95-04 Tacoma; 96-02 4Runner
Discussion in 'Deals & Coupons' started by Toytec Lifts, Jan 13, 2010.
  1. Jan 13, 2010 at 3:11 PM
    Toytec Lifts
    Toytec Lifts [OP] Toyota Suspension specialist Vendor
    Rocky Mountains
    Toyota's are awesome
    I've got 4 sets of these on sale for $399.99
    The UCA’s are adjustable replacement arms offering extra clearance between the tire and control arm as well as in the front spring area. The arms use a larger heavy duty ball joint with a rubber boot to keep moisture and dirt out, while keeping the grease in, thus preventing noise. They feature adjustable camber and caster so alignment on any lift can be dialed in perfectly. They will work with any lift that uses the stock arms yet there is no need for longer CV’s. They will also add some more flex too due to the increased ball joint size and travel.
  2. Jan 13, 2010 at 3:15 PM
    dylandercole
    dylandercole Well-Known Member
    Dylan
    Santa Cruz Mountains, CA
    03 SR5 TRD 4x4 5-speed
    sway-a-way 2.0 coilovers, 1.5'' AAL, 1'' toytec shackle lift, Go-Rhino 3000 Grille Guard, Kicker KS6502 speakers, JVC KD-S24 Head unit, billstein 5125 rear shocks, Deck Plate mod, K&N air filter, Wheelers offroad front and rear braided brake lines, diff breather mod, power slot rotors, ebc yellow stuff pads
    if only i had the cash. id be all over it
  3. Jan 13, 2010 at 3:22 PM
    Toytec Lifts
    Rocky Mountains
    I hear ya ;)
