886 Backup light mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FFRNDAN, Mar 13, 2012.
  1. Mar 14, 2012 at 6:31 AM
    Gene563
    Gene563 Well-Known Member
    Eugene
    Lanoka Harbor, NJ
    08 Double Cab, LB, TRD Sport
    TRD catback exhaust, Undercover hard tonneau, Vent visors, Husky liners, customized seat covers, front license plate bracket, rear suspension TSB, Eibach springs w 5100s@0, & General Grabber AT2 (265.70.17).
    Subscribed for future use.
  2. Mar 14, 2012 at 9:03 AM
    charles08tacoma
    charles08tacoma Well-Known Member
    Santa Cruz, CA
    08 Prerunner SR-5 Access Cab
    White Snug Top shell
  3. Mar 14, 2012 at 1:00 PM
    patpatpat
    patpatpat Well-Known Member
    '11 Prerunner SR5 4cyl 2WD DC
    I can't wait to do this tonight!!!
  4. Mar 14, 2012 at 5:27 PM
    patpatpat
    OP,
    I bought mine for $7.99 x 2 at autozone. <-- want to add this to your first post?
    Arkie-Marty likes this.
  5. Mar 14, 2012 at 6:07 PM
    cintocrunch
    cintocrunch Special Substitute Guest Member
    MD
    2012 DCSB TRD Sport MGM 6MT
    Anytime fogs, Leer Tonneau
    So has anyone compared these to LED reverse bulbs yet? I'd be interested to see which is better.
    Pearson likes this.
  6. Mar 14, 2012 at 6:36 PM
    Bengland25
    Bengland25 Never Forget! 343
    Bradley
    Southern California
    09 Tacoma TRD
    MB Chaos 6 17" wheels, BF Goodrich All-Terrain TA/KO LT265-70R17, Anytime Fog Lights, Anytime Backup Camera, Bed Lights, Tailgate Lock, Light bar with 3 Hella 700FF's, Realtree Camo arm-rests, Anytime DTRL (With Switch), Blue Seas Fuse Block and Circuit Breaker, Custom Bed Light-Bar, Cobra 29 LTD Chrome, 4' Firestik, Masterlock Hitch Key Safe, Bed Storage Compartment Locks, Custom Shovel Bracket Mount, Flag Pole Mount (RED SOLO CUP FLAG!), DIY Washable Cabin Filter, URD MAF Cal., Homelink Garage Door Opener, Volant CAI w/ Ram Scoop, AeroTurbine 3030XL, URD Short Throw Shifter, Custom Satoshi, Blitzpro 21S, 2 Blitzpro 6LZ's, Blitzpro 6D, BAMF Sliders
    Nice write up OP! possibly gonna do this in the near future!
  7. Mar 14, 2012 at 10:06 PM
    FFRNDAN
    FFRNDAN [OP] Well-Known Member
    Dan
    Edinburg, Oh
    09 Acess Cab 4x4 MGM
    I have the stock 09+ "LED" style tails, so yes, no problem
    It isn't, maybe one of the mods can add it?
    I've been running it for about a month, left them on for about 5min when I first did this, no problems at all.
    Unless you drive in reverse for an hour, I don't see a problem :p
    I used VERY light pressure with my saw, using a thin metal blade. Let the saw do the work, do not put extra pressure.
    I think thats about what I found them for, thanks!
  8. Mar 14, 2012 at 10:19 PM
    octacorunner
    octacorunner Well-Known Member
    G
    Orange County
    11 DCSB
    t|x pro rims, trd exhaust painted flat black, retrofit hids on oem smoked headlights, weathertech digifits, interior & exterior LEDs, console vault, 20% tint (need to install: eyelids, lower grillcraft, satoshi by homer)
    you got a rear view camera op? if so can you post some pics of the camera while in reverse? i've tried 2 different LED bulbs, and have considered trying this too
  9. Mar 15, 2012 at 4:02 AM
    Gregoryk
    Gregoryk Well-Known Member
    Greg
    tri cities, TN
    05 SR5 4x4
    It is a plate frame and only goes on when you put the truck in R. Sure you could wire it off a switch to work differently, I just wired it into the R lights.
  10. Mar 15, 2012 at 5:44 AM
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    I'm throwing my LED's in the trash and doing this mod! Thanks for the write up.
    LED's don't work very well at all for those with the rear view cam.
  11. Mar 15, 2012 at 8:50 AM
    1GR
    1GR Toyota Dealer Technician
    Scott
    BC, Canada
    2012 Tacoma DCLB TRD Sport
    Too lazy to read the entire thread, so not sure if anyone has said it. But if this is NOT done right, you are looking at some EXPENSIVE repairs down the road. This runs a lot hotter then what the reverse light bulb. Ever notice a fog light bulb is in glass housing? Do this mod AT YOUR OWN RISK.
  12. Mar 15, 2012 at 8:53 AM
    THExBUSxDRIVER
    THExBUSxDRIVER Victory is reserved...
    GOO5E
    Old Man Tan!
    Not enough.
    On the to do list
  13. Mar 15, 2012 at 9:09 AM
    dfalcon217
    dfalcon217 Member
    Dave
    951
    Did this mod yesterday. Found the bulbs at O'reilly for $7.99. Instead of cutting the posts though, I simply grabbed both posts simultaneously with a pair of needle nose pliers as close to the plastic base as possible and bent back n forth till i got a nice clean snap. Then i put a nice little bend on each one before installing them in the socket for a little extra grippage between the contacts. Worked like a champ thanks for the idea! Nice n bright, highly recommend doing this.
  14. Mar 15, 2012 at 11:19 AM
    FFRNDAN
    Dan
    Edinburg, Oh
    I don't have the backup camera, wish I did. I need to find the thread that shows the add-on how-to. These new bulbs do "throw" light further than stock. Much brighter.
    As long as you don't drive for an hour in reverse, you will be fine, read the whole thread next time, its discussed above.
  15. Mar 15, 2012 at 11:54 AM
    #35
    griffin407c
    griffin407c Well-Known Member
    Upstate NY
    '12 DCLB MGM 4x4 Sport w/Entune
    OME 885s on Bilstein 5100s set at 0 with 1/2" plate spacers. OME Dakars with Bilstein 5100 Extended Length Shocks. 16" Pro Comp 7032 wheels wrapped with 285/75-16 Duratracs
    once again, for the ppl that seem to think this is a big no no. i've had mine for years. no problems at all. original bulbs and everything. i've left them on for several minutes as well. to the guy that thinks the fog lights are glass.... hahaha
  16. Mar 15, 2012 at 12:08 PM
    #36
    patpatpat
    I cut them with a dremel. Just take your time with it.
    I have a OEM backup camera. I will get some before and after pictures on the 1) viewing screen 2) side mirrors 3) as a driver from behind
  17. Mar 15, 2012 at 12:28 PM
    #37
    1GR
    Scott
    BC, Canada
    There are other issues other then overheating, that don't require you being in reverse for one hour.
  18. Mar 15, 2012 at 12:54 PM
    #38
    Oregon TRD
    Oregon TRD "GO DUCKS" Edition
    Ross
    Steel Panthers bathroom floor!
    2005 Mall Krawler
    6" Fabtech Lift, 35" Fierce M/T 17" Eagle Alloy Sim bead locks Naked girls in the bed 10.1" DVD head unit Two 7" Headrest Monitors PS2 in glove box
    I was gonna say.......If you ain't Bo or Luke Duke then you won't have yer truck in reverse for more than what? .....15 to 20 seconds at a time?
  19. Mar 15, 2012 at 12:56 PM
    #39
    Oregon TRD
    Ross
    2005 Mall Krawler
    X2 . I have 5% tint and can't see shit with my reverse lights. If this works without issues then hell....I'm game!
  20. Mar 15, 2012 at 12:57 PM
    #40
    1GR
    Scott
    BC, Canada
    You are all over reading my statement. Overheating can be an issue, if not done correctly, as can shorts, opens, blown fuses, and feedback. Installing something that is not meant to be there, although can work without problem, can occasionally have issues do to installation error. I'm not saying don't do it. Just saying don't do it unless you are absolutely confident in knowing WHAT you are doing.
