885 coils and 5100s?
Discussion in 'Suspension' started by BakerTaco, Jun 26, 2012.
  1. Jun 26, 2012 at 10:23 PM
    BakerTaco
    BakerTaco [OP] Well-Known Member
    Will
    Lower Alabama
    2006 4x4 SR5
    Black UWS Toolbox, Window Tint, Weathertech mats, OME lift: 885x coils, top plate spacer, OME shocks all around, 2 inch AAL driver side trim packer, Toytec diff drop, Grillcraft, Colormatched grille, CHLM, 6000k HIDs - headlights and fogs, Smittybilt shackle hitch, ARB snatch strap, Pioneer avic x940bt headunit,
    I have just now gotten to a point where I have enough cash to buy a lift... Therefore, I am freaking out. Because for a jobless 16 year old $600-$800 is a small fortune. I don't want to spend too much money on my suspension, considering my truck will rarely wander off the pavement. Although I would like to have 3 inches of front lift rather than the 2-2.5 that the 885s alone produce, and have a quality ride.
    So my question is: would it be a safe choice to set the 5100s at 0.85 with 885 coils? or should I go with one or the other(OME or bilstein)? I am well aware bilstein is cheaper but I want to install it myself. I could pay a little more to toytec to get it all pre-assembled with top mounts(which would make installation a lot easier) and I can't do that if I use 5100s with my stock springs...
    Sidenote: I would like to get new springs anyway because mine have over 136,000 miles on them
  2. Jun 26, 2012 at 10:28 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    I did it but eventually lowered the 5100s back to zero. Just a better ride and the easier on the cvs
  3. Jun 26, 2012 at 10:29 PM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    I plan on running my 885s (sitting in my closet) with with 5100s set at zero. I figure whatever amount of lift I get from the 5100s (expecting anywhere from 2.5 to 3") will be plenty.
  4. Jun 26, 2012 at 10:34 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Damn haha. How much lift do those 885s give you? Another problem I have is the 285/265 debate. If I get 285s, I don't want to trim because my dad bought the truck :eek:
  5. Jun 26, 2012 at 10:36 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    dont get 285s then...i remember buying a lift whe i was 17....lol
  6. Jun 26, 2012 at 10:42 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    They just look so much better!!!! haha especially since my dads making me get BFG A/Ts, not mud tires
  7. Jun 26, 2012 at 10:43 PM
    anthony250f
    Anthony
    San Diego, CA
    they look wayyy batter imo.....i had to cut the cab mounts and i have 5" of lift....its because the spacers though
  8. Jun 27, 2012 at 6:33 AM
    DevL
    DevL Well-Known Member
    I cut a shit ton up front. Most people say that they could not tell if I did not point it out. Can you weld? If yor dad has a welder you can utilise the shittiest welds and just grind em down and fill in flaws with JB weld. I have not seen a better looking cab mount chop than mine and it jus from grinding and using JB weld as a filler before painting. I cannot weld and my buddy tried to cut out bad welds and reweld one side... still had tons of porosity. Good welds dont matter but dont think you can run a 33" 285 without a cab mount chop and lots of plastic trimming.
  9. Jun 27, 2012 at 7:10 AM
    Bama_TACO
    Bama_TACO ROLL TIDE!!!!!!!
    Winfield, AL
    2006 PreRunner Double Cab TRD SPORT
    I've got 885s and 5100s set at zero. I have considered moving the 5100s up to the .85 setting, but I'm afraid I will have alignment issues. Plus mine sits level now and it would raise the front higher than the back.
  10. Jun 27, 2012 at 4:54 PM
    BakerTaco
    Will
    Lower Alabama
    2006 4x4 SR5
    Do you have TSB springs? Or just the TSB AAL with regular leafs?
  11. Jun 28, 2012 at 7:57 AM
    Bama_TACO
    Winfield, AL
    I have stock leaf pack with 150,000 miles on them and a 1 1/2" Wheeler AAL.
  12. Jun 29, 2012 at 2:56 AM
    jeremy1ns
    jeremy1ns Gamecock Tacos
    Jeremy
    Greenwood, SC
    2010 TRD Sport BR
    None yet, but its about to get rolling.
    Do the 275s rub at all?
  13. Jun 29, 2012 at 5:57 AM
    Bama_TACO
    Winfield, AL
    They rub my mudflaps on full turn but I'm not willing to remove the flaps so I live with it.
  14. Jun 29, 2012 at 6:13 AM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I got 885's with 5100's set at zero and the top plate spacer and I got a little over 3"s of lift. I am also running 285's and your going to have to do some minor trimming and will still rub the cab mount at full lock.
