885x and billies, hub to fender measurements.
Discussion in 'Suspension' started by Raceline08, Apr 27, 2013.
  1. Apr 28, 2013 at 8:03 PM
    4Wheelin4Banger
    4Wheelin4Banger Longtime Toyman
    Randy
    Ferntucky, NV Halfway between Reno & Falabama
    2011 4x4 Access Cab Silver State Edition
    3" OME lift 885s & Dakars riding on 33" KM2s Click the sig pic to see the build thread .
    Between the wheel well & UCA?
    First time I did mine I pried the UCA down with a pry bar.
    When I added spacers I used the jack, so much easier that way.
  2. Apr 28, 2013 at 8:19 PM
    Raceline08
    Raceline08 [OP] Well-Known Member
    Brett
    Santa Rosa, ca
    Silver 08 DBC SB 4x4 TRD Offroad
    front Billies, 885x coils, taco lean spacer, TC UCA'S, Magnaflow 22" OME Dakars, Billy 110 rear's, B.A.M.F CMC, custom made E-locker guard
    I'm not sure I understand? The TC UCA's was maxed out to the point where it would hit the coil when I was trying to install these, the lower control arm was disconnected from the ball joint and it would not go any lower, about a half inch is all I needed.
    I'm still asking for hub to fender measurements for the 885 and billy setup? I've got great advice and I appreciate it but in would like to know that you guys are running? No top plate? Yes top plate? Taco lean spacer too? Etc.
    I've had 2 responses with measurements thank you.
    Thanks fellow TW members,
    Brett
  3. Apr 29, 2013 at 1:59 AM
    4Wheelin4Banger
    Randy
    With UCA & LCA still attached place bottle jack upside down between wheel well & UCA. This will push LCA down far enough to fit the shock in place.
    The two that did give you measurements were running 885s on OME (like I am) not billies.
  4. Apr 29, 2013 at 5:35 AM
    Skunkman
    Skunkman Well-Known Member
    Syracuse - Tug Hill
    2007 Tacoma Access Cab ,
    Bilstein 5100's with OME 885 X,top plate spacers,taco lean spacer,All Pro Expo's in the rear,installed fog lights,installed intermitent wipers,IPF off road lights,ARE topper with 5 ft. Hi-Lift Jack,first aid kit, fire extinguisher installed inside,Sway a Way front sway bar,Westin Brush Guard,air box mod,Mag Lite Mod,Relentless CB ant. Mount, DX 959 Galaxy CB,Go Rhino nerf bars,Duratrac 235-85-16's on TRD OR wheels,
    I just did this last week and might be able to help. I was running 5100's set at 2.5 " and they gave me exactly that much over stock on my 4 cyl. AC with stock coils. We put new 5100's on set at 0" and 885 X's along with the Wheelers 1/2" top plate and a 1/4" Taco Lean spacer on the drivers side. I also used Wheelers new Poly. Isolators when assembling the coils and new Top Hats,those isolaters are pretty thick. The drivers side was a bastard to get in,the mechanic that did it called and wanted to make sure it was correct,and finally got it assembled after a struggle. The Passenger side went in much more easily. When it came off the lift we drove it around for maybe 10 miles before measuring ,to let everything settle. Both sides have the exact same measurements, at 3.5 " above stock right now, I believe it is 23.5" but will double check later. I am hoping the isolaters will compress some, and it will settle to a true 3 " when done. Everything clears at this time, no bumps or rattles, and it drives way better than I could have hoped for, after reading some of the stories when people do this lift,seems like every truck takes it differently. Going to run it for a week, get it aligned,and the decide how quickly to get some UCA's depending on the alignment numbers. I will get the exact measurements today and post them. Hope this helps.
    I didn't see you wanted the measurement without the spacer, till now. Mine is still at 23.5 on both sides after a few hundred miles,doesn't appear to be settling much, but this measurement is with the top plate spacer installed.
  5. Apr 30, 2013 at 9:45 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Thank you. I want this height, right now with the crappy revtek I'm at 22.5 on drivers side and 23.5 on the passenger . Guess it doesn't really matter to me if I'm on the 22.5 or the 23.5 side ( height lifted with 885 ) I just don't want it any lower. Even would be nice also . :)
    Thanks,
    Brett
  6. Apr 30, 2013 at 9:50 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Great idea, did you try the install before you used the bottle jack meathod? I jumped and pushed down as much as I could on the lca and didn't get much of anything. If so do you remember how much in inches you might have gained? One inch? 0.5 inch?
    Thank you,
    Brett
  7. May 1, 2013 at 11:01 AM
    4Wheelin4Banger
    Randy
    When I first saw & helped install some the guy that's done it many times did the pry method. and that's how I did it the first time. It was a pain but it worked.
    Read on here about the jack method, so when I added 1/4" spacers to mine I used the jack method.
    Don't know how much it moved it, but I was just turning the jack by hand (no crank) and got plenty of room. Mine wouldn't even go into the cup until I put the jack on it. So much easier this way!
  8. May 1, 2013 at 8:19 PM
    Raceline08
    Brett
    Santa Rosa, ca
    Thank you sir, ill try that for sure. I'm going to look into the jack method also. I just want to get as much info as I can so I can knock this out and get it done. It's been haunting me for a week now. :)
    Thanks again,
    Brett
