9 inch suspension lift questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by CAN8EN, Feb 24, 2011.
  1. Feb 24, 2011 at 9:29 PM
    CAN8EN
    CAN8EN [OP] Active Member
    matt
    winnipeg
    07 trd sport
    black grill guard, 6 inch pro comp stage 1, pro comp wheels, 315/70/17 GoodYear Wrangler MT/R kevlar
    So I have been asking around and looking around about trying to put 9 inches of lift on my tacoma so that I can fit 37's
    I have found some good information so far but does anyone have the answers to these questions? Preferably someone who has done this. (also I'm not concerned about peoples opinions on lifting a tacoma 9 inches) I will not be doing any off roading this is just for looks I like the look. I do not want to get a body lift.
    I currently have a 6 inch pro comp. now from what I understand this leaves the cv angle the same as stock.
    If that is correct wouldn't putting another 3 inches of lift be the same as someone putting 3 inches of lift on a stock tacoma?
    I know I would need to re-gear with 37's I have been thinking about 4.88 does anyone know if this is correct? and how much do the gears cost?
  2. Feb 24, 2011 at 9:33 PM
    especk
    especk Nothin' Special
    Erik
    Redding, CA
    2010 Tacoma Reg Cab 4x4
    3" OME lift with 885 coils on nitrocharger 90000 shocks with 5mm trim packer on driver's side, TC UCAs, Rear OME Dakar leafs with nitrocharger shocks, All-pro U-bolt flip kit and 3* Toytec shims, extended rear brakelines, 16" Raceline Rockcrusher 887 wheels with 3.6" backspacking, BFG KM2 305/70/16 tires, Doug Thorley header, Doug Thorley catback exhaust, Volant CAI with ram air, Weathertech floor mats, Kicker 12" sub, Kenwood 500W RMS amp, Relentless Fab front and rear bumpers, 4.88 gears, custom flatbed with swing out tire carrier
    Ya it would be the same as putting a 3" lift on a stock truck as far as cv angles are concerned. It will however make your rear driveline at a super steep angle and may cause vibes.
    Gears would be a great idea and they cost about $700 per axel installed.
  3. Feb 24, 2011 at 9:37 PM
    especk
    Erik
    Redding, CA
    I believe member tacoridinhigh is runnin 37s with a similar setup
  4. Feb 24, 2011 at 9:41 PM
    JasoTaco
    JasoTaco Well-Known Member
    Salt Lake City, Utah
    09 Tacoma TRD Off Road
    ToyTec Ultimate 3" Lift -TSB Rear springs - TRD Cold Air Intake - TRD Skid Plate - Total Chaos Upper Control Arms - 2 Hella Rallye 4000 lights (130W Bulbs) - Clear Bra - Under Coat - Bed extener - Toyota Bed Mat - Weathertech floor mats - Tailgate hose clamp & washer mod - PIAA Fog Lights - ScanGauge II - Beefed Sliders - Differential Breather Mod - Heated Seats - All-Pro Bumper - Warn M8000 Winch with wireless controls - Boztec Diff Skid - ATO skids
    Have you considered a SAS? You could easily get 9+ inches out of that not to mention it would be bad ass to see more of them done to second gen Tacoma’s.
  5. Feb 24, 2011 at 9:46 PM
    mountainwolfpup
    mountainwolfpup Ford Guy (Formerly known as a Toyota Guy)
    Vancouver, WA
    2015 Ford F150 Lariat FX4 3.5l Eco
    First month of ownership... This month I'm removing front air dam, and also Rhino lining the bed.
    Yes, you will definitely have to re-gear. You should be fine running 4.56 which should be pretty close to bringing you back to a "normal"/stock feel.
    Personally, I'd say go with the 4.88
  6. Feb 24, 2011 at 9:48 PM
    MrGrimm
    MrGrimm Mall Crawler
    Dean
    Wisconsin
    2006 Toyota Tacoma 4WD w/TRD Sport Package
    See build page
    ^he wants to do it for the 'look' so throw the idea of SAS out the window.
  7. Feb 24, 2011 at 10:01 PM
    JasoTaco
    Were did you get $30K+?
    http://www.tacomaworld.com/forum/solid-axle-suspension/138316-sas-quick-guide-cost.html
    I'm not 100% sure the cost on a second gen (not many out there) but you can easily do a first gen for well under $10k with premium parts. Obviously doing a SAS with coilovers vs. leafs is going to be more expensive.
    If you go the junk yard route you could do it much cheaper. My bro. in-law did his own under $4K
  8. Feb 24, 2011 at 10:04 PM
    JasoTaco
    Wouldn't a SAS "look" badass?
    It's just an option.
  9. Feb 25, 2011 at 12:57 AM
    400lbGorilla
    400lbGorilla ^Son of a hamster, I smell of elderberries.
    T-LAM
    Ocean City, MD
    BSP 4X4 BASE
    Roof Rack, TRD exhaust, Hood Shield, Side Steps, 5% Tints, Tow Package, Bed Extender, Billies at 2.5, Toytec TSB AAL, Avid Offroad Bar, Cruise Control, Removed Sway, Hella 700s, 6000k HIDs, diff breather mod. DTRL, BHLM,Sockmonkyed.
    I enjoy the sig. it brings a smile to my face. You have yourself a handsome family my friend.
  10. Feb 25, 2011 at 2:43 AM
    06rubi
    06rubi Well-Known Member
    Kenney
    Pueblo West, CO
    10 MGM (wife's truck)
    Debadged, tinted windows, 7 pin relocated, bed lights, 12 volt socket in bed of truck, on board air, auxiliary fuse box, grill craft, hella 500's, t-rex eyelids, pink budbuilt skids, icon remote resi coil over, camburg uca, alcan rear springs, ubolt flip, icon 2.5 remote rear resi shocks
    Couldn't you fit 37's with glass fenders and bedsides? I'm guessing a pretty good hack at the cab mount would be in order too.
  11. Feb 25, 2011 at 5:07 AM
    92LandCruiser
    92LandCruiser Well-Known Member
    Nevada
    80 series Land Cruiser
    Cummins, tons, 40s
    4.88s
    http://eastcoastgearsupply.com/
    Depends on labor costs but there are the costs for the gears.
    Personally I think you should trim and you could fit the 37s with your 6" but it's your ride.
  12. Feb 25, 2011 at 9:42 AM
    CAN8EN
    matt
    winnipeg
    07 trd sport
    Thanks for all the info. not sure If I would be able to get 37's without more lift though... I think that would be alot of cutting.
    Also I figured the extra lift will add more of the look that I want.
    I think a SAS is not a good option for me too much cash and I don't really think it should be needed if I'm not doing any off roading.
    and thanks for the link to prices for gears
  13. Feb 25, 2011 at 12:39 PM
    jdaddyia
    jdaddyia Member
    Iowa
    Hey that's a great looking family....
    Now can I have your mom's cell # so I can text her "Can I hit that?" and add it to the thread on here??? She's freakin hot.
    Just kidding....or am I?
  14. Feb 25, 2011 at 2:01 PM
    cantac09
    cantac09 Official TW Igloo Builder
    Hugh Jass
    Saskatchewan
    tundra
    stock
    with 9 inches of lift you might get blown over driving down portage and main!
  15. Feb 25, 2011 at 2:06 PM
    98_Mud_bug
    98_Mud_bug 98_mud_bug
    lucedale Ms.
    98 tacoma sr5/ 06 x-runner
    3 inch suspension lift, night shades corner and blinkers projector headlights with halos and 3 led's 18 inch kmc xd rockstar wheels,275/65/18 kelly safari tsr's, bush whacker fender flares 7 inch touch screen, 2 kenwood 12's, Magnaflow exaust single in dual out,
    taco ridin high has about 9" and 37's with 4:88's if i remember correctly. you could pm him with more questions if you want.
  16. Feb 25, 2011 at 2:15 PM
    Two40TacomaAZ
    Two40TacomaAZ Active Member
    Ricky
    Phoenix,AZ
    02 PreRunner SR5
    33" DuraTrac's, Fog Light Mod., 2.5" ToyTec Lift, Debadged, Gillcraft Mx Mesh Grill, WeatherTech Floor mats, Chaos Rims, K&N Drop-In Filter, 12K H.I.D's, Limo Tint, KYB Shocks, Kenwood Deck, JL Audio W-1, JL Stealthbox, ALpine Speakers, Kenwood Amp., Alarm, Tinted Tail Lights, Pre-Runner Front Bumper, Custom Rear bumper, 3 - 6" KC Daylighters, Removed Fender Flares, L.E.D license plate lights
    I feel like that dude is fucking with you guys bout his picture, his name is "grandmas computer", like really? His profile is a joke as well. Apparently he designs holiday napkins. ha.
  17. Feb 25, 2011 at 2:20 PM
    MyYota05
    MyYota05 Well-Known Member
    Muskogee, Oklahoma
    2005 Toyota Prerunner w/ TRD Offroad Pkg.
    3'' Lift Kit, Bed Rug Liner, Black Rims
    :rofl::rofl::rofl:
  18. Feb 25, 2011 at 2:25 PM
    triad
    triad Member
    Houston, Tx
    11' TRD TX|Pro Speedway Blue
    Undercover, TRD Cold Air Intake, WeatherTech Mats
    lol.. this thread.
  19. Feb 25, 2011 at 2:26 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail, 88 pickup, Tundra Platinum
    A few bolts are different.
    a family full of Bert Reynolds' is who.
  20. Feb 25, 2011 at 2:31 PM
    jrider636
    jrider636 Well-Known Member
    justin
    tally,fl
    08 tacoma prerunner
    no way thats his family.....but if it is he's old as shit haha
