886 Backup light mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FFRNDAN, Mar 13, 2012.
  1. Nov 8, 2012 at 4:09 AM
    #101
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    Cut the bulb at "A" if you don't the bulbs won't stay in the pig tail Socket.
    I love my 886 reverse light mod, I bought leds and they had less output then stock. No issue with melting or deforming my lights yet. About 10 months/11000 miles with them so far.:cool:
    http://www.tacomaworld.com/gallery/data/500/liveZ5yjlq.jpg
    886 VS. LED
  2. Nov 8, 2012 at 12:27 PM
    #102
    chipnoreo
    chipnoreo Ready for snow!
    Anna
    Alaska
    Ram Eco Diesel
    Getting 30 mpg on the highway
    subbed
    great mod!
  3. Nov 8, 2012 at 1:28 PM
    #103
    shorti
    shorti Well-Known Member
    So my Canadian Tire didn't have 886's but they have 885's. The plug is straight instead of L shaped. The bulbs look the same, these should work right?
  4. Nov 8, 2012 at 6:45 PM
    #104
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    885 is the exact same thing as 886, but with the straight base. Will work just as well.:thumbsup:
  5. Nov 8, 2012 at 9:10 PM
    #105
    wmdpowell
    wmdpowell Well-Known Member
    Bill
    Essex county NY
    23 trd OR DCSB 4x4 silver
    a cross on my rearview Circle mirror Scotch guard seats
    Will try.
  6. Nov 9, 2012 at 8:58 AM
    #106
    jeremy_283
    jeremy_283 Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    886 vs stock
  7. Nov 10, 2012 at 3:29 PM
    #107
    WATacoRider
    WATacoRider Well-Known Member
    TRD Sport 4x4
    Just got done doing this mod. I had the LED cree bulbs in there. They were brighter than stock, but the beam pattern sucked. So it almost made it worse in a sense.
    I ordered a pair of Philips 886 off ebay for $15 shipped. When I opened the package, it was obvious to me the best way would be to just use pliers and wiggle. On the post inside the socket, there's a crease.
    Just grab it like this and wiggle back and forth. Do not do any side to side action. This will put pressure on the bulb end and may break it. When done correctly, you will just be apply pressure on this crease. After about 30 secs of wiggling, it'll break right off.
    Now I wasn't quite sure if it would fit into the light socket, since the "blades" are so thin. Only way to know was to try it out. And FFFUUUU, they are too thin. Don't know how OP had his bulb secured.
    So the next step was to fold the blade onto it self to increase the thickness of it. I didn't have my camera when I was doing this, but carefully fold it each side in half. On the blade, you will have the skinny bulb filament welded on to it. It goes about halfway down the "blade". Perfect spot to perform the fold.
    I just used my needlenose and another set of pliers. Worked out great. Tight solid fit. Lights appear to work great. Very bright.
    Don't know if polarity is an issue. I just jammed them in place.
  8. Nov 10, 2012 at 9:15 PM
    #108
    GTACO
    GTACO GTACO
    Gabriel
    Murrieta, CA
    07 PreRunner
    Camburg Spindles, Total Chaos UCAs & LCAs, Fox 2.5 c/o front, Fox 2.0 rear, All Pro 3" leafs, Dumped Borla muffler, AFE intake, DTF front bumper, Demello rear bumper.
  9. Nov 10, 2012 at 9:37 PM
    #109
    bosbo6939
    bosbo6939 Member
    WA
    08 dbl cab TRD or
    Just out of curiosity do the 06+ 4runners use the same factory reverse light? I could go check my wifes runner but im feeling lazy right now.
  10. Nov 11, 2012 at 1:36 AM
    #110
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    sub'd.
  11. Nov 11, 2012 at 3:07 AM
    #111
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    I plan on doing this soon. Tired of not being able to see. But my question is, no ill effects from this, for any of you guys that have done it? Obviously, wouldn't be on long enough to get hot enough to melt anything, but are the wires ok to handle the upped wattage of the bulb?
  12. Nov 11, 2012 at 4:09 AM
    #112
    scotch
    scotch Well-Known Member
    Mark
    Centennial, CO
    2012 Tacoma, 2015 Tacoma, 2005 4runner 4.7L
    Lots of Stuff
    It's the same bulb in my 05 4runner
  13. Nov 11, 2012 at 6:54 AM
    #113
    BostonBilly
    BostonBilly Well-Known Member
    Easton
    2018 Jeep Wrangler JL Rubicon
    I went to my local parts guy the other day and they didnt carry the 886 not even a spot for it. I still have others to check I was just driving by that one
  14. Nov 14, 2012 at 2:16 PM
    #114
    Yota_Fox
    Yota_Fox Active Member
    Ben
    Beaverlodge,Alberta, Canada
    08 DCLB TRD Ducks Unlimited
    Grillcraft , Piaa behind grill and fog in bumper,BHLM, Kenwood DD In Dash Nav, Garmin My Mechanic on Nuvi1495, Max 4 Duck blind seat covers, Debadged , cargo bed lights, Wilson cell booster,
    Did this mod 2 nights ago !! I can finally see :)
    This is why I love TW !!
  15. Nov 15, 2012 at 12:38 PM
    #115
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    I'm getting my lazy ass out of the house right now, buy some bulbs & do this mod. I've been running some pricey $40 LED reverse bulbs but the light spread is too narrow. Didn't solve my problem. Hopefully this cheap mod will. Thanks TW!
  16. Nov 26, 2012 at 8:22 PM
    #116
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Wow, swapped the bulbs this weekend and quite amazed at how bright the 886 bulbs are! Awesome mod!
  17. Dec 4, 2012 at 9:27 AM
    #117
    Rufus
    SoCal
    Success finally! I broke several bulbs in the process :annoyed:
    My 1st attempt was with a dremel. Broke a bulb right away. My 2nd attempt was with pliers. I cannot see how this method works :notsure:. Either the bulb shatters or the wire soldered to the flat blade breaks loose. Broke 2 more bulbs this way. My 3rd attempt was back to a dremel. This time I used a different cut-off wheel & that worked. Now I had to bend the flat metal connectors. That was tough because they are short & very stiff. Impossible to use 2 pliers. Plus the glass bulb is very delicate. During this process, I was beginning to have doubts whether this can be done without breaking another bulb. If so, this would be my last attempt. I clamped the metal leads to a vise & "carefully" pushed down on them with a screwdriver. Finally got enough of a bend to fit securely in place in the light connector. What a relief :yay:. This mod felt like I was diffusing a bomb.
    I used 38w 894's instead of 50w 886's. I noticed bulbs get hot quickly & I'm a little worried about overloading the truck wiring. I'm afraid truck may catch fire & blow up :eek:. I'll keep a close watch on these bulbs. Hopefully no harm to my baby.
    Has anyone had problems with this mod? Please let us know.
  18. Dec 4, 2012 at 9:47 AM
    #118
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    What brand of bulb did you use? I was also planning on going the 894 route in hopes of creating less heat.
  19. Dec 4, 2012 at 9:54 AM
    #119
    Rufus
    SoCal
    Sylvania.
  20. Dec 4, 2012 at 10:05 AM
    #120
    Jon850FL
    Jon850FL is Lurkin'
    Jon
    DFS, FL
    used 880 bulbs the other day, worked great.
