(805) TW Members Thread
Discussion in 'Southern California' started by jblaze805, Feb 25, 2011.
  1. May 8, 2014 at 3:03 PM
    santabarbarataco
    santabarbarataco Well-Known Member
    jordan
    santa barbara
    just fix it. it will take 15 minutes. don't trust the dealer in 5 years to replace your frame if it rusts. like anthony says, our trucks are on the beach ever weekend sometimes and aren't rusty at all. just takes some time and maintenance
  2. May 8, 2014 at 5:29 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    Yeah I guess I should do it. Just read through some threads and it seems hit or miss but some did get a new frame or buy back. I've driven in a few feet of saltwater before which is probably why this is happening already. Makes me feel like it may be a lost cause.
  3. May 8, 2014 at 5:48 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    ^ I don't know what year you have, but I have a 12' and since I've gone through sea water many times as well I have surface rust all over the frame. I'm planning on doing everything in the next few weeks as well. Just gotta make sure to get it done before it gets anything more than just surface rust...
  4. May 8, 2014 at 5:52 PM
    santabarbarataco
    jordan
    santa barbara
    Salt water isn't bad, but you must was it off right away. If the salt was left on the truck most likey your cause if rust. Salt is very corrosive but as long as you treat the effected areas you'll be fine. Just stay on top of it and don't let the rust turn into cancer
  5. May 8, 2014 at 5:55 PM
    TacoBrah
    Sean
    What is your plan of attack?
  6. May 8, 2014 at 6:14 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Haven't thought about it too much but probably just do it when I go through my suspension next. Just going to take susp completely off and attack as much rust as I can get to. Then paint. It doesn't have to be too crazy. You'll notice some areas are more prone to rust than others, so you can double up on the undercoating.
    Haha. You can do mine while I micromanage with beer in hand! Haha ;)
  7. May 8, 2014 at 6:54 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    I've driven in salt water up to the doors...always wash it underneath Immediatly...zero frame rust
  8. May 8, 2014 at 7:40 PM
    RJALLDAY702
    RJALLDAY702 U MAD? OH U MAD
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    :bananadead:
  9. May 8, 2014 at 7:48 PM
    ntydog13
    ntydog13 Well-Known Member
    Alex
    Santa Barbara
    86 4x4 long travel pick up
    Lc engineering power pack, total chaos gen 2 caddy kit, 2.5 race runners, deaver f67, total chaos 12in shackles, king 2.5 double bypasses, corbeau baja ss fixed back seats
    Jesus Christ what happened there!?! Did the guy get stranded in the ocean for a few days
  10. May 8, 2014 at 8:27 PM
    TacoBrah
    Sean
    I didnt wash mine after a few of the times I went in the water. I dun goofed.
    Gonna wire/sand it down then prime and either paint or bedliner spray it. Not gonna use undercoating, I read some bad things about it.
  11. May 8, 2014 at 8:28 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    Rust Cure Formula 3000
    You're welcome
  12. May 8, 2014 at 9:57 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    Coming from a Canuck I would bet that stuff is the bee's knees!
  13. May 8, 2014 at 10:48 PM
    DTFtacoma
    DTFtacoma Dezert Toy Fabrication Vendor
    Anthony
    Santa Maria, CA
    06 PreRunner D-cab
    DTF LT front & rear
    That's giving me a headache lol
  14. May 9, 2014 at 9:11 AM
    4WDTrout
    4WDTrout Perpetually dreaming of tall trees & rivers
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
  15. May 9, 2014 at 9:14 AM
    RJALLDAY702
    RJ
    Las Vegas
    2014 Toyota 4Runner
    6" Ruff Country DBL
    For real dude. Id shit.
  16. May 9, 2014 at 10:23 AM
    TacoBrah
    Sean
    Theo what's the latest on your new suspension?
  17. May 9, 2014 at 10:56 AM
    4WDTrout
    Theo
    08 4WD SR5 DCSB
    Total Tacoma nOOb.
    I have to order my Wheelers Super Bumps for the front & rear. Once I receive those, I will need to drill holes in the rear brackets so that they will fit onto my AllPro U-Bolt Flip Kit Plate. I also still need to order my AllPro Front Extended Brake Lines. I also have to take my Camburg Ball Joint UCA's off and swap the ball joints. After those parts are in hand & ready to go.... I'll be installing everything.... and cross my fingers.
    I may need Axle Shims & Carrier Bearing Drop Bracket post suspension install but, we'll see..
    I also plan on doing the Cab Mount Chop...It's just hard for me to find the time to get things done.
  18. May 9, 2014 at 12:46 PM
    TacoBrah
    Sean
    Yeah finding time is the hardest part of working on the truck.
  19. May 9, 2014 at 12:54 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    You're not supposed to FIND time, you're supposed to MAKE IT!! :cool:
  20. May 9, 2014 at 1:50 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    I don't know how much All Pro sells their extended brake lines for but here on TW a member has a group buy going since 2010 where you can get 4 extended lines (whatever length you want) delivered to your door for $106. I think he'll even sell just two lines if that's what you need. PM him. I purchased 4 lines and they shipped next day. He lives in orange county and is on top of customer service so you get them really fast. Read through the thread and you'll see 100% satisfaction from everyone who bought. Just tossing it out there.
    http://www.tacomaworld.com/forum/gr...-deal-steel-braded-brake-lines-group-buy.html
