89' 7.3, f-350
Discussion in 'General Automotive' started by saltbranch, Dec 29, 2009.
  1. Dec 29, 2009 at 5:37 PM
    saltbranch
    saltbranch [OP] Well-Known Member
    Tx
    1996 2.4,2wd,5spd, stock, 250k
    Does anyone have any experience with 1 of these trucks? I found a good deal on 1. Its got the 7.3 IDI non turbo,5 spd, 4.10, crewcab, single wheel rear(not a dually). I had a 84', 6.9 years ago that was a real good truck, not much on power. Anyways, the truck will do what I need for hauling capacity, seems to run good.
    Thx
  2. Dec 29, 2009 at 5:50 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    The 7.3 IDI is a bored out 6.9. One of the major issues you have to look out for is cavitation problems with the thinner cylinder walls. Stick with Motorcraft/Beru(sp.) glow plugs and run diesel kleen and you'll be golden. My '87 6.9 4x4(it was free). Also, the 5 speed is the way to go. The 3 speed auto sucks too much petrol.
  3. Dec 29, 2009 at 5:52 PM
    350TacoZilla
    350TacoZilla Well-Known Member
    Hancock MD
    1997 3RZ 5spd 4x4 Reg Cab
    2.7L 3RZ,K&N filter, 4" deck plate mod,flowmaster 40 series,3" suspension lift, hybrid 52"chevy/toyota rear springs.
    pretty much bulletproof motor, think the 5spd is a zf not sure but the truck should be good truck as long as it wasnt beat on and had normal maint.
  4. Dec 29, 2009 at 6:44 PM
    saltbranch
    Tx
    The starter is out on the truck, we pulled started and it seems to run pretty good. The body is straight, it did have a 5th wheel bolted into the bed at 1 time, holes are there. Since it was a bolt in 5th wheel, I doubt it was pulling alot of weight. All the fluids look good.
    Basically I am trading a 93' Dakota,5.2,auto,4x4 hunting truck that has rusted out fenders/bed. The Dakota can be street legal very easily, has A/C. Body is dented up abit. But runs like a bat of H-LL. Dakota does need a brake line and e-brake cable replaced. Both trucks have not been road legal for over a year.Pretty much a project/toy swap.
    Thanks for the input.
