91????
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ismael_Navarro, Sep 15, 2020.
  1. Sep 15, 2020 at 7:39 PM
    Ismael_Navarro
    Ismael_Navarro [OP] Member
    Ismael
    1997 Black Tacoma RWD
    Magnaflow muffler, cold air intake, LCE headers, throttle body spacer, short shifter, cat deleted.
    I have a gen 1 Tacoma 98 2.4 l is it bad if I were to pump 91 in my truck. I have headers from LcE not sure if that has anything to do with it but... thanks
  2. Sep 15, 2020 at 10:42 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    No, it’s not bad. Just not necessary. Your motor is designed to run on 87 octane, and the ignition system is easily able to adjust timing to account for any spark knock or detonation during normal operation.
    You only need to run higher octane if you’re supercharged or turboed with these motors, as they have a pretty low compression ratio to begin with.
    TnShooter likes this.
  3. Sep 16, 2020 at 1:40 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Only bad to your budget .
    If it makes you feel better it will not hurt anything
    GQ7227 and Taco critter like this.
