886 Backup light mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FFRNDAN, Mar 13, 2012.
  1. Jan 19, 2013 at 6:50 PM
    #181
    adam337
    adam337 Well-Known Member
    adam
    north east ohio
    SR5
    LED interior, fog light mod, with hyper yellow bulbs leer cap,front tow hook,zombie defense system,smitty built bull bar, 20" LED light bar,12v accessory power supply in cap, rear facing led lights for trailer illumination (tying down quads etc)
    just did mine... dremmel cut the tabs, bent the socket tabs a bit closer to each one, and pugged in the new bulbs... that easy
  2. Jan 19, 2013 at 7:01 PM
    #182
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    http://www.tfwm.com/WhatIsALumen
    http://www.candlepowerforums.com/vb/showthread.php?348984-Lumen-levels-and-Human-Perception
    http://www.applet-magic.com/eye.htm
    So... going back to an earlier post:
    Watts - Lumens - Life Expectancy - Bulb
    50------1257-----200 hours--------885, 886,
    50------1194-----400 hours--------887. 888 (advertised as a low Voltage design? and expensive)
    38-------942-----200 hours--------893, 894, 896
    38-------754-----200 hours--------898, 899
    27-------540-----300 hours--------880, 881, 889, 890
    18-----264/297---500-1400 hours--921 (OEM)
    You are not going to see a visible difference between the 880 series and the 898 series (27/38 watts), likewise, no difference between the two 38w series, but you will likely see a difference between the 880 series and the 893 series lamps (again, 27/38w).
    From the 942 lumen 38w lamp to the 1197 and 1257 50w lamps?
    I don't think you'd notice the difference unless directly comparing them side by side.
    I'm surprised you're not seeing much difference side by side between the 750 and the 1257
    Seems that the safest "bang for the buck" are the 38w 893, 894, 896 lamps.
  3. Jan 19, 2013 at 7:15 PM
    #183
    JimBCa
    JimBCa Well-Known Member
    Jim
    Bay Area California
    2012 TRD Off Road
    Build Duratrac 265/75R16 Load rated E BAMF Rock Sliders, Pelfreybilt Front bumper and skid plates (3) Pro Runner front and rear shocks,Add-A-Leaf springs ATO (Armor Tech Offroad) hilift mounts, Famous Fabrication cb antenna/flag mount CoverKing Tactical seat covers, Flyzeye dash-light ARE Shell, backup light mod SumoSprings and Stops
    "Seems that the safest "bang for the buck" are the 38w 893, 894, 896 lamps."
    Yes, the easiest and best real value is to pick them up at Home Depot, no cutting, squeeze socket contacts and insert. Takes longer to remove the tail light assy. then anything else. Pulled straight out as instructed and pushed back in the same way. Very easy.
  4. Jan 19, 2013 at 7:20 PM
    #184
    Rich91710
    Rich
    Los Angeles
    08 Base
    I agree... I was just referring to benefit/risk of lumen output vs too much power draw.
    It is interesting that the Home Depot lights are getting 750 lumens from only 30 watts, which is awesome. I'm curious if they aren't actually the same as the 38w lamps, but are derated for 12v vs 14.4?
    30w @ 12v = 2.5a
    2.5a * 14.4v = 36w
    It's possible.
  5. Jan 19, 2013 at 7:31 PM
    #185
    Ostrichsak
    Ostrichsak Don't taze me bro!
    Jer
    Northern Colorado, USA
    Supercharged '10 Tacoma 4x4 TRD
    TRD Supercharger + too much stuff to list. Click sig pic
    Which bulb did you buy specifically that didn't require any cutting and what was the price?
  6. Jan 19, 2013 at 9:05 PM
    #186
    Rich91710
    Rich
    Los Angeles
    08 Base
  7. Jan 19, 2013 at 9:09 PM
    #187
    JimBCa
    Jim
    Bay Area California
    2012 TRD Off Road
    yes, that was it. In the light section of the store. You can go to their web site with that link, put in your zip, and it will give you what is in stock for a 50 mile radius. Mine listed 5 in stock, there were 4 on the rack. There was one higher, but figured this was just fine. The prongs are thick and fit just perfect.
    $8.57 / EA-Each
  8. Jan 19, 2013 at 9:17 PM
    #188
    Ostrichsak
    Jer
    Ok, I'll give them a shot. They cost a lot more than the al cheapo ones I found but those also burnt out in a couple of days too. These will likely last as long as the stock ones so money well spent.
  9. Jan 20, 2013 at 12:27 AM
    #189
    hour
    hour TL;DR BOSS
    Brandon
    Fort Collins, CO
    '12 Tacoma RC 4x4 (Sold) '14 Ram 1500, '99 4R
    Level 8 Trackers, Hankook Dynapro LT265/75/16, Bilstein 5100's @ 2.5, Wheelers 3-Leaf Progressive w/ factory overload, 5100s all around // Ranch Camper Shell, BHLM, hacked reverse lights, auxiliary reverse lights // Pioneer AVH-P1400DVD, RF Prime Components, BOSS 10" Sub
    I'm glad people are choosing the safe route. I'm not saying 50w is dangerous, what do I know? I'm saying spending ~$15 and breaking no bulbs in the process is the bees knees.
    1000bulbs.com has a philips 50w 1500 lumen bulb too, should anyone be interested. <$2 per bulb, shipping applies of course - order some extra bulbs for your burnt out above-sink fluorescent light or something to save on shipping costs. 50 hour lifetime sucks, but if you actually hit 50 hours lifetime..for the cost... yea boyeee.
    I'm perfectly happy with my 750 lumen 30w Home Depot bulbs. Truth be told, I still can't see that great out of my camper shell with 2x55w halogens on bumper and 2 x 30w Home Depot bulbs. I've already forgotten what it was like stock. Ultimately worse. Ah well. Derptastic.
  10. Jan 20, 2013 at 7:57 PM
    #190
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    After putting 894's in my Taco a few weeks ago, last night I put 894's in my wife's Lexus ES350 which also uses the 921 bulb. I thought taking out the Taco lamp assemblies was a chore, try a Lexus - you have to remove 6 pressed-in plastic thingys that are a PITA!
  11. Jan 20, 2013 at 9:16 PM
    #191
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I just did this today with a pair of 885's. Same lamp @50watts, but with a straight plastic plug that gets cut off.
    ... What a difference!
  12. Jan 24, 2013 at 7:22 PM
    #192
    LITACO
    LITACO Well-Known Member
    Rob
    Long Island
    2006 DCSB 325,000 Miles
    ARMOR- CBI Moab 2.0 front bumper, Bud Built Mid Skid, Bud Built Trans skid w/cross member, BAMF rear diff skid, Armortech gas tank skid, OEM front tin skid, Icon Lca skids, Demello off-road round tube sliders bolt on but tack welded for strength, Body Armor 4x4 rear bumper, CHASSIS AND SUSPENSION- New frame from Toyota September 2016, One piece rear driveshaft by supershafts of long island, BAMF cab mount chop plates, 5100 front shocks with toytec 3 inch lift coils w/top plates, All-Pro expo leafs, 1.5 inch blocks + 3 degree shims, Daystar rear bumpstops, 5100 extended travel rear shocks, spc light racing uca's, Toytec steel braid rear brake lines, synergy 1.5 wheel spacers, front sway bar relocation blocks, Minor front fender trim, hammer pinch weld mod. PERFORMANCE MODS- TRD Cat back exhaust with Thrush welded muffler, TRD CAI with Updated AFE filter, Air Flow Snorkel. WHEELS AND TIRES- M/T Sidebitter wheels 16X8 4.5 B/S with Falken wildpeak atw3. LIGHTING MODS- Black Bezel headlights brand X resealed before install, 6k LED headlights by Opt7 silicone glued into headlight, 3k hid foglight conversion, 4 inch Hella optilux 6k, 31inch led bar resealed before installation, Fog light bulb reverse light mod, LED interior lights. SOUND SYSTEM- Pioneer head unit with ipod interface (stock unit is junk), Rockford speakers all around, Pioneer 10 inch sub behind rear seat. ACCESSORIES- Armor Tech Hi-Lift Bed mount, OEM Bed mat, Weather Tech floor mats, Wet Okole front seat covers, Cobra 19 CB with Firestick, Home made bolt on antenna mount near tailgate, Ultra Gauge EM, Avital remote start for North East winters.
    doing this tomorrow! thanks!
  13. Jan 24, 2013 at 7:41 PM
    #193
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    I did this with the 894 series(38w) and did the needle nose pliers method to break the contacts. Worked perfectly. I then added some solder to the contacts for a bit of thickness. The light is definitely better than stock.
  14. Feb 2, 2013 at 3:42 PM
    #194
    Ostrichsak
    Jer
    Did this today & it worked flawlessly. Cost was about $16 (had some store credit) & install was a snap. 10mm bolts times four (two per side) and a quick tug & the hard part was done. Take out the old bulb, use a pick or small flat head screw driver to bend contacts inward slightly to hold smaller posts & push mew bulb in. Reverse order to reinstall & a quick test & that's that. Much brighter & I trust these FAR more than the el cheapo's I got from Deal Extreme last time. Thanks!
  15. Feb 22, 2013 at 11:39 AM
    #195
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
  16. Feb 22, 2013 at 3:52 PM
    #196
    df9334
    df9334 Member
    Dave
    Jacksonville, FL
    2011 PreRunner TRD Sport
  17. May 29, 2013 at 10:42 AM
    #197
    sofiasdad11
    sofiasdad11 Reads more than posts
    Near the Windy City, but in the country
    2011 BLACK 4X4 DCLB TRD SPORT
    Flux capacitor (2nd gen version), toytec ultimate liftkit, amp research powersteps, custom katzkin heated leather incl. console cover, retraxpro retractable bed cover, earnhardt jr. cannons@18x9(summer),ballistic jesters@18x9 (winter),285/60/18 nitto grapplers, bodymatched bushwackers, the original Homertaco full satoshi " raptor" grill, viper 5704 remote/smart-start/alarm w/viper cellulor app, ravelco anti-theft device, ipcw tails, redline hoodstruts, oem roof rack, led maps/dome, backup light mod, swingcase storage box, jl audio stealthbox and amps,focal drivers,alpine carplay unit, pop&lock premium handle, seatbelt chime disabled, tailgate hoseclamp mod, rich evans caliper covers, weathertech digitalfit mats, flyzeye V2W,oem bedmat, salex console organizer,speeddawg shiftknob
    Having read thru the entire thread, wondering if this posts mention remains valid? Considering this bulb as an addition to some aftermarket tails on order (IPCW Bermuda Black). Planning a trip to HomerTaco's almamater tomorrow regardless,lol :D
  18. May 29, 2013 at 11:07 AM
    #198
    RearViewMirror
    RearViewMirror Saw things so much clearer once you... were in my
    Craig Christ
    State of Love and Trust
    2023 Subaru WRX GT Manual
    Don't know about the Home Depot bulb but I did the 886 Mod the other night. I'm not too concerned about the extra power draw since my truck has NEVER been in reverse longer than 30 secs at a time. The longest it has ever been in reverse is for the pictures below. I assume that there could be some detrimental effects if left in reverse for too long but I don't know.
    I wish I would have taken some before and after pics but all 4 are of the 886
    Pictures speak for themselves. Also... these are the aftermarket Anzo Tail Lights
  19. May 29, 2013 at 1:03 PM
    #199
    On An Island
    On An Island Assimilated
    David
    Houston-ish
    '12 Black 4x4 DC LB TRD Sport
    Bilstein 5160 reservoir rear shocks, Bilstein 5100 height-adjustable front shocks, SuperSpring SSA19 leafs, Westin bull bar, KC Apollo Pro 6" spotlights, Leer 100XQ cap, K&N air filter, AntennaX 13" Euro antenna, tailgate washers, spare tire tool guide, Console Vault, FJ silver wheel caps
    Guess I'm going to Home Despot tonight.
  20. May 29, 2013 at 1:08 PM
    #200
    RearViewMirror
    Craig Christ
    I wouldn't expect the Home Depot bulbs to look like the pictures. I could be wrong though.
