886 Backup light mod
Discussion in '2nd Gen. Tacomas (2005-2015)' started by FFRNDAN, Mar 13, 2012.
  1. Dec 4, 2012 at 10:11 AM
    #121
    Rufus
    Rufus Well-Known Member
    SoCal
    2010 TRD PreRunner Sport
    OEM Truck Bed Extender, Window Tint, Tailgate Security Mod, OEM Spare Tire Lock, Cam Locks (storage compartments), OEM Bed Mat, OEM Skid Plate, Stant 11504 Locking Gas Cap, TW Edrin55 OEM Running Boards, Pop & Lock w/Back-Up Cam, Black WeatherTechs, Red Line Quick Lift Plus Hood Struts, Wet Okole Front Seat Covers-black/charcoal with red & white TRD graphic & back seat pockets, DIY Satoshi Grillcraft & Old School Toyota Badge, TW ZonKs Black UWS Low Pro Truck Box, Rear Suspension TSB, 3M Scotch Guard Paint & Headlight Protection Film 8mm Urethane, Flyzeye V2 Wired Amber/White/Amber Interior LED Lights w/Silver Case, Sleek Looking Black LED Tail Lights from K2 Motors (Identical to OEM, but black).
    Are those 880's 50w? Any problems yet?
  2. Dec 4, 2012 at 12:13 PM
    #122
    sporttracguy
    sporttracguy Well-Known Member
    Puyallup, WA
    Magnetic gray tx pro double cab
    3" Lift spidertrax wheel spacers grillcraft grill Color matched grill Color matched eylids PIAA 520 lights behind grill HIDs in headlights and fog lights Debadged Plasti dip lower grill
    Another satisfied customer! What a difference!
  3. Dec 4, 2012 at 1:38 PM
    #123
    Twiostaco
    Twiostaco Well-Known Member
    Austin
    Utah
    08 White DC TRD Sport
    5100's front set to .85 w/eibach springs, 5100 rear w/toytec 2"AAL, Light Race UCA, 17" Black Rhino Ocotillo wheels, 265/70/17 KO2's, K&N drop in filter, Grill Craft front mesh, one piece driveshaft (vibes gone) rear diff breather mod, BHLM, Fog anytime, 886 reverse bulbs.
    I've been running the 886 for a few months with no issues
  4. Dec 4, 2012 at 6:02 PM
    #124
    CLynch
    CLynch Well-Known Member
    Charlie
    Upstate New York
    None
    Fifty percent done. I ran out of bulbs. The one that is in there, is wedged in with the broken piece of flat metal. The other bulb just shattered, almost immediately. Real happy with just one done. Should I get rid of the one that is working due to the wedge issue? Thanks. Will probably just get from CSJumper. I just was cleaning basement and work area and found some 880's. No real lost money as I did not even know I had them. Thanks for the mod and time killer.
    Charlie
  5. Dec 28, 2012 at 10:12 AM
    #125
    Redtaco12
    Redtaco12 Member
    '12 taco 4x4 dc longbed
    I finally did this yesterday with the 866 bulbs. I had been skeptical if they would make much of a difference but it sure does. The backup camera is now usable at night where before it was too dark to do make much out on the screen.
    The one thing that I noticed is that the bulb is wider than wanted to fit securely in the plug. In fact one vibrated out after a short drive. I was having a hard time getting it to secure until I accidentally broke off just a tiny piece of the glass on the bottom of the bulb. Then it fit right down in the plug nice and snug.
    I didn't bother trying to break off the light with the flat blades still attached. I just broke the wire loose from the blades and folded the wire over onto itself and it made a nice connection in the plug.
    Very well worth the time!
  6. Dec 28, 2012 at 5:05 PM
    #126
    Team Flatline
    Team Flatline Not squatin' w/ my spurs on...
    Eric
    Up a creek, Fla
    PreRunner
    Maxtrac'd, Icons, Dakars...........
    Has anybody tried to use this mod as a strobe setup? I was thinking of doing this in conjunction with a Feniex controller http://www.feniex.com/product.php?prod_id=274
    For additional visability.
    What do ya'll think......will it work?
  7. Dec 30, 2012 at 4:05 PM
    #127
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    I did this with a philips 894 bulb, very easy. I separated the prongs by wiggling it back and forth with pliers, and I did have to fold those prongs over on themselves to get a snug fit, although one of the lights can wiggle a little back and forth, but not out. They looked brighter, I will update if I notice a difference with the back up camera tonight.
  8. Dec 30, 2012 at 4:24 PM
    #128
    weazel
    weazel Well-Known Member
    I did the 894 myself and they are much brighter. I used a soldering gun and added some solder to the ends of the metal prongs, really snug fit.
  9. Dec 30, 2012 at 5:03 PM
    #129
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    I've had my 894's in for a while now, and for some odd reason I get a big smile on my face every time I back up at night.
  10. Dec 30, 2012 at 5:53 PM
    #130
    Country101
    Country101 Well-Known Member
    NW Arkansas
    08 tacoma access cab V6 4x4 manual
    dirty truck mod, custom trailer scratch on tailgate, husky floorliners, OME Lift
    so the 894's are a lot brighter than the 886 or just the oem?
  11. Dec 30, 2012 at 5:58 PM
    #131
    landphil
    BC, Canada
    Tundra 5.7 mod
    894s are not as bright as the 886's, as they are 38w, compared to 50w. A bit safer for the wiring, B/U light switch, and lenses IMHO, and still plenty bright, way better than OEM.
  12. Dec 30, 2012 at 6:25 PM
    #132
    Juggernaut
    Juggernaut Captain
    Sacramento
    25 TRD OffRoad DCSB
    Correct. For Sylvania bulbs at least; the differences between the three bulbs are:
    Stock 921 bulb is 18 watt, 264 lumens
    894 bulb is 37.5 watt, 942 lumens (3.6 x brighter)
    886 bulb is 50 watt, 1257 lumens (4.8 x brighter)
  13. Dec 30, 2012 at 11:05 PM
    #133
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Another thing to consider when buying the 8XX bulbs is to avoid the black tip bulbs, or scrape off the black coating if you can. Since most of these 8XX bulbs are for fog lamps, the black tip reduces the glare for oncoming drivers. As reverse lights, we want the light to go everywhere. The reflector is designed to do that, but the black tip may, or may not, affect the luminosity.
    Here are some specs taken from the GE website; life expectancy may vary among manufactures.
    Watts - Lumens - Life Expectancy - Bulb
    50------1257-----200 hours--------885, 886,
    50------1194-----400 hours--------887. 888 (advertised as a low Voltage design? and expensive)
    38-------942-----200 hours--------893, 894, 896
    38-------754-----200 hours--------898, 899
    27-------540-----300 hours--------880, 881, 889, 890
    18-----264/297---500-1400 hours--921 (OEM)
    High performance versions (ie NightHawk, Silverstar, Xtreme, etc...) may reduce life expectancy by 50% or so.
    OEM 921 Philips is 1000 hrs -SilverStar is 175hrs! The NightHawk is 1400 hrs. Check the manufacure's website for specs.
    http://genet.gelighting.com/LightProducts/Dispatcher?REQUEST=PRODUCTS&PRODUCTLINE=Lamps
  14. Dec 31, 2012 at 12:52 PM
    #134
    calebm12
    calebm12 Well-Known Member
    MD
    2011 trd tx
    Weathertech, hand turned wood shift knob, rear view mirror mod, grillecraft MX, hella 500s
    Did this today. Ended up having to use 894 cause auto zone didn't carry 886. Dremel and bend and install. Looking forward to seeing what they look like tonight.
  15. Jan 2, 2013 at 8:31 AM
    #135
    Mudphish
    Mudphish Member
    Andre
    Martha's Vineyard
    13 TRD OR Tacoma
    I only had to break one bulb to realize I shouldn't be messing with the bulb I should modify the socket. Bent the little tabs in, plugged in the bulb, snug fit enuff said. I stepped out side of the box and it worked. Hope this helps.
  16. Jan 2, 2013 at 9:14 PM
    #136
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    Don't know how I missed this post when I did mine tonight. One went perfectly smooth and the second bulb broke right away. Will do your method tomorrow when I pick up a new bulb.
    On another note, these bulbs are bright as fuxk.
  17. Jan 5, 2013 at 6:17 PM
    #137
    SCConstable
    SCConstable Member
    Carolinas
    2010 DCSB 4x4 SR5 TRD
    Pictures would help make this more useful. I did the 894's and it is much brighter. Apparently not a problem, but going to 50 watts was more than I was willing to chance on the electrical system.
  18. Jan 8, 2013 at 8:21 AM
    #138
    Benson X
    Benson X My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    Damn, how have I not done this yet?!?!?
    I was ready to pull the trigger on some 9w CREE LEDs with a 440 Lumen output, but I was worried about visibility at close range since the LED "projector lens" throws the beam further from the truck than a normal halogen flood pattern.
    I recently tinted my LED tailights, and taped off the "clear" back-up light area to maintain full light output. I also have 10% tint on front windows, a canopy with tinted windows, and the back-up camera, so the increased output will definitely help me out while on the trails at night. So excited to get this mod done! :D
    I found some generic bulbs for super cheap @ lightexports.com. Total was $6.80 shipped for both bulbs.
    They seem to have whatever bulbs you want: 880, 894, 886, 887, 888 etc.
    I opted for 886, since the specs were the same as 887/888. There was no indication that lifespan or lumen output was different.
    I will post before/after pics when I get them installed.
  19. Jan 8, 2013 at 2:19 PM
    #139
    Dizzy TRD
    Dizzy TRD Member
    North Carolina
    07 TRD Sport 4x4
    BHLM, Tinted Taillights, Debadged, 35% Window tint, Removed mud flaps, LED dome, map and tag lights, 886 reverse light swap, sill protectors, TRD Center caps, Banks Monster Exhaust, Bed lights, D-rings added to front of bed
    I just completed this mod so we will see if there is a difference tonight. I used the 885 50W bulb and a hacksaw. No problems. Hope it makes a true difference, with tinted windows I can't see anything at night.
  20. Jan 8, 2013 at 2:24 PM
    #140
    KCDuran
    KCDuran Stormtrooper
    Kyle
    South Jersey
    5 Lug'n 4 banger
    Icon/TC Mid Travel Kit, Kenwood Deck, Helix Audio System, BHLM (With Tinted Reflectors), Tinted Taillights, Satoshi Grill (color matched to super white), Stormtrooper sticker, Air Force sticker HUA! Re colored gauges (White numbers and ODO with Blue Needles) Magnaflow Glasspack Muffler, Stainless steel exhaust tip, 8k HIDs, LED Satoshi, Eye Lids, ARB locker (4.10 Gears), 8k FOG HIDs, LED Head Lamp, Tonneau Cover
