89 toyota truck driveshaft angle?
Discussion in 'Toyota Trucks & SUVs' started by jroach321, May 28, 2008.
  1. May 28, 2008 at 7:01 PM
    jroach321
    jroach321 [OP] Member
    Chattanooga
    01 TAcoma 4x4 white
    Was curious what angle others were running for rear driveshaft angle.
    Putting finishing touches on 89 extra cab truck all-pro ifs to straight axle conversion. its a 5 inch lift with heavy-duty rear springs. I have already removed the factory rear spring perches. As it sits it is 10 degrees and looks about normal but didnt want to weld new perches without getting some input. Thnks
  2. May 28, 2008 at 7:05 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If you dont get the answer here, Try TTORA.com. They have alot of info on SAC's and earlier modle Toyota trucks. :)
  3. May 29, 2008 at 4:13 AM
    jroach321
    Chattanooga
    01 TAcoma 4x4 white
    I posted on there as well. thanks for the help
