885's and 5100's
Discussion in 'Suspension' started by Range 44, Mar 8, 2011.
  1. Mar 8, 2011 at 6:21 AM
    Range 44
    Range 44 [OP] Well-Known Member
    Georgia
    2008 FJ TTE
    I know, I know, but I cant seem to get a real number. How much will the 885's lift a 2011 DC SB with 5100's? No spacers or packers. Also I have the TSB, what will level it with them. I would rather use a spring for the lift rather than the 5100,s. I am trying to achieve around 2.25"-2.5" of lift. Dont want to buy UCA's just yet. Thanks you for your patience!
  2. Mar 8, 2011 at 8:13 AM
    raycie
    raycie Well-Known Member
    Oahu, HI
    2013 DCLB / 2016 4R Trail
    In need of $$$
    885s may give you 3" or a bit more. 884s will give you between 2-2.5". There will be slight variances from one truck to the next.(single/extended/double cab, shortbed/ LB)
    NLF just installed some 884s last week. I just installed my 884s yesterday. He posted some post lift measurements. I'm gonna let mine settle a week then post some measurements.
  3. Mar 8, 2011 at 8:24 AM
    06Bluez
    06Bluez Well-Known Member
    Phoenix, Arizona
    06 4x4
    Icon Coil-overs, TC UCA, with Bilstein 5150 and Icon 3 leaf pack. 17" Moto Metal 951 4.5" Backspacing wrapped in 285/70/17 BFG AT's. Demello front bumper and Avid offroad sliders.
    My bilstein 5100's set at 0" and OME 885's didnt give me a full 3" of lift. :eek:
  4. Mar 8, 2011 at 8:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    You had the older 885's too.
  5. Mar 8, 2011 at 8:27 AM
    Gregero
    Gregero TRD: Trail Ready Development
    Greg
    Carson City, NV
    Blue '06 Prerunner TRD Sport
    Debadged Tailgate, TOYOTA logo on Tailgate, Uniden Radio w/ 4' Ant., Removed Sway-Bar, Rear Icon Extended Travel Shocks, 8" King Offroad Shocks, Debadged Doors, 1.25" Rear AllPro Wheel Spacers, 315/70R17 Mickey Thompson Baja MTZs, AllPro Skid Plate, New Car Smell Air Freshener, OMD Ford&Chevy Leaf Pack with Original Main leaf, Engage LT UCAs and LCAs, Engage HD Tie Rod Ends, Kar-Tek Limit Straps, Camber Eliminator Kit, Removed Rear Flares, Blue LED Dome and Map lights, LED License plate lights, Black TRD Sport Rims, 20W PA Speaker, 2 Meter Radio, Demello-like Bed Bar, Harbor Freight Dust Lights, Blacked-out Hood Scoop, Custom Pre-Runner Bumper, JBA Long Tube Headers, MBRP Catback Exhaust, AFE Stage2 CAI, URD MAF Sensor Calibrator
    I've got the same set up. I'm about 2.75" I think- was in a hurry and forgot to measure :( but it's definitely up there.
  6. Mar 8, 2011 at 8:29 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Im referring to the set up on my new truck which was just purchased and installed 1 month ago from DSM. Maybe is is 3" but it seems like about 2.5"
  7. Mar 8, 2011 at 9:16 AM
    lembowski
    lembowski Well-Known Member
    Rolando, CA
    Jeeper Creeper
    I had the 5100's with 885x coils. After a few weeks mine settled in to 2.75" of lift in the front. I have an Access Cab Prerunner. So I would assume that a DC will give you between 2.25" to 2.75". But that is just a guess.
    I will tell you that it rode smooth and I really recommend the setup from my experience.
  8. Mar 8, 2011 at 10:22 AM
    Range 44
    Georgia
    2008 FJ TTE
    So prob 884's and a 1.5 AAL on my tsb should look pretty good?
  9. Mar 8, 2011 at 10:34 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    ARB suggests the 885 for Double Cabs. 884 is suggested for Access Cabs.
    Results will vary, will the 884 look good? I sure it will, but so with the 885.
  10. Mar 8, 2011 at 11:05 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Did you measure, or are you just throwing number out there?
  11. Mar 8, 2011 at 11:07 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Throwing random numbers out there. It has sagged for sure since it was first installed.
  12. Mar 8, 2011 at 11:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Right. The 885's give over 3" initally, then settle down to about 3" for Prerunners, and about 2.75 for 4x4's
  13. Mar 8, 2011 at 11:15 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Can I get my 3" back?? :confused:
    I am rubbing pretty bad now and I wasn't before it settled. I'm sure the 1/4" top plate spacer would do the trick but that means I would have to bring it by another shop and pay $40 to get it installed.
    (sorry for the thread jack)
  14. Mar 8, 2011 at 11:42 AM
    lembowski
    Rolando, CA
    Jeeper Creeper
    Your only option is to get the top plate spacer, or pre-load the 5100's to .85".
    I would think the top plate spacer would be the solution with the least amount of headache.
  15. Mar 8, 2011 at 11:43 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    You don't even know if you lost height. Measure your truck. THEN decide what action to take.
  16. Mar 8, 2011 at 11:45 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    Top spacer would also allow more down travel would it not ?
  17. Mar 8, 2011 at 11:45 AM
    06Bluez
    Phoenix, Arizona
    06 4x4
    Top plate spacer would mean I need to change out the 3 bolts on each shock with longer ones which would require a spring compressor.
    adjusting to .85 would be the easiest route but would be to much lift. :mad:
    Ill just deal with the rubbing.
  18. Mar 8, 2011 at 11:48 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    First, you don't even know if the springs sagged below 3 inches. Until you get away from the keyboard, and take some measurements, nothing can be accuraely decided.
  19. Mar 8, 2011 at 2:54 PM
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    This is why I love reading Chris's posts! He tells it as it is, no sugar coating
  20. Mar 8, 2011 at 3:10 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    If he posts up again with out giving measurements, Im going to find him, and beat him with his keyboard.
