90K Tune Up/Service Advice? Spark Plug Wires
Discussion in '2nd Gen. Tacomas (2005-2015)' started by mabrown24, Nov 27, 2012.
  1. Nov 27, 2012 at 9:51 AM
    mabrown24
    mabrown24 [OP] Active Member
    Brownie
    Clemson, SC
    08 DC PreRunner SR5 Silver Taco
    Satoshi Mod, BHLM, Volant CAI, OEM Roof Rack, Bull Bar, 4" Side Steps, Front & Rear TSB, 5.8" Pioneer TouchScreen DVD Head Unit, Sony 6.5 Componet Speakers (Front), 5.25 (rear), Advance Tri-fold hard cover, Blacked out Badges.
    Hi, I am approaching the 90K mark on my 2008 DC 4.0 Prerunner and am debating on performing the appropriate tune up/service that is required. I've searched the internet and this site and have only found spark plug suggestions. I would really like a suggestion on the Spark Plug Wires and where to buy them. Does anyone have any suggestions? And please, if anyone has any suggestions or tips on the rest of the tune up (rear diff oil change, re-torqueing the propeller shaft bolt, etc) please feel free to add.
  2. Nov 27, 2012 at 10:00 AM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Hopefully others with more experience will chime in. With modern coil-on-plug ignition, I am not sure if the plug wires are still as stressed as with older distributor ignition systems.
    Diff fluid change guide: http://www.tacomaworld.com/forum/technical-chat/24545-changing-differential-fluid-step-step-how.html
    Propeller shaft bolts (basically the bolts holding the U-joint flanges) should be checked every year or 10k. :) Simply attempt to tighten them with long wrenches. The reason those bolts are part of the maintenace schedule is because the driveshaft rotational inertia has a coupling effect that can [in theory] loosen those bolts.
  3. Nov 27, 2012 at 11:21 AM
    650H1
    650H1 Well-Known Member
    Michael
    VA
    2020 (Cement) TRD O/R
    I'm going to be doing this soon as well. Any write ups on changing the front diff, tranny, or transfer case fluids?
  4. Nov 27, 2012 at 11:28 AM
    benbacher
    benbacher Purveyor of Fun Vendor
    Anchorage, AK
    '10 Tacoma 4x4 LBDC SR5 TRD Sport
    Too many to list now.
    It's really easy. ^ fill plug comes out first, then drain plug, drain,put plug back in and fill until level with the full plug hole. Just did mine a few weeks ago and it was way easier than I thought.
  5. Nov 27, 2012 at 11:29 AM
    benbacher
    Anchorage, AK
    I should clarify I only did the front diff this way. Tranny I would be a lot more accurate with amounts.
  6. Nov 27, 2012 at 11:29 AM
    tacoftw
    tacoftw 5100s are the same price as spacers, seriously
    McDonough, GA
    05 Double Cab 4x4
    5100s, camburg arms, toytec AAL, 285s on m/t 17x9
    2nd gen tacos dont have spark plug wires, its coil on plug, and the diffs both have fill and drain plugs
  7. Nov 27, 2012 at 1:25 PM
    mabrown24
    Brownie
    Clemson, SC
    All is very good information. So you're saying I dont need to change the spark plug wires at all? If anyone has a part number for items that need to be changed, I'd appreciate it. Thanks a million guys!
  8. Nov 27, 2012 at 7:20 PM
    tacoftw
    McDonough, GA
    05 Double Cab 4x4
    yes, because it doesnt have spark plug wires
