886s the only option?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by kyzmyss, Jan 21, 2010.
  1. Jan 21, 2010 at 9:06 AM
    kyzmyss
    kyzmyss [OP] Well-Known Member
    NorCal
    07 Dbl. Cab TRD Sport 4x4
    Hi All,
    Ready to order the All-Pro bumper and was wondering what my options are for the front suspension.
    Currently I have the 885 OME springs with OME N140s shocks. I hear the 885s will sag with the added weight to the front.
    I appreciate the current ride quality and understand the 886s (though will support the added weight from the bumper) will be a stiffer ride. Are there other options with the current shocks I have? Or would I need buy coils or new shock/spring setup?
    Any advice is greatly appreciated.
    Thanks in advance.
    Best Regards,
    Kris
  2. Jan 21, 2010 at 9:08 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Yes, they are a stiffer spring, but the weight from the bumper will help reduce a fair amount of the extra spring resistance.
  3. Jan 21, 2010 at 10:01 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    Commifornia
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    To much to list...see sig for more...
    Time to invest in some coilovers.
  4. Jan 21, 2010 at 10:11 AM
    Brunes
    Brunes abides.
    Rotorhead
    He already has- His 885 COILS are OVER his shocks.
    You just need the 886 coils to combat sag. If you aren't worried about a little droop-Don't worry about swapping. The springs will ride differently but with the weight change- You may not notice anything.
  5. Jan 21, 2010 at 10:14 AM
    sirsaechao
    Tim
    Commifornia
    I know he does but if he does get 886's he would have to swap the 885's out. I say keep the 885's for now...live with the droop and since they will sag n e ways...save up for coilovers for the near future.
  6. Jan 21, 2010 at 10:19 AM
    Brunes
    Brunes abides.
    Rotorhead
    My point was he has coilovers. I assume you are suggesting "adjustable" coilovers...but the 885 springs going over the shocks makes the OME lift a coilover set up.
    And it's only slightly more work to replace the springs and keep the same parts over wise...and FAR cheaper.
  7. Jan 21, 2010 at 10:20 AM
    Afwrestler1986
    Johnstown, NY
    Yup. Coilovers come on stock tacomas.
  8. Jan 21, 2010 at 10:22 AM
    sirsaechao
    Tim
    Commifornia
    Yes 'adjustable' coilovers like ICON, Sway, Camburg and etc...and it is more expensive and costly but it eliminates the sag of extra weight added and gravity over time.
  9. Jan 21, 2010 at 10:23 AM
    Anathollo
    Anathollo www.saveadane.org
    Houston
    07 Tacoma TRD Sport
    Icon coilovers, Rear Fox Resi-shocks, 285/70/17 Toyo A/T's, Touchscreen JVC Headunit, Custom Rhino-lined sub box, Rocksford Fosgate components and Dual Rockford Fosgate 10" shallow subs, Pioneer and Rocksford Fosgate amps, 1250 watts total, Autometer Volt and Trans gauges with Lotek A-pillar, K&N Drop-in filter, WO Seat covers, Tint, NST WP pulley, Hi-lift jack, Diff breather mod, horn relocation mod, extra "D" rings, de-pinstriped, carrier bearing drop, Rear backup 886 bulbs, Camburg UCA's, AMW Catch can, BHLM, OME Dakars with AAL, Procomp 7089's, Front single hoop Demello bumper, Superwinch Tiger Shark 9500, Amsteel 3/8th synthetic line
    X2! OME's are the best bang for you buck.
    Yes, the 886's are going to be a stiffer ride until you install the front bumper. Then it should be near the same as the 885's.
    And I think if you keep the 885's, then you're ride quality might suffer because the springs weren't designed to bear the extra weight in the front.
    I don't know for sure, but I know you should upgrade. But realize you have time to save up for the new 886's by wearing out the 885's.
  10. Jan 21, 2010 at 10:25 AM
    Anathollo
    Houston
    07 Tacoma TRD Sport
    the only reason they do this is because of the spring rate. I think fox and toytech's are around 750#. Well thats what the 886's are, so it's the same thing. just without the "adjustability" part.
    Edit: The 886's are 660#.
  11. Jan 21, 2010 at 10:56 AM
    Masada
    Masada Well-Known Member
    Taylor
    Laveen, AZ
    05 Tacoma 4x4 TRD Off Road
    All Pro Steel Plate Front Bumper| All Pro Light Bar| All Pro IFS Skid Plate| All Pro E-locker guard| PIAA 510 Fog Lights| Hella 700FF| Fox 2.5 Coilover| Bilstein 5100 on the rear| BHLM| Grill Craft MX Series insert| Added two D-rings to bed|AVID Off Road sliders| AFE Dry Flow S| Gibson Cat Back| Custom Bedbar with hilift mount| Camburg 1" Uni-Ball UCA's| Hi-Lift 48" Extreme
    I'm speaking form experience here, I have the all pro front bumper and 886 coils. The ride is good, but if I had it all to do over again I would have gotten the 885 coils. The bumper doesn't weigh anywhere near the ARB bumper so the spring rate IMHO is too high for the lighter All Pro bumper.
    I have taken my rig off roading and it handles great, but the down travel is severely limited for some reason. It could be the shock or UCA's I'm using, but I feel that if I had the 885 it wouldn't be so high a lift and I would have better articulation in the front end.
    I'm thinking I may have to get the larger Uni-Ball UCA's or some extended travel shocks.
    I'm not saying my setup is right or perfect, but my experience is when I go over a large bump I get a loud thud sound when my wheels travel downward.
  12. Jan 21, 2010 at 11:04 AM
    Brunes
    Brunes abides.
    Rotorhead
    In addition- That adjustable thing only goes so far...All springs sag no matter what. You can only adjust up so much before you run out of threads or run out of travel.
    And the 886s compensate for the weight just fine.
    Look at Mas post above me- I didn't even really think about the weight difference between All Pro and the ARB....Might be ok to try with the 885s and see what happens.
  13. Jan 21, 2010 at 11:20 AM
    Masada
    Taylor
    Laveen, AZ
    I have the 886's now, and I like them but I just don't want to be limited so much on my down travel. My UCA's are at about the end of their travel, so I think they may be hitting the springs when I go over a large bump and making the sound. I'm wondering if the TC or Camburg UCA's with the 1.25 uni-ball would be better for down travel than the 1" ones I have now.
    Plus I'm not sure if it hurts me that that I'm still running the 5100 in front with the 886 on them.
  14. Jan 21, 2010 at 12:27 PM
    Masada
    Taylor
    Laveen, AZ
    I have the 5100 set at 0 and I bought some used Camburg 1" uni-ball UCA's. I can't think of anything else causing it to hit. When I go over a speed bump at speed, I hear a loud clunk from the front coils. It was never there when I had my previous set up.
  15. Jan 21, 2010 at 12:42 PM
    sirsaechao
    Tim
    Commifornia
    You have OME shocks so I am sure the 886's would ride nice since they are properly valved for those springs.
  16. Jan 21, 2010 at 12:47 PM
    Anathollo
    Houston
    07 Tacoma TRD Sport
    Okay thanks I couldn't remember. having one of those days...
    and Listen to Silverback, he knows alot!
    And I got to ride in his truck before he got the fox coilovers, and it rode amazing offroad and onroad. riding with him pretty much sealed the deal on getting OME's rather than the billie's.
  17. Jan 21, 2010 at 12:57 PM
    Toytec Lifts
    Toytec Lifts Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    CORRECTION: Toytec uses a 600# coil for the Tacoma's
    and the 886 are not 750 either, try 660#
    Big difference.
  18. Jan 21, 2010 at 12:57 PM
    Anathollo
    Houston
    07 Tacoma TRD Sport
    Yeah I was thinking about something else. :eek:
    My bad.
  19. Jan 21, 2010 at 12:59 PM
    Toytec Lifts
    Rocky Mountains
    No worries man! :D
  20. Jan 21, 2010 at 11:54 PM
    kyzmyss
    NorCal
    Wow! Thank you all for the prompt replies.
    This is very helpful.
    Tacoma World Rocks!
