870 Express Rant
Discussion in 'Guns & Hunting' started by bjmoose, Dec 2, 2012.
  1. Dec 2, 2012 at 9:21 PM
    bjmoose
    bjmoose [OP] Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    OK, this is a pretty minor rant.
    But I picked up my new Remington 870 Express 12 gauge yesterday and took it out to the trap range today.
    It was late in the day so I only got to go thru 25 rounds - but that was pretty much enough.
    Four cartridges out of five, after the gun fired, I couldn't get the slide "Fore-End" to slide back and eject the spent cartridge. The rangemaster "tapped" the but of the shotgun on the ground with authority to release it - and that's what I ended up doing most of the time I was there. He was pretty baffled - said he'd had to do that like 3 times in his life on other 870s - and here I had to pretty much every time.
    From the manual:
    Uh yeah. Ain't happenin'.
    Everyone says these things are stupid reliable. I guess I'm just unlucky.
    He suggested I give the shotgun a thorough cleaning - and if the prob doesn't go away send it back to Remington for repair. That is my plan, but this is where you experts come in - anything in particular I oughta be looking for/paying attention to on the 870 mechanism while I have it apart for a "normal" cleaning? Anyone seen dirt/contamination/lack of lube in key location/ cause this particular prob? I'm pretty much resigned to having to send it in... PITA. :mad:
    I'm certainly no expert, but I've handled, fired, and cleaned various other guns. No shotguns until now though.
    RESOLVED. The gun was repaired at a factory authorized gunsmith and now works fine. Read the entire thread for details.
  2. Dec 3, 2012 at 10:52 AM
    DblstuftTaco
    DblstuftTaco Well-Known Member
    Joe
    Ohio
    02 TRD SR5
    OME 3" Kit New frame
    sounds like it might be ammo related? Did you try different kinds? Maybe a bad batch of whatever kind you were shooting or the gun doesn't agree with that brand....
    Every 870 ive seen would spit out whatever you fed it. If it kept it up i would ship it back.
  3. Dec 3, 2012 at 11:00 AM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    ^^ good advice. as they others have said, 870's are awesome. . i wouldn't quite give up on it yet. that wear in time and a good cleaning will probably fix your problem. kind of like when you get a new key cut and you can barely get it in the lock. takes some time for it to get worn down a little bit before it slides in an out with ease.
    that's just the theory i came up with while reading your post. it might be entirely stupid advice, but pump shotguns do slide and eject smoother after shooting them a few months. RemOil her up and send another 100 rounds through it and then go from there.
    :popcorn:
  4. Dec 3, 2012 at 11:01 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    Damn, I've been researching this gun and heard great things about them. I'm between buying a Remington 870 Express and a Mossberg 500 at the moment. I hope you get this resolved!
  5. Dec 3, 2012 at 11:03 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    did it have any lube on it at all? moving parts need lube
  6. Dec 3, 2012 at 11:06 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    Did you clean the cosmaline out before you shot it? When that shit heats up it gets nasty and will make a gun not run correctly. All new guns should be thoroughly cleaned before you shoot them.
  7. Dec 3, 2012 at 11:07 AM
    tomwopat
    tomwopat Well-Known Member
    Memphis, TN
    2012 DCSB Prerunner
    My brother in law had the exact same issue with his new 870. I recommended a good cleaning but he hasn't shot it since so I can't confirm that it's working properly now. I don't think it's the ammo because my Benelli worked flawlessly with the same shells (taken from the same box).
  8. Dec 3, 2012 at 11:09 AM
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    Ya I would say clean then oil oil oil
  9. Dec 3, 2012 at 11:09 AM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    I have a bum 22lr from Remington. Never worked right from day 1 regardless of ammo used. Sadly I never returned it like I should have and now I'm stuck with it.
    That's my first/last Remington for sure.
  10. Dec 3, 2012 at 11:10 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    oil change...
    Ammo should not be an issue as its a pump and not an auto.
    OP clean the white packing grease out and lube her up nice and I bet that your issue will be resolved.
    Let us know the result :popcorn:
  11. Dec 3, 2012 at 11:11 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    870s are wonderful shotguns. You'll get it resolved.
  12. Dec 3, 2012 at 11:12 AM
    Ghoster
    Ghoster Well-Known Member
    Baltimore
    2012 PreRunner DCSB
    I fired countless rounds through an 870 and never had a failure. I would suspect the ammo first.
  13. Dec 3, 2012 at 11:14 AM
    blackhawke88
    blackhawke88 wo ai ni bao bei ^_^
    SGV, CA
    07 TRD Offroad
    that's strange, my 870 worked day 1 out of the box, I put 50 rounds through it the same day I bought it without any cleaning without so much of a hiccup. I would send it back for them to check it out for sure.
  14. Dec 3, 2012 at 11:16 AM
    jgwheeler17
    NC
    neglect, mostly.
  15. Dec 3, 2012 at 11:17 AM
    aficianado
    aficianado Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    how is it an ammo issue when we are talking about a pump shotgun?
    you guys are thinking the shell expanded to a point the action cant be recycled? i have an old 870, and it is super smooth..was this 870 cleaned first before the range?
  16. Dec 3, 2012 at 11:39 AM
    cabarbhab
    cabarbhab Well-Known Member
    Andy
    Mary Esther, FL
    2011 DC TRD OR 4x4
    My 870 Magnum gets hung up sometimes when I am shooting 2 3/4 shells.
  17. Dec 3, 2012 at 11:39 AM
    Mapcinq
    Mapcinq Well-Known Member
    Ontario, Canada
    I was going to buy an 870 when i first got my license a few years ago. I know people love them, and the old ones were great.. but I read a shit ton of reviews on the new ones being hit and miss (lots of people having problems with them). I went with a Mossberg and had 0 problems. Bought a Remington 700 rifle, and the scope mounting holes were out of allignment. Id send it back to Remington and see what happens.
  18. Dec 3, 2012 at 1:02 PM
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I didn't pre clean it -- it went straight out of the box to the case to the range.
    Yeah, I know cleaning first is "best practice" But I also know that like Beavis076 above more than a few folks skip that step as a practical matter.
    I'll clean it this coming weekend and get another chance to shoot it the following weekend - if not before.
  19. Dec 4, 2012 at 6:55 AM
    StZu
    StZu Where the White Women At?
    Richard
    Dallas Texas
    18 Super White TRD Offroad
    Level 8 Wheels, Bilstien/Eibach lift, 2" aal, blacked out rear bumper, AC drain hose relocation, sound deadening 4 doors and back wall, amp/speaker upgrade, 10" daytona sub, LED interior lights.
    I am betting this is your problem, that packing grease is like syrup in your gun.
  20. Dec 4, 2012 at 7:12 AM
    Shaunsquatch
    Shaunsquatch Well-Known Member
    Shaun
    Louisville, KY
    2020 Tundra
    I had the same problem with an 870 express, and only with certain ammo (meaning cheap). Turns out the chamber was rough, had it polished and never a problem since. I think this is a relatively common problem unfortunately.
