884, 885, 886 ????? PLEASE HELP!!!!!
Discussion in 'Suspension' started by luchin, Jul 27, 2015.
  1. Jul 27, 2015 at 8:36 AM
    js312
    js312 Well-Known Member
    Joe
    New England
    23 F150 PowerBoost Lariat 502a
    Husky Weatherbeaters, OEM Mud Guards, Wheel Well Liners, Bullet Spray-In Bed Liner, Gator Soft Tri-Fold Cover, Michelin LTX M/S2 (Summer), Blizzak DM-V2 (Winter)
    884s with 5100s @ 0 are a great combination. I got 2" dead on with mine, but haven't checked to see if they have settled at all since.
  2. Jul 27, 2015 at 8:40 AM
    luchin
    luchin [OP] living the Canadian dream
    Vancouver Island
    15 6MT DCSB SR5
    OME 885 coils, Dakar leaf pack, Bilstein 5100 struts, SCS Matte Jet Black SR8 wheels, 265/75/16 Toyo Open Country AT II, Arrow cap, Truxedo Truxsport Tonneau cover, TRD Exhaust, colour matched grill.
    So I can run the 5100s with the OME 884 coils? Would it not be better to run the whole OME 2885 kit since the dampers are made to work with those coils?
  3. Jul 27, 2015 at 8:50 AM
    Large
    Large Red
    If you have the money I wouldn't the struts and coils, I did run 885s with 5100s without issues as well.
  4. Jul 27, 2015 at 9:13 AM
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    If I opt for the 2885 setup I'm stuck at approx 1.75 lift in the front, yes? It seems that's how much the 2885 kit lifts the truck.
    If I go to the 884 coil with 5100s I can still play with lift height within the 5100s adjustments. Yes?
    Also, I'm assuming the 2885 OME kit keeps the factory front rake.
  5. Jul 27, 2015 at 9:38 AM
    VandalTaco
    VandalTaco Well-Known Member
    Will
    Moscow/Idaho falls, Idaho
    07 DCSB TRD SPORT
    OME 887 lift, 16" XD addicts, 285 duratracs, leather seats, badass JL/Focal stereo
    No. 885s are 2.5 inches of lift in the front, 884s give 2 inches of lift. All of the lift comes from the coil, not the strut. Regardless of which struts you decide on you will get the same lift. Technically you could play with the height by adjusting the settings on the 5100s, but they are supposed to be set to 0 when paired with the OME coils.
    Arailt likes this.
  6. Jul 27, 2015 at 9:53 AM
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    Thank you.
  7. Jul 27, 2015 at 10:03 AM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    Yup. Just FYI I have the 5100s paired with OME 887 coils for just under 3 inches of lift and I love it. Had it for about 2 months now and I'm so happy with it.
  8. Jul 27, 2015 at 11:21 AM
    cgchambers93
    cgchambers93 Well-Known Member
    Christopher
    Houston
    14 Tacoma SR5 4x4
    Wheels and tires, Billstein suspension
    5100s set at "0"?
  9. Jul 27, 2015 at 12:29 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    Yes. When pairing the OME coils with the 5100s you should always set the strut to the lowest setting (0"). OME has several coils to choose from in order to get the lift height you are after.
  10. Jul 27, 2015 at 12:40 PM
    Jack Wagon
    Jack Wagon Active Member
    Glen Burnie, MD
    2015 SR5 Shortbed
    5100 w/ 2.5 Eibach springs, stock UCA's, Single AAL, ImMrYo mirror relocation, Tonnopro Tri-Fold, 20% Tint
    I'm sort of in the same boat. Want to run 265/75R16 and 5100/885 for 2.5" lift.. Then on the otherhand the 285's w/ 5100/887 looks damn good. I'm just not interested in cutting up my new truck because of rubbing. Plus the wife would absolutely kill me.
  11. Jul 27, 2015 at 1:27 PM
    cgchambers93
    Christopher
    Houston
    14 Tacoma SR5 4x4
    I have 5100/887 with 285s and do not rub at all. Depends on the tires you use and the offset of the rims.
  12. Jul 27, 2015 at 1:32 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    This is true.
    I had some light rubbing for street driving. I lived with it for about a week before having it trimmed up. Not much was required, and you can't even tell unless you know what to look for. I wouldn't let that keep you from getting what you want. Besides, you'd only need to trim the splash guard on the bumper and maybe a tiny bit of the fender...that's all it was on mine. And you're right, the 285s look sooo damn good. :D
  13. Jul 27, 2015 at 1:51 PM
    Gearheadesw
    Gearheadesw must modify
    Davenport Fl
    1 truck 1 car 1 motorcycle
    Vandaltaco, where'd you get your 887's ?
  14. Jul 27, 2015 at 1:57 PM
    VandalTaco
    Will
    07 DCSB TRD SPORT
    Arailt likes this.
  15. Jul 27, 2015 at 3:24 PM
    #35
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    The simple solution. :D Call Wheeler's!
  16. Jul 27, 2015 at 5:05 PM
    #36
    Jack Wagon
    Glen Burnie, MD
    2015 SR5 Shortbed
    I'm looking at that headstrong kit as well. Back to the tire rub.. What do you think of the SCS SR8's with 285/75r16 KO2's? Think they would rub w/ the 887's? I'm just worried about cutting and a CMC. But, if it'll fit like butter then we might have something.
    Then there is always the "play it safe" and go 885 w/ 265.. Same wheel and tire combo.
    I've also thought about level 8 Bully Pro's, Cooper's STT or Toyo R/T as well.
  17. Jul 27, 2015 at 10:45 PM
    #37
    VandalTaco
    Will
    07 DCSB TRD SPORT
    If you are planning on wheeling hard then you'll probably want to do the cmc with 285s. Otherwise I doubt you'll need to worry about it. I just had some light trimming on the front bumper splash guard and a tiny bit on the fender where the mud flap was.
    Try posting on the sr8 thread and ask if anyone is running the setup you want...might get lucky!
  18. Jul 28, 2015 at 6:20 AM
    #38
    luchin
    Vancouver Island
    15 6MT DCSB SR5
    What's going to give me a better ride, 5100s with 884/885 coils or 5100s with factory coils.
    I'm of the opinion that preloading a strut deteriorates the ride some. Correct me if I'm wrong.
  19. Jul 28, 2015 at 6:42 AM
    #39
    VandalTaco
    Will
    07 DCSB TRD SPORT
    I think you'd be better off with getting the aftermarket coils. I would think it would ride better and be better for your truck in the long run. I've never rode in a truck with the other setup though so...
  20. Jul 28, 2015 at 7:44 AM
    #40
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    You don't want to ride in a truck with my setup.
