(805) TW Members Thread
Discussion in 'Southern California' started by jblaze805, Feb 25, 2011.
  1. Jan 30, 2015 at 6:56 PM
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Today I also put the bottle cap catcher magnet to the test in the bed. Works amazingly. Apparently holds up to 40 caps! ImageUploadedByTapatalk1422672990.506943.jpg
  2. Jan 30, 2015 at 7:18 PM
    logcabinwc
    logcabinwc Well-Known Member
    Micah
    SF East Bay
    08 4d 4x4 White V6 TRD
    Old Man Emu 885s with Nitrocharged 90000, Bilstein 5100 in the back with AllPro 3 spring progressive AAL, 16 inch Baja Black 6-spoke alloy wheels, Flow Master exhaust, bed lights, Pioneer HD radio, Uniden CB Radio, K&N Air filter, BAMF Sliders w/kickout, Relentless Aluminum IFS Skid, 24 LED light bar, custom/homebuilt expedition style bed rack and basket combo, and Body Armor rear plate bumper.
    Ive done all that. Just take it slow and steady and you should be good. But I get how nerve racking it can be.
  3. Jan 30, 2015 at 7:19 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    How long did it take you? Did you do the BHLM at the same time?
  4. Jan 30, 2015 at 7:24 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
  5. Jan 30, 2015 at 7:25 PM
    logcabinwc
    Micah
    SF East Bay
    oh ya definitely do it all at the same time, you want want to pull it all part again. Took me a weekend just to allow the paint to dry overnight to make sure it really had time to dry 110%.
    Really baking is the most nerve racking part. I would put it in the oven, let it heat up, pull it out and take out as much of the sealant as possible and repeat. Probably did that about 5 times for each light. It takes time, you just down want to over stress the grey plastic when trying to get them separated. I also did a write up on my entire processes.
  6. Jan 30, 2015 at 7:26 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    That's awesome! I'll check it out! Thanks a ton!
  7. Jan 30, 2015 at 7:28 PM
    logcabinwc
    Micah
    SF East Bay
    NP, just let me know if you have any questions when youre doing it!
  8. Jan 30, 2015 at 7:32 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Sand the magnet first. The first time I didn't sand it and the caps took the liner off the magnet.
  9. Jan 30, 2015 at 7:34 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Sorry one more right now. I see you left the bowls chrome in your BHLM. Can't you paint it black as well because the projectors don't rely on reflective surface to spread light?
  10. Jan 30, 2015 at 7:39 PM
    logcabinwc
    Micah
    SF East Bay
    Ya you can paint the projectors chrome. However, if you think you might ever want to go back to the halogens, you'll have to get either new bowls or new headlights all together.
    One recommendation is don't do halos, I was told from the guys at TRS that they don't usually recommend them even because they so easily break. If you really do want some, get some tough ones from Oznium or something that will last you much longer and wont break.
  11. Jan 30, 2015 at 7:40 PM
    TacoBrah
    TacoBrah Well-Known Member
    Sean
    Icon stage 1, 255/85/16 KM2
    That.
  12. Jan 30, 2015 at 7:40 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Thanks for the heads up. I bought some halos but I've been thinking of not putting them in.
  13. Jan 30, 2015 at 7:52 PM
    deadhed61
    deadhed61 :notsure:
    Santa Barbara, Ca
    The Black Pearl
    A little lift and a little armor
    40 caps....
  14. Jan 30, 2015 at 7:53 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I'm excited to see. It did say that I should mount it 6 inches below the opener for that but it's only like 2. The caps will block the opener after a bit.
  15. Jan 30, 2015 at 9:39 PM
    08PRELB
    08PRELB Don't Tread On Me
    Adam
    805
    08 Prerunner LB
    Toy Tech Ultimate Lift kit,Buildt Right UCA's 285/70/17 BFG AT, Camburg Spindles, BHLM, K&N, Flow Master 50, Spider Trax, URD MAF CAL, Satoshi Grill, any time fog mod, 20% tint, Katzkins Leather Interior, FX-R Projector Retro
    Don't be nervous just be smart and pay attention to what your doing, as long as you turn the oven off when you put them in there you'll be fine. I've done about 8 sets of BHLM and retros so let me know if you need some help.
  16. Jan 30, 2015 at 10:17 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Wow I will for sure! Why have you done that many?
  17. Jan 31, 2015 at 7:14 AM
    08PRELB
    Adam
    805
    08 Prerunner LB
    I've done most of them for other people, I started out with BHLM on my truck then retroed another set of lights for her. I've also retroed my wife's 13' 4R. You should also check out hidplanet.com it's a forum all about retros with tons of info.
  18. Jan 31, 2015 at 6:24 PM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    Wow if you don't mind I may be contacting you if I have questions during the process. I've been looking at hidplanet because TRS recommended them.
  19. Feb 1, 2015 at 9:23 AM
    08PRELB
    Adam
    805
    08 Prerunner LB
    Not a problem man let me know, where are you located at?
  20. Feb 1, 2015 at 9:27 AM
    SixthSnail
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I'm right near UCSB. Yourself?
