95-04 Pre-Runner Rear Bumper ?'s
Discussion in 'Demello Offroad' started by AggiePilot12, Jan 14, 2013.
  1. Jan 14, 2013 at 1:09 PM
    AggiePilot12
    AggiePilot12 [OP] Well-Known Member
    Texas
    03 4x4 6" Double Cab
    6" Fabtech, All-Pro Leafs, Cold Air, Cat Delete
    Understand they're busy over at Demello, I have sent an email and a PM to Jason but no response so hopefully y'all can answer my questions:
    1) Are there existing license plate mounts?
    a) If so, can you flip up the license plate to access the 2 in. towing
    receiver? Similar to a vertical door hinge.
    b) If not, (why not?) would it be fairly easy to fab mounting spots?
    2) Can you use the stock spare tire access point underneath the tailgate
    via the supplied stock 'turn style rod'?
    3) Last ?: Has anyone had any trouble mounting this bumper? I am hoping
    bolt-on truly means bolt on. Not like the rock crusher sliders needing
    cutting/drilling/welding.
    Thanks TW
  2. Jan 15, 2013 at 10:38 AM
    JDEMELLO
    JDEMELLO Well-Known Member Vendor
    Corona Ca
    none
    Sorry, I've gotten neither. We answer e-mails first thing every morning and try to return any VM before noon.
    Yes there is are two holes for the license plate to mount to.
    Yes you can, it's on a hinge.
    I believe you still can, meaning the last time we installed one you could still access the tire spinner.
    It should bolt right to your frame. We have one sitting in our show room if you want I can take pictures for you.
    E-mail me for faster response. jason@demello-offroad.com
  3. May 28, 2019 at 8:50 PM
    94jdmeg6civic
    94jdmeg6civic Well-Known Member
    David
    orlando
    01 prerunner
    I want this bumper
