886 Backup light mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FFRNDAN, Mar 13, 2012.
  1. Mar 13, 2012 at 12:37 AM
    FFRNDAN
    FFRNDAN [OP] Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    This is my first write-up, so bear with me.
    After doing a pretty good search, I noticed nobody had done a write-up on the 886 fog light bulb mod in the backup lights of a 2nd gen.
    This will replace your wimpy stock backup light bulbs with a 50w bulb. You will need:
    2x 886 Fog light bulb (see pics below)
    10mm socket and ratchet
    standard (flat) screwdriver
    hacksaw, dremel tool, ect.
    30min of your free time.
    First, stop by your local parts store on your way home from work and pick up 2 (two) 886 flog light bulbs, mine were from o'reilly's:
    Next, grab your 10mm socket, ratchet, and screwdriver. Remove the 3 bolts holding the taillight in, which can be accessed by simply lowering the tailgate:
    Next, give the taillight housing a good tug straight out (rearward) and it should come out with a "pop".
    Look for the plug for the reverse bulb, it will take a quarter turn, then come straight out:
    The stock bulb just tugs right out.
    Now comes the fun part, you must cut off the connector for the 886 bulb. DO NOT use wire cutters! Use a hacksaw like me, or better yet a dremel tool. Place the connector end in a vice, and CAREFULLY make your cut at the yellow line. Just put your cutting blade up against the connector base and use that as a guide. If using a hacksaw, use VERY light pressure, as the bulb is very fragile. Let the saw do the work, and take your time or you will break the bulb. DO NOT TOUCH THE BULB! Use a clean paper towel, or gloves if you have them oils from your skin will ruin the bulb.
    I forgot to grab a pic of the bulb after the cut, but you place it in the connector, just like the stock bulb
    Now, re-install the bulb into the housing, and the rest is the reverse of removal. Rinse and repeat for the other backup light, and you're done!
    Now for the before and after pics! Both are from 10 paces away with my cell phone.
    Before:
    After:
    Enjoy!
  2. Mar 13, 2012 at 1:49 AM
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    did this to mine years ago. loved every minute of it. still running the same bulbs. nice write up
    ChadsPride and PvilleJohn like this.
  3. Mar 13, 2012 at 2:35 AM
    mjm540ii
    mjm540ii Ding Dang Dee
    Oxford, PA
    2010 TRD Sport AC V6
    Fog light mod, interior LED's, illuminated switch, B110 5100's in the rear, Satoshi Grill, Hella 500's, 4X Innovations sliders, rear diff breather mod, painted rocker panels, bhlm, yellow wire mod, CB, Wheeler's 2"aal, Allpro diff skid, ubolt flip, LR UCA's, 885X's w/ 13mm spacer on 5100's, Spydertrax spacers, Relentless IFS/ mid/ T case skids, 255/85/16 KM2s, block heater, DTRL mod, T2 eyelids, Wheelers Superbumps, Extended SS brake lines, ATO shackle flip kit,1" 4Crawler BL, Elite fr plate bumper, Flyzeye LEDs, Drilled and slotted rotors, 20" LED bar
    Nice write up! Does this work with the stock "LED" style looking reverse lights as well?
    ChadsPride and Mr. Ed's taco like this.
  4. Mar 13, 2012 at 2:39 AM
    RI Tacoma
    RI Tacoma Well-Known Member
    Tim
    Phx sometime soon
    2011 Sport DCLB
    OME 885's, Derped FJ TRD Wheels, Hankook Dynapro's ATM 265/75/16's, Retro's, WeatherTech Liners, Fog Light Mod, Bak Flip F-1, N-Fab Steps, 20% Tint, complete stereo, heated mirrors, Katzkin seats!!
    Yes it does. I did this mod for my 2011 a couple months ago and couldn't be happier with it. With my front windows tinted the 886's made a huge difference
    ChadsPride likes this.
  5. Mar 13, 2012 at 3:17 AM
    mjm540ii
    Oxford, PA
  6. Mar 13, 2012 at 4:56 AM
    tbone11212
    tbone11212 Well-Known Member
    fayetteville NC
    07 Tacoma TRD 4x4
    Black Spyder Headlights Black LED Spyder Tail Lights Spyder Smoke Fog Lights HID Headlights and Fog Lights Black LED IPCW Third Brake Light De-badged plasti-dip power window panels plasti-dip center console modded A/C controls JVC 7inch double Din touch screen HD radio Extreme bull-bar color-matched billet grille Billet lower grille color-matched rear bumper 5% tinted windows LED fog lights added HID bulbs added for fog lights Fog light Mod high beam/ low beam mod LED bedlights LED under hood lights aux fuse box Image Dynamics front and rear speakers Blue accent lighting
    subbed nice mod
  7. Mar 13, 2012 at 5:35 AM
    CtTaco
    CtTaco Well-Known Member
    Eric
    Connecticut
    2010 4x4 Doublecab Sport Longbed Supercharged
    3" lift, Tundra wheels with BFG ATKO's, Viper Remote starter TRD Supercharger
    Great mod. Might try this today. Lets add this to the sticky if its not already in there
  8. Mar 13, 2012 at 5:51 AM
    Bryan139
    Bryan139 I have a spectacular aura
    NJ
    '09 Sport
    I cut some wires here. Added some wires there.
    This is great. Tinting the windows is coming up next on the list soon and I was thinking about going to led reverse lights when I do. Not anymore.
  9. Mar 13, 2012 at 8:14 AM
    MountainDog
    MountainDog Well-Known Member
    Aurora, CO
    2012 4x4 Double Cab Off Road
    Vinyl floor; 265/75/16 Duratracs; SnugTop Rebel
    Subbed. Might have to do this to my 2012. Never too much light!
  10. Mar 13, 2012 at 10:11 AM
    boomer6
    boomer6 Well-Known Member
    TN
    Tacoma TRD Offroad
    disabled DRLs disabled seat belt chime disabled the key in the ignition with door open buzzer Installed Illuminated 4wd switch circuit board Marker lights Flashing with turn signals Toggle switch ABS Disable Fog Lights on AnyTime Mod Changed to Yellow bulbs in the Fog Lights Converted interior lights to leds Installed oem roof rack Installed Firestone Ride Rite Air Bags and Daystar Cradles for the air bags Added oil catch can Relentless Tailgate Protector installed
    Great write up. Wish I had seen this mod sooner. I added extra reverse lights under rear bumper. Guess I will Do this mod also.Cant ever have enough reverse light!! :)
    BigE likes this.
  11. Mar 13, 2012 at 10:22 AM
    Endurozw
    Endurozw War Damn Eagle!
    Zach
    Birmingham, Alabama
    09 PreRunner DC SR5 w/ tow package
    Fold-a-cover G4 - Wranger Duratrac 265/75/16 Audio Upgrades: Pioneer AVH-P4200DVD / JL Audio HD600/4 amp / Hybrid Audio 6.5 Clarus up front / Arc Audio 10 in subwoofer
    I'm assuming this won't blow a fuse since members have been running this for a while now. Cool mod! I'll stop by O'reillys on the way home ^^
  12. Mar 13, 2012 at 10:26 AM
    IndianTaco
    IndianTaco Well-Known Member
    subbed sweet mod
  13. Mar 13, 2012 at 10:34 AM
    ty.s07
    ty.s07 Well-Known Member
    Alabama
    Nice, I might do this today.
  14. Mar 13, 2012 at 10:36 AM
    GEENYUSS
    GEENYUSS Well-Known Member
    Colfax, CA
    1998 TRD Off-Road 3.4V6
    Icons, SPC UCAs, Solo Motorsports Mid Travel LCA, Fox 2.0, All-Pro Exp Leafs, 285/75/17 BFG KO2s
    Any issues with heat or possible melting of the tail light?
  15. Mar 13, 2012 at 2:05 PM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    Rear view camera at night should improve
  16. Mar 13, 2012 at 3:01 PM
    ty.s07
    Alabama
    just tried this using the hacksaw method and it broke one of my bulbs.. so to all you hacksaw guys, be careful. As for where to cut, I lined my hacksaw up with the base (plastic part) of the bulb and used it as a guide since all you need to plug the bulbs in is the metal leads anyways.
  17. Mar 14, 2012 at 3:38 AM
    mjm540ii
    Oxford, PA
    Did this mod yesterday. I used and would reccomend a dremel. The difference is substantial; it is a lot easier to see at night with tinted windows.
    I don't think anyone has it in reverse long enough to do any melting. Plus, after putting my headlights in the oven for the BHLM, I don't think there's anything to worry about.:cool:
  18. Mar 14, 2012 at 5:40 AM
    Gregoryk
    Gregoryk Well-Known Member
    Greg
    tri cities, TN
    05 SR5 4x4
  19. Mar 14, 2012 at 5:58 AM
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    The newer style tail lights still use the same style reverse bulb, not led.
    that looks pretty cool. goes above the license plate and only turns on when the truck is in reverse?
  20. Mar 14, 2012 at 6:06 AM
    mjm540ii
    Oxford, PA
    Figured that out...
    juansebas445 likes this.
