95.5 TACOMA 4x4 Extracab- CA truck//NO RUST
Discussion in 'Buy / Sell / Trade' started by zidaro, Mar 8, 2010.
  1. Mar 8, 2010 at 2:06 PM
    zidaro
    zidaro [OP] Well-Known Member
    mammoth lakes, ca
    4x4
    87runner with some mods, 08 V8runner ready to rock
    SOLD
    95.5 Tacoma 4x4 Extracab- CALI truck/NO RUST
    3RZ 4cyl.- wicked strong and reliable
    NO accidents
    clean body and interior
    170K on truck- I'm 2nd owner, best friend was original owner- I know complete history on vehicle.
    Stats:
    ENGINE:
    =50K on 3RZ engine(factory Toyota ) installed in truck less than 2K mi. ago in July 2009. Original owner( my buddy) had a thermostat freeze and overheated truck/blew HG. I found a great engine, out of a 96 taco w/48K original mi. that was the shop truck build for a fab shop(project was never finished/scraped), and bought it- easy decision to replace full longblock to avoid ANY issues and save rebuild time.
    =Following installed at same time:
    - thoroughly cleaned inside/out incl. wiring harness(truck original not swapped)
    - AEM ShortRam Intake/Dryflow filter CARB compliant
    - LCE Header ceramic coated
    - LCE street clutch
    - LCE 35# Flywheel w/new OEM fly bolts. Incr. torque for crawling/ no stall
    - LCE underdrive Pulley
    - LCE T.O. bearing/pilot bearing/Header studs/PCV valve/grommet/oil pan gasket/valve cover gasket/fuel filter/oil pump and seal/water pump/termostat/rear seal/rad. cap
    - LCE magnecor wires/cap/rotor
    - new cat. converter
    - GY Gatorback belts PS 43", Alt./AC 34.25"ea.
    - battery Autolite
    - silicone hoses throughout
    - upgraded starter/grd./fuse panel cables
    = T100 oilpan swap kit for your SAS when you are ready
    DRIVE:
    - 5speed W59 trans. tight/ no leaks
    - 4.10 stock gearing
    - Stock 15X7 alloy rims
    - 31.5" crappy tires with plenty of tread to get by ~30% left. Can get great deals on TireRack tires but not gonna install new for sale cuz tires are personal to each- let me know what you may want and we can add them in if you like.
    - Manual Hubs/ NO ADD
    - CV NO leaks/ NO rubbing
    - drilled/slotted rotors
    - Fabtech front +3" adjustable coilovers FTS2100K preformance. Set at 2.5"
    - Fresh prof. alignment
    OTHER:
    - Factory Tow Pkg. receiver/trailer wiring
    - Aux fuse panel in cab under dash
    - Hella Headlamps
    - Spray in Bedliner prof. installed years ago (has 2 bubbles but no tears)
    - Chrome grill/ trim level
    INTERIOR:
    - tachometer(factory)
    - tan 60/40 split bench and rear jumpseats- no wear/tears
    - PW/DoorLocks/PS/rear slider/ Cruise/ hot heat/ AC (needs recharge)
    - Eclipse CD8052 deck
    - Rockford Fosgate Punch4080DSM 4ch. amp
    - Boston Acoustic ProSeries 6.2 separates/ custom hidden enclosure dual 8"subs
    BAD:
    - no rear bumper (sold it cuz was gonna fab up a tube bumper)
    - paint on roof faded
    - minor body dings- DS fender top, rear corner above taillight
    - A/C needs recharge
    - front plastic valence pushed in at frame from dune razorback clearance issues :)
    - tires 30%
    - not a new truck
    Great reliable clean build platform with many important things already tended to. Ready for your own personal touches to be added.
    Only selling cuz i bought a new TUNDRA. Already have a crawler.
    $7000
    May accept partial trades for truck stuff.
    Call/PM/email for any more info.
    Aaron
    760- nine one four- 08 six 8
    zidaro@aol dot com
    truck is in Mammoth Lakes, CA 93546. Possible delivery to SoCal, Reno or other areas. USHIP.com delivers anywhere too.
  2. Mar 9, 2010 at 3:25 PM
    bigsur
    bigsur Well-Known Member
    Stephen
    Big Sur, CA
    2010 4dr 4x4 short bed
    Nice new engine:
    - LCE street clutch
    - battery Autolite
  3. Mar 10, 2010 at 7:18 AM
    zidaro
    mammoth lakes, ca
    4x4
    Not NEW, but sure runs like it. Maybe even better :), the flywheel is great torque, the rest just purs like a kitten.
    all offers considered, BTW.
  4. Mar 10, 2010 at 7:23 AM
    hillbillynwv
    hillbillynwv Well-Known Member
    Fairmont, WV
    08 Tacoma 4x4 TRD V6 SR5
    Rear Leaf Spring TSB, Front Bilstein 5100's set to 1.75, Goodyear Wrangler DuraTrac 265/75/R16 tires, Black WeatherTech Floor Liners, aFe Pro Dry S air filter, lighted 4x4 switch......
    I had the same truck and would still be driving it today if it wasn't for the rusted out frame.
  5. Mar 10, 2010 at 4:52 PM
    zidaro
    mammoth lakes, ca
    4x4
    Frame is in PERFECT shape! Engine is a Tiger!
  6. Mar 11, 2010 at 8:35 AM
    zidaro
    mammoth lakes, ca
    4x4
    up we go
  7. Mar 11, 2010 at 12:16 PM
    zidaro
    mammoth lakes, ca
    4x4
    Answers to some questions:
    A SMOG CERT is included of course
    NO PETS or SMOKING occurred in this truck
  8. Mar 18, 2010 at 9:44 PM
    zidaro
    mammoth lakes, ca
    4x4
    SOLD,
    thanks all for inquiries
