885's or 886's?
Discussion in 'Suspension' started by 05RedTaco, Oct 22, 2012.
  1. Oct 22, 2012 at 7:08 AM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I have a dilemma of which springs to get for my 5100's currently set at 2.5 with stock TRD Off Road coils. I have pre runner style bumper with shackles light hoops and lights, picture below;
    [​IMG][​IMG]
    I know that 885's are up to 110lbs of additional weight and 886's are 200lbs+ additional weight.
    What do you guys think?
  2. Oct 22, 2012 at 7:10 AM
    Mitch
    Mitch Somebody call for a Wambulance?
    Mitch
    Spokane, WA
    2007 Access Cab SR5 4x4
    Lights, Siren, Drugs, Needles, Electricity
    I would bet 885s would be fine. That bumper can't weigh that much
  3. Oct 22, 2012 at 7:11 AM
    Large
    Large Red
    x2, I ran 885s with a bumper & winch. The bumper by it's self made them sag 3/8" or so but the ride was great. Added a winch, that's another story.
  4. Oct 22, 2012 at 7:12 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    885's with top plates. You have a Prerunner so you'll experience slightly more lift than what the 4x4 guys are showing.
  5. Oct 22, 2012 at 7:16 AM
    05RedTaco
    Tony
    Scottsdale
    I don't think I will need top plates... 885's with 5100's set at .85 should give me almost 3" lift...
  6. Oct 22, 2012 at 7:19 AM
    Pugga
    Massachusetts
    New 885's on 5100's at .85 will likely put you right at, if not a tad over 3" of lift. At least that's where my money is at.
  7. Oct 22, 2012 at 7:23 AM
    cgs2k2
    cgs2k2 old man
    definitely don't need 886 for that thing
  8. Oct 22, 2012 at 7:26 AM
    OZ-T
    OZ-T You are going backwards
    Peter North
    British Columbia
    885's and 1/4" top plates
  9. Oct 22, 2012 at 7:35 AM
    05RedTaco
    Tony
    Scottsdale
    Just out of curiosity... Why do you guys keep suggesting top plates?
  10. Oct 22, 2012 at 7:38 AM
    Pugga
    Massachusetts
    Because personally I would avoid preloading the new coils. 885's with 1/2" plates on the DS and 1/4" on the PS would put you close to 3" of lift without adding preload to your new lift coils. Those short plates don't have any adverse affects on the suspension geometry.
  11. Oct 22, 2012 at 7:49 AM
    05RedTaco
    Tony
    Scottsdale
    Most likely I am getting the springs used, would that make a difference?
  12. Oct 22, 2012 at 7:52 AM
    Pugga
    Massachusetts
    Depending on how they were used and how long, it could. Do you know if the springs you're getting are 885 or 885x?
    The 885's are more prone to sagging as they age so applying a little preload might not be a bad thing and might be necessary to get the height your looking for. With used springs, it's a little bit of a crap shoot trying to guess what you'll need to do to make them end up at a specific height. New springs are predictable but used can really vary depending on the life they've had.
  13. Oct 22, 2012 at 7:55 AM
    skidooman
    skidooman I'm your huckleberry
    TJ
    Northern Nevada
    19 Taco
    Kings, JBA, BAMF, C4, Deaver, Prinsu, TJM, SnugTop, 5.29s
    I may be wrong but I didn't think you could put 886 on 5100s?
  14. Oct 22, 2012 at 7:56 AM
    05RedTaco
    Tony
    Scottsdale
    The seller says they are 885's. Whats the difference between 885 and 885x?
  15. Oct 22, 2012 at 7:59 AM
    cgs2k2
    cgs2k2 old man
    the 885x is the newer version. less prone to sagging.
  16. Oct 22, 2012 at 8:02 AM
    Pugga
    Massachusetts
    You can, it's not recommended though. The 886's should be paired with Nitrochargers.
    ^This. They're still the same spring rate and length, they are just made different to resist sagging as they age.
  17. Oct 22, 2012 at 11:21 AM
    tacoma16
    tacoma16 Well-Known Member
    Peter
    Ontario
    Double cab SR5 4x4
    Not to thread jack but what if you had full skids, sliders, and a bumper is on your agenda. You only wanted 2.5' of lift. Would the 855's do the job, or would 886's work better for the long run.
    I just wont be able to get a lift and a bumper at the same time, so i dont want to run the 886 springs with no load and risk my cv's.
    any thoughts?
    hope that wasnt too confusing
  18. Oct 22, 2012 at 11:22 AM
    Large
    Large Red
    Just use 886s. It won't hurt your drivetrain for a while.
  19. Oct 22, 2012 at 11:26 AM
    Saskquatch11
    Saskquatch11 TRUCK YEAH
    I got 2 7/8" lift with 885x coils no top plate spacer, 5100s @ 0".
  20. Oct 22, 2012 at 11:27 AM
    tacoma16
    Peter
    Ontario
    Double cab SR5 4x4
    Alright super. Thanks for the Help!!
    How much lift do you think 885's would give me with skids and sliders? probably under 3? Just debating on the bumper, so if i had to switch to 886's if i got the bumper in the end. Instead of the other way around
