying to stay around $1000, and want the best bang for my buck. What lift kits would you guys suggest? I know I can do the 5100's and add 2.5" to the front, but I am hoping for more...if possible, within my budget. Also, I live in an apartment and have no place to install the lift myself which will add additional cost to the install. To be honest, I"m hoping for more like 4", so any help with ideas would be greatly appreciated. Also, and place you reccommend locally (Ventura) that could do this. The people at Ventura 4x4 seem great, but I am widly open for suggestions! Thanks in advance...
  10. May 20, 2013 at 3:44 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    maxtrac spindles! they are 510$ and then install a aal in the back and bilstein shocks all around...should be under 1k...i had that setup and its great
  11. May 20, 2013 at 3:51 PM
    rnance85
    rnance85 Member
    Ventura
    09 PreRunner TRD
    Oh really? How much height would you say it gives? Any pictures by chance?
  12. May 20, 2013 at 3:52 PM
    CayucosTacoma
    CayucosTacoma Just think outside the Yota
    San Luis Obispo/San Jose
    2004 Double Cab 4x4
    Specs in the Build Thread
    http://www.tacomaworld.com/forum/group-buys/277075-maxtrac-spindles-gb-headstrong-off-road.html
    There's a start^^
  13. May 20, 2013 at 3:52 PM
    anthony250f
    Anthony
    San Diego, CA
  14. May 20, 2013 at 4:00 PM
    rnance85
    rnance85 Member
    Ventura
    09 PreRunner TRD
    Thanks guys! That looks great. Any recommendations on a place to have it installed?
  15. May 20, 2013 at 4:01 PM
    CayucosTacoma
    2004 Double Cab 4x4
    JMFAB :p
  16. May 20, 2013 at 4:03 PM
    anthony250f
    Anthony
    San Diego, CA
    i know how to do it...its not to hard...just rent a tie rod puller and get brake fluid for the brake lines
  17. May 20, 2013 at 4:04 PM
    DTFtacoma
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    :cool:
  18. May 20, 2013 at 4:04 PM
    CayucosTacoma
    2004 Double Cab 4x4
    Oh brake lines
  19. May 20, 2013 at 4:06 PM
    santabarbarataco
    jordan
    santa barbara
    i have a tie rod puller :cool:
  20. May 20, 2013 at 4:07 PM
    anthony250f
    Anthony
    San Diego, CA
    you have the pitman arm puller....does that work for 2nd gens? i cant remember
