85 , 87 , 91 Octane ? -----E85 +/- ?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Shawn08Tac, Feb 7, 2011.
  1. Feb 7, 2011 at 2:42 PM
    Shawn08Tac
    Shawn08Tac [OP] New Member
    Boulder
    08 Tacoma TRD SR5 Sport
    I have always driven a sports car mostly with superchargers so I have always used the highest octane I could find normally being 91 here in CO.
    Now that I have the V6 in my 2008 TRD Sport do I still need to run 91 or would 87 work with out taking away any longevity from the engine? Any other huge negatives? Gas is high and getting higher so just looking at cutting back where I can, but it is not worth it if is going to cause even small problems. Also any thoughts on converting to E85?
  2. Feb 7, 2011 at 6:15 PM
    supralight
    supralight Well-Known Member
    Dan
    Earth
    2013 4Runner limited
    87 is ok per manual, and you cannot run E85, also per manual
  3. Feb 7, 2011 at 6:16 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    usually go with the 87
  4. Feb 7, 2011 at 6:23 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    easy solution slap on a supercharger get the x1 and a high boost pulley and some ethonal injectors and run E85.
    But otherwise 87 will be fine
  5. Feb 7, 2011 at 6:30 PM
    Sant0s
    Sant0s Well-Known Member
    Compton,Ca
    VIP GS300, Drag Silvia, 99 T4R Ruckus
    on my ols 4.0l i always ran 91, i tried 87 and 89 and i noticed a diff in mpg and overall response from the truck and when i towed even more so.
    E85 is a great thing i run it in 2 of my cars but theres a lot involved with ensuring having a full system that can support the extra fuel requirements needed for E85 plus the need for the tuning needed to take advantage of the ignition/fuel tables.
    i bet $ a stock 4.0L tuned on E85 will put around 330-350hp
  6. Feb 7, 2011 at 6:39 PM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Supercharge, than the conversion to E85 would be worth it!
  7. Feb 7, 2011 at 6:52 PM
    crf69
    crf69 scraping my emblems off my plasti-dip
    Ohio
    06 TRD OR BSP cab'n 1/2
    ummm yeah
    with ya on that......
  8. Feb 7, 2011 at 7:09 PM
    Sant0s
    Compton,Ca
    ive felt and noticed the diff, remember this is a 10:1 comp motor and heres something too take it as you will
    str8 from WIKI
    The 1GR-FE is the 4.0 L (3956 cc) version, designed for longitudinal mounting in RWD and 4WD pickup applications. It has a 94 mm bore and a stroke of 95 mm. Output is 236 hp (176 kW) at 5200 rpm with 266 lb·ft (361 N·m) of torque at 4000 rpm on 87 octane, and 239 hp (178 kW) at 5200 rpm with 278 lb·ft (377 N·m) at 3700 rpm on 91 octane. This engine features Toyota's VVT-i, variable valve timing system on the intake cam and a compression ratio of 10.0:1. An updated version of this engine features Dual VVT-i, increasing output to 254 hp (189 kW) and 270 lb·ft (366 N·m) on 87 octane and 285 hp (213 kW) and 289 lb·ft (392 N·m) on 91 octane
  9. Feb 7, 2011 at 7:15 PM
    Jdevine80
    Jdevine80 Member
    Josh
    Fort Collins, CO
    '11 V6 DC TRD Sport 6 Speed
    Regular 85 is fine too in Colorado (anywhere there is higher altitude) but not E85 as others said. I run regular 85 in mine with no problem.
  10. Feb 7, 2011 at 7:29 PM
    Sant0s
    Compton,Ca
    HP isnt what you feel but the TQ, but you do not see a graph you you could be seeing a lot of usable torque that you wont get with lower oct. fuel.
  11. Feb 7, 2011 at 11:51 PM
    Doug2000
    Doug2000 Well-Known Member
    London, Ontario, Canada
    2008 Toyota Tacoma Quadcab 4x4
    I was told by a friend that build race motors, that if it's high compression or boosted, then you go with a higher Octane.
